Manjaro KDE critical bug: Plasmashell extreme CPU usage + IO write (also affecting lattedock, dolphin, krunner)
Ok, I really need help…
I have freshly installed manjaro on a new machine and everything worked fine, for two days: Then, all hell breaks loose. The processes “plasmashell” and “lattedock”, as well as “dolphin” (when started), are consuming 30-80% CPU usage, heavily writing something on the disk (IO Write). Also, the used memory of these applications rises slowly, but steadily.
I have already reinstalled the system three times, tryiing desperately to find the root of the problem by maticulously rebooting after every single step of configuration or setup. But it just happenes randomly after a certain period of time - then, the system is stuck in this behaviour immediately after booting.
The complete Desktop is absolutely unusuable, unresponsive. After a while, I can’t even start krunner.
I am stuck.
Specs:
KDE Plasma 5.20.3
Linux Kernel 5.10.0-1 (I tried several others before using this RC)
AMD Ryzen 5 3600
Geforce GTX 3070 on Nvidia 455 Drivers
Help :frowning:
Julius
A temporary fix:
First thing, did you try to use KDE without latte?
Second, as it’s io related, have a look what the processes are actually io-ing. I often use strace to investigate wired process activity. For this, add the pid column to the process list. Open a terminal and use
sudo strace -p thePid
(im not shure if strace is in default installation, if not, it’s available using pacman.
There should be a lot of log traffic but watch out for fopen or similar file operations that may give you a hint about what’s going on .
Hi a-sassermann and thank you for your input.
Yes, the first thing I tried to rule out is latte, I stopped it, even deinstalled it. Same result. The problem occurs always on the process plasmashell, but also in combination with krunner, dolphin and latte-dock.
I have (again) installed manjaro from scratch and I will (again) try to pinpoint, where the bug is coming from. Thank you very much for your tip with strace. I will try that, as soon as it occurs.
Possibly related?
Uh, that’s too high for a semi-noob as me. How could this be related?
Comments and bug reports like this:
It seems like this MR causes hangs of apps and kwin_wayland and high CPU usage of plasmashell on both my PCs: 429593 – KBuildSycoca loop causes hangs
(but also commented is it is possibly fixed with a commit from a few days ago … which might mean the fix is in the pipe for next stable update)
Thanks @cscs! I didn’t saw that one.
I am setting the system up at the moment, fingers crossed…
Same here: plasmashell, dolphin and krunner use extra cpu and write to disk at 2MB/s with latest update 5.20.3
For some reason kservice was installed as kservice-git and many dependencies. In order to install the kservice stable, install purpose (also installed as purpose-git for some reason) and it will install kio stable, then you can install kservice stable from pacman.
Is that a solution / procedure to resolve the problems? :slight_smile:
It worked for me, maybe it will work for you.
If for some reason you are using a mix of giit and non-git packages … then that could be a problem.
And of course even if you use git version for all of plasma … its git … meaning latest, not fully tested … so it could be a problem in and of itself too.
Usually only people desiring the bleeding edge or testers want to be using the GIT packages.
@cscs Thanks for finding this bug! I was trying to chase it down for days!
It worked also for me
If you don’t want to remove the *.git versions of the packages and install the stable versions, another fix is to do the following:
cd ~ && find .config -name mimeapps.list -exec mv {} {}.back \;
The very presence of the mimeapps.list file in .config and/or any subdirectories causes the issue. The contents of the file don’t even matter. You can recreate the issue by touching ~/.config/mimeapps.list.
@lenonk Wow thank you for this amazing tip - nice one liner fixed all my problems. Had issues with plasmashell and krunner running hot - very annoying.
EDIT: System is very fast and responsive now
I have just reinstalled my system with a fresh copy of manjaro kde plasma 20.2 and I can confirm, that indeed kservice and kio are installed as git versions. I am running stable though, why is that? I don’t believe, that this is on purpose, or is it?
Let’s see if the error reoccurs.
So, the aforementioned bug with KSycoca actually seems to be the origin of this.
See this:
So, funny stuff. In the current release of Manjaro, the KSycoca mimeapps.list bug is still there and to make things worse, user-manager as well as his dependencies are installed as git versions (installing manjaro image directly provided from manjaro homepage using the graphical calamari installer with default settings)…
It is quiet shocking to me, but Manjaro KDE is therefore at the moment unfit for daily use, especially for regular users.
A workaround for now (which keeps custom file associations) is to MOVE the mimeapps.list from ~/.config/mimeapps.list to ~/.local/share
  • thanks to @lenonk for pointing in that direction.
The post directly above yours addresses this…
