Manjaro KDE 20.2 does not install epson-printer-utility
Mod-edit: Formatting
I am trying to install epson-printer-utility from AUR via Pamac at no luck, and this is the output I have:
Preparing...
Cloning epson-printer-utility build files...
Checking epson-printer-utility dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building epson-printer-utility...
==> Making package: epson-printer-utility 1.1.1-15 (Tue Dec 29 15:31:25 2020)
==> Retrieving sources...
  -> Downloading epson-printer-utility_1.1.1-1lsb3.2_amd64.deb...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
curl: (22) The requested URL returned error: 404 Not Found
==> ERROR: Failure while downloading xxxxx://download3.ebz.epson.net/dsc/f/03/00/12/04/36/91a3d7ad4a056612f9a4d2f96f6a8b4a9a4ccf88/epson-printer-utility_1.1.1-1lsb3.2_amd64.deb
    Aborting...
Failed to build epson-printer-utility
Obviously there is no more a package to download.
Otherwise the printer is recognized and work well.
Any ideas how to get it installed?
Thanks.
Hi and welcome to the forum :+1:
You should contact the author of the AUR package, because if it can’t find it’s source to build the package you won’t be able to install it.
Thank you, I will.
