Hi, I recently installed Manjaro KDE and have been loving the experience. One thing that has been quite annoying though is that after the computer locks itself, usually within a few hours, it will completely freeze. It doesn’t give an error or anything, just a frozen lock screen with the time of whenever it froze, and requires a restart to continue using the computer. I never have any stability issues when using the computer, but this is a consistent problem when locked. I haven’t found a surefire way to reproduce it, sometimes it goes slightly longer, sometimes it doesn’t freeze even overnight.
So, has anyone had this issue themselves or know how to fix it? How would I go about finding the problem, is there a log or something I can look at? A linux newbie here so try to have some patience.
Thanks.
inxi -Fazy
Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=6b420bc0-7827-4c39-98d5-712be766fa88 rw quiet apparmor=1
security=apparmor resume=UUID=31efe5fb-c24b-428c-9ba1-2ae446e42d6d
udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B350 PC MATE (MS-7A34) v: 2.0
serial: <filter> UEFI: American Megatrends v: A.D0 date: 03/16/2018
Topology: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001136
L2 cache: 3072 KiB
bogomips: 76822
Speed: 1433 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
1: 2208 2: 2086 3: 1376 4: 1377 5: 1368 6: 1369 7: 1368 8: 1367 9: 1378
10: 1376 11: 1377 12: 1377
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 20:00.0
chip ID: 1002:67df
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-2 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.37.0
5.7.17-2-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.6 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 20:00.1
chip ID: 1002:aaf0
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 22:00.3 chip ID: 1022:1457
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus ID: 3-4:4 chip ID: 046d:082d
serial: <filter>
Device-4: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-2:3 chip ID: 0d8c:0005
serial: <filter>
Sound Server: ALSA v: k5.7.17-2-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus ID: 1e:00.0
chip ID: 10ec:8168
IF: enp30s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.16 TiB used: 21.24 GiB (1.0%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
rotation: 7200 rpm serial: <filter> rev: CC43 scheme: GPT
ID-3: /dev/sdc vendor: Kingston model: SA400S37120G size: 111.79 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 61K1 scheme: GPT
ID-4: /dev/sdd vendor: Silicon Power model: SPCC Solid State Disk
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 81.3 scheme: GPT
ID-1: / raw size: 102.69 GiB size: 100.58 GiB (97.94%)
used: 21.24 GiB (21.1%) fs: ext4 dev: /dev/sdc2
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc3
System Temperatures: cpu: 32.2 C mobo: N/A gpu: amdgpu temp: 45 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1893
Processes: 304 Uptime: 18m Memory: 15.65 GiB used: 2.57 GiB (16.4%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1215 pacman: 1211
lib: 346 flatpak: 0 snap: 4 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
