First time Manjaro user here, I am working on getting KDE installed on the System 76 Darter Pro with Coreboot. Coreboot does not really like other distros than Pop O/S but I am going to try again. It also really wants a 5.8 or better Kernel to work. Anyone using a System 76 laptop with Coreboot for Manjaro, I would love to read your adventures.
What do you mean?
Use a recent Manjaro ISO with 5.10 LTS or 5.13.
FYI, there are System76 driver and software packages in the AUR (Arch User Repository).
Thank you. I am just getting it set up, and just installed 5.10. I am going to play with it for a while.
KDE is not my cup of tea, and Cinnamon has some weird issues being laggy, so I am going to now try XFCE.
Back again, and I will keep trying CInnamon, it is what I am used to using. How do I enable Flatpak support? I know it is something simple.
For Flatpak integration in Add/Remove Software, install libpamac-flatpak-plugin
. Also see Flatpak - Manjaro
I am assuming that I do that in Terminal with the “sudo” command? I will give that a shot, thank you. Off to my MRI on my knee so it will be later.
You can install it like any other package from Add/Remove Software or from the terminal. Do not use sudo
with pamac
pamac install libpamac-flatpak-plugin
Or:
sudo pacman -S libpamac-flatpak-plugin
Thank you so much, I now know I have a great deal to learn about Manjaro (Arch) since the syntax is different from that of Mint (Debian) which I am used to. The look and feel of the Manjaro Cinnamon is magnificent, and I am very impressed. I look forward to learning and improving my skills. Since I am going to retire in May of next year, I need a project to keep me busy…
pamac
commands are similar to apt
. see man pamac
or pamac --help
. Each action has it’s own help info as well; i.e., pamac install --help
You can compare apt
commands with pacman
commands here: pacman/Rosetta - ArchWiki
