Hi, i got stuck on the calamares installer on the first step “Waiting for 1 module“:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
23:20:04 [6]: Calamares::Settings::Settings(const QString&, bool)
Using Calamares settings file at "/etc/calamares/settings.conf"
WARNING: .. Required settings.conf key hide-back-and-next-during-exec is missing.
23:20:04 [6]: void Logger::setupLogfile()
Using log file: "/root/.cache/calamares/session.log"
23:20:04 [6]: void CalamaresApplication::init()
Calamares version: 3.2.44.3-1.3
.. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, ca@valencia, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, pl, pt_BR, pt_PT, ro, ru, si, sk, sl, sq, sr, sr@latin, sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
23:20:04 [6]: bool CalamaresUtils::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
23:20:04 [6]: Calamares::Branding::Branding(const QString&, QObject*)
Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
23:20:04 [2]: void Calamares::flavorAndSide(const YAML::Node&, const char*, Calamares::Branding::PanelFlavor&, Calamares::Branding::PanelSide&)
WARNING: Branding setting for sidebar is missing, using "widget" "left"
WARNING: Branding setting for navigation is missing, using "widget" "bottom"
23:20:04 [2]: Calamares::Branding::Branding(const QString&, QObject*)
WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
Loaded branding component "manjaro"
.. Loaded QRC translation "tz_" "en_US"
.. Loaded QRC translation "calamares_" "en_US"
.. STARTUP: initSettings, initQmlPath, initBranding done
.. STARTUP: initModuleManager: module init started
23:20:04 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&)
WARNING: Module descriptor contains extra keys:
"requires"
23:20:04 [6]: void Calamares::ModuleManager::doInit()
Found 49 modules
23:20:04 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
23:20:04 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(1920, 1080) minimum size QSize(1024, 520)
.. Proposed window size: 1024 560
23:20:04 [2]: QString Calamares::_stylesheet(const QDir&)
WARNING: The branding component "/usr/share/calamares/branding/manjaro" does not ship stylesheet.qss.
STARTUP: CalamaresWindow created; loadModules started
23:20:04 [6]: void Config::initLanguages()
Matching locale QLocale(English, Latin, United States)
23:20:04 [6]: void Config::setLocaleIndex(int)
Index 14 Selected locale "en"
.. Loaded QRC translation "tz_" "en"
.. Loaded QRC translation "calamares_" "en"
23:20:04 [2]: OpenType support missing for "Mukti Narrow", script 12
23:20:04 [2]: OpenType support missing for "Droid Sans", script 11
23:20:04 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "welcome@welcome" loading complete.
ViewModule "locale@locale" loading complete.
23:20:04 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
Loaded 188 keyboard models
23:20:04 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
Variants now 0 -1
.. Loaded QRC translation "kb_" "en"
23:20:04 [6]: void Config::detectCurrentKeyboardLayout()
("pc", "us", "inet(evdev)", "terminate(ctrl_alt_bksp)\"")
23:20:05 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "keyboard@keyboard" loading complete.
23:20:05 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
23:20:05 [6]: Loaded backend plugin: "pmsfdiskbackendplugin"
.. Backend @0x555da32c8bd0 "pmsfdiskbackendplugin" "1"
23:20:05 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
ViewModule "partition@partition" loading complete.
ViewModule "users@users" loading complete.
ViewModule "summary@summary" loading complete.
23:20:05 [6]: void Calamares::ModuleManager::loadModules()
Module "partition@partition" already loaded.
23:20:05 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
23:20:05 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
23:20:05 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "machineid@machineid" loading complete.
Module "locale@locale" already loaded.
Module "keyboard@keyboard" already loaded.
CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
CppJobModule "initcpio@initcpio" loading complete.
Module "users@users" already loaded.
23:20:05 [2]: void Config::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
ViewModule "finished@finished" loading complete.
23:20:05 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
23:20:05 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
STARTUP: Window now visible and ProgressTreeView populated
.. 8 view steps loaded.
23:20:05 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= "AT"
23:20:05 [6]: void Config::setLocaleIndex(int)
Index 12 Selected locale "de"
.. No translation for "tz_" "de" using default (en)
.. Loaded QRC translation "calamares_" "de"
.. No translation for "kb_" "de" using default (en)
23:20:05 [6]: getting temp failed for "/dev/nvme0n1" : Success
23:20:05 [6]: getting powered on time failed for "/dev/nvme0n1" : Success
23:20:05 [6]: getting power cycles failed for "/dev/nvme0n1" : Success
23:20:05 [6]: void Config::xkbApply()
xkbmap selection changed to: "us" - ""
23:20:06 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 2
"partition"
"welcome"
23:20:07 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"welcome"
23:20:08 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"welcome"
23:20:09 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"welcome"
23:20:11 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"welcome"
23:20:12 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"welcome"
23:20:13 [6]: void Config::setLocaleIndex(int)
23:20:13 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"welcome"
23:20:14 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"welcome"
23:20:15 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"welcome"
23:20:16 [6]: bool GeneralRequirements::checkHasPower()
A battery exists, checking for mains power.
23:20:16 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
GeneralRequirements output:
storage : 8482560409
enoughStorage : true
RAM : 1073741824
enoughRam : true
hasPower : true
hasInternet : true
isRoot : true
23:20:16 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 5 requirement results from "welcome"
23:20:17 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 1
"partition"
23:20:18 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:19 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:20 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:21 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:23 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:24 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:25 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:26 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:27 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:29 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:30 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:31 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:32 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:33 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:35 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:36 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:37 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:38 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:39 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:41 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:42 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:43 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:44 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:45 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:47 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:48 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:49 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:50 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:51 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:53 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:54 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:55 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:56 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:20:57 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
after 300 seconds still nothing happened
I tried connecting with LAN, WLAN still no improvement
I also used Ventoy, Rufus and BalenaEtcher
Is there any workaround?
