Boo. Maybe we can try restarting the service…
systemctl restart NetworkManager
(then check ping again … I forgot dig
is part of the bind
package which you do not have)
is part of the bind
Running in chroot, ignoring command 'restart'
This would need to be done for the host system … simply input it in a different terminal
Ok, restarting internet in another window worked, but ping gets the same output yet
EDIT
Even though now software manager notifies me with updates
can you please try to reinitialize the chroot?
exit
and chroot again.
Yay!
Restarting chroot worked!
ping manjaro.org -c3
PING manjaro.org (116.203.91.91) 56(84) bytes of data.
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=1 ttl=51 time=30.2 ms
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=2 ttl=51 time=30.6 ms
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=3 ttl=51 time=30.4 ms
--- manjaro.org ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 30.238/30.417/30.594/0.145 ms
going ahead with
sudo pacman-mirrors -f && sudo pacman -Syu
and it’s working
Woot.
Now lets get back at those mirrors.
EDIT. oh there you go. ok afterwards I think we just want to reinstall the video-linux driver profile:
sudo mhwd -f -i pci video-linux
And … unless there are more errors … I think it might be time to poweroff, unplug usb, and power on.
Everything worked.
I’m restarting the system without the usb drive
YAAAAAAAAAAAAYYYYYYYYY!
It worked!!
Don’t know how to thank you, I could never have done all of this without your help!
No worries. I’m glad its all sorted.
I would say to mark the post that best solves your poblem … but theres a few
Happy linuxing
Yeah! Kind of a long process.
Thank you again and best wishes!
I quoted the most relevant parts so that I can flag this post as the solution and hopefully it is summarizing it all enough.
Hope to have your help again if I need, and to pay you back in some years (for experiencing )
Byeeee!
