journalctl -p3 -b-1
-- Journal begins at Tue 2021-11-02 11:10:58 IST, ends at Tue 2021-11-16 12:09:43 IST. --
Nov 16 10:19:36 w1sebox kernel: x86/cpu: SGX disabled by BIOS.
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GPLD], AE_ALREADY_EXISTS (20210604/dswl>
Nov 16 10:19:36 w1sebox kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210604/psobject-220)
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20210604/dswl>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GUPC], AE_ALREADY_EXISTS (20210604/dswl>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TUPC], AE_ALREADY_EXISTS (20210604/dswl>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20210604>
...skipping...
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:37 w1sebox tlp[565]: Error: conflicting power-profiles-daemon.service is enabled, power saving will not apply on boot.
Nov 16 10:19:37 w1sebox tlp[565]: >>> Invoke 'systemctl mask power-profiles-daemon.service' to correct this!
Nov 16 10:19:38 w1sebox tlp[740]: Error: conflicting power-profiles-daemon.service is enabled, power saving will not apply on boot.
Nov 16 10:19:38 w1sebox tlp[740]: >>> Invoke 'systemctl mask power-profiles-daemon.service' to correct this!
Nov 16 10:19:43 w1sebox kernel:
Nov 16 10:19:57 w1sebox kded5[993]: org.kde.plasma.dataengine.geolocation: error: "Unknown host location.services.mozilla.com: Host not found"
Nov 16 10:20:38 w1sebox kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
Nov 16 10:49:05 w1sebox kernel: ACPI Error: No handler for Region [CMS0] (00000000706c785b) [SystemCMOS] (20210604/evregion-130)
Nov 16 10:49:05 w1sebox kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20210604/exfldio-261)
Nov 16 10:49:05 w1sebox kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20210604/psparse-529)
Nov 16 11:19:10 w1sebox kernel: ACPI Error: No handler for Region [CMS0] (00000000706c785b) [SystemCMOS] (20210604/evregion-130)
Nov 16 11:19:10 w1sebox kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20210604/exfldio-261)
Nov 16 11:19:10 w1sebox kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20210604/psparse-529)
...skipping...
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20210604>
Nov 16 10:19:36 w1sebox kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20210604>
