Iv delete /usr/share/wallpapers/ is there anyway to restore it to its original.
thankyou
Hello @Dataman
I changed the title to be more accurate
Just search the database with the called directory:
pamac search --files /usr/share/wallpapers/
and it should show which package contains it. Then just install it again:
pamac install my-package
Iv deleted every package it dont show anything thing in wallpapers directory.
What’s your DE? If you are on KDE ok you’ve edited title & tag.
reinstall the packages
sudo pacman -Syu breeze plasma-workspace-wallpapers plasma5-themes-breath2 --overwrite "/usr/share/wallpapers/*"
The command:
Does search the package database and not the directory.
@tuxmanjarino made good list of the packages to install on KDE
