On a Samsung Chromebook 3 with the setxkbmap -model chromebook script to use media keys. Maybe ram is related, I have 4GB ram, can you also help me how to increase memory with swap.
Finally, i have found someone with the same issue as me. I thought I was the only one facing that issue.
This used to happen very often but now it occurs very rarely to me that I almost forgot about it
i never thought about the swap though. i started using systemd-swap recently so that might have reduced it .
What’s in logs? Sounds a bit similar to my issue, which is Xorg failure when holding display brightness buttons.
[ 1234.916] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 1234.916] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 1234.916] (WW) xf86OpenConsole: VT_GETSTATE failed: Input/output error
[ 1234.917] (II) Server terminated successfully (0). Closing log file.
this is what i found in Xorg.1.log
right after a logout
Can confirm, this happens to me aswell and it’s very anoying
