Title says all, I know it’s a common problem and it’s not my first time installing manjaro. Also, if needed, i can provide information but i don’t know what should i give so I’ll leave it blank. I used rufus to create the bootable. Live disk works fine, every app works, internet, battery works too. Just the installation.
Hello @Nzyme
Run this in a terminal:
sudo calamares -d
and share this log:
/root/.cache/calamares/session.log
These were the logs for a gnome DE i tried. KDE didn’t work, so i tried installing the gnome one and same problem. Stuck at the welcome screen. I tried connecting to internet, disconnecting from it. None works.
const QString&, const QString&)
ERROR: YAML parser error yaml-cpp: error at line 4, column 5: end of map not found
- 21:44:20 [1]: void Calamares::ModuleManager::loadModules()
ERROR: Module "users@users" cannot be created from descriptor "users.conf"
2020-11-24 - 21:47:49 [0]: QObject::~QObject: Timers cannot be stopped from another thread
- 21:47:49 [2]: void Calamares::Module::loadConfigurationFile(const QString&)
WARNING: Bad module configuration format "/etc/calamares/modules/users.conf"
Strange… it abort at this point…
Here is a working log:
=== START CALAMARES 3.2.30-1
2020-11-24 - 16:45:06 [6]: void CalamaresApplication::init()
Calamares version: 3.2.30-1
2020-11-24 - 16:45:06 [6]: .. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, es_PR, et, eu, fa, fi_FI, fr, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, pl, pt_BR, pt_PT, ro, ru, sk, sl, sq, sr, sr@latin, sv, te, tg, th, tr_TR, uk, zh_CN, zh_TW"
2020-11-24 - 16:45:06 [6]: bool CalamaresUtils::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
2020-11-24 - 16:45:06 [6]: Calamares::Branding::Branding(const QString&, QObject*)
Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
2020-11-24 - 16:45:06 [2]: void Calamares::flavorAndSide(const YAML::Node&, const char*, Calamares::Branding::PanelFlavor&, Calamares::Branding::PanelSide&)
WARNING: Branding setting for sidebar is missing, using "widget" "left"
WARNING: Branding setting for navigation is missing, using "widget" "bottom"
2020-11-24 - 16:45:06 [2]: Calamares::Branding::Branding(const QString&, QObject*)
WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
Loaded branding component "manjaro"
2020-11-24 - 16:45:06 [6]: .. Loaded QRC translation "tz_" "en_US"
2020-11-24 - 16:45:06 [6]: .. Loaded QRC translation "calamares_" "en_US"
2020-11-24 - 16:45:06 [6]: .. STARTUP: initSettings, initQmlPath, initBranding done
2020-11-24 - 16:45:06 [6]: .. STARTUP: initModuleManager: module init started
2020-11-24 - 16:45:06 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&)
WARNING: Module descriptor contains extra keys:
"requires"
2020-11-24 - 16:45:06 [6]: void Calamares::ModuleManager::doInit()
Found 45 modules
2020-11-24 - 16:45:06 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
2020-11-24 - 16:45:06 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(1680, 1013) minimum size QSize(1024, 520)
2020-11-24 - 16:45:06 [6]: .. Proposed window size: 1024 560
2020-11-24 - 16:45:07 [2]: QString Calamares::_stylesheet(const QDir&)
WARNING: The branding component "/usr/share/calamares/branding/manjaro" does not ship stylesheet.qss.
2020-11-24 - 16:45:07 [6]: void CalamaresApplication::initView()
STARTUP: CalamaresWindow created; loadModules started
2020-11-24 - 16:45:07 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/etc/calamares/modules/welcome.conf"
2020-11-24 - 16:45:07 [6]: void Config::initLanguages()
Matching locale QLocale(English, Latin, United States)
2020-11-24 - 16:45:07 [6]: .. Matched with index 13 "en_US"
2020-11-24 - 16:45:07 [6]: .. Loaded QRC translation "tz_" "en_US"
2020-11-24 - 16:45:07 [6]: .. Loaded QRC translation "calamares_" "en_US"
2020-11-24 - 16:45:07 [6]: void Config::setLocaleIndex(int)
Index 13 Selected locale QLocale(English, Latin, United States)
2020-11-24 - 16:45:07 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "welcome@welcome" loading complete.
Loaded module configuration "/etc/calamares/modules/locale.conf"
ViewModule "locale@locale" loading complete.
Loaded module configuration "/usr/share/calamares/modules/keyboard.conf"
2020-11-24 - 16:45:07 [2]: virtual QString CalamaresUtils::GeoIP::GeoIPJSON::rawReply(const QByteArray&)
WARNING: Invalid YAML data for GeoIPJSON
ViewModule "keyboard@keyboard" loading complete.
Loaded module configuration "/usr/share/calamares/modules/partition.conf"
2020-11-24 - 16:45:07 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
2020-11-24 - 16:45:07 [8]: Loaded backend plugin: "pmsfdiskbackendplugin"
2020-11-24 - 16:45:07 [6]: .. Backend @0x55df64a8a9c0 "pmsfdiskbackendplugin" "1"
2020-11-24 - 16:45:07 [6]: CalamaresUtils::Partition::KPMManager::KPMManager()
KPMManager 1 created.
2020-11-24 - 16:45:07 [6]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
Setting firmwareType to "bios"
2020-11-24 - 16:45:07 [6]: QString PartUtils::findFS(QString, FileSystem::Type*)
Found filesystem "ext4"
Partition-module setting *defaultFileSystemType* "ext4"
ViewModule "partition@partition" loading complete.
Loaded module configuration "/etc/calamares/modules/users.conf"
ViewModule "users@users" loading complete.
ViewModule "summary@summary" loading complete.
2020-11-24 - 16:45:07 [6]: void Calamares::ModuleManager::loadModules()
Module "partition@partition" already loaded.
2020-11-24 - 16:45:07 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
Loaded module configuration "/usr/share/calamares/modules/mount.conf"
Loaded module configuration "/etc/calamares/modules/unpackfs.conf"
Loaded module configuration "/etc/calamares/modules/machineid.conf"
2020-11-24 - 16:45:07 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
2020-11-24 - 16:45:07 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "machineid@machineid" loading complete.
Loaded module configuration "/usr/share/calamares/modules/fstab.conf"
Module "locale@locale" already loaded.
Module "keyboard@keyboard" already loaded.
Loaded module configuration "/usr/share/calamares/modules/luksopenswaphookcfg.conf"
CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
No config file for "initcpiocfg" found anywhere at
"/home/manjaro/Desktop/src/modules/initcpiocfg/initcpiocfg.conf"
"/etc/calamares/modules/initcpiocfg.conf"
"/usr/share/calamares/modules/initcpiocfg.conf"
Loaded module configuration "/etc/calamares/modules/initcpio.conf"
CppJobModule "initcpio@initcpio" loading complete.
Module "users@users" already loaded.
Loaded module configuration "/etc/calamares/modules/displaymanager.conf"
Loaded module configuration "/etc/calamares/modules/mhwdcfg.conf"
Loaded module configuration "/etc/calamares/modules/services.conf"
Loaded module configuration "/usr/share/calamares/modules/grubcfg.conf"
Loaded module configuration "/etc/calamares/modules/bootloader.conf"
Loaded module configuration "/etc/calamares/modules/postcfg.conf"
Loaded module configuration "/usr/share/calamares/modules/umount.conf"
Loaded module configuration "/etc/calamares/modules/finished.conf"
2020-11-24 - 16:45:07 [2]: virtual void FinishedViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
ViewModule "finished@finished" loading complete.
2020-11-24 - 16:45:07 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
2020-11-24 - 16:45:07 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
2020-11-24 - 16:45:08 [6]: void CalamaresApplication::initViewSteps()
STARTUP: Window now visible and ProgressTreeView populated
2020-11-24 - 16:45:08 [6]: .. 8 view steps loaded.
2020-11-24 - 16:45:08 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= ""
2020-11-24 - 16:45:08 [6]: void setCountry(Config*, const QString&, CalamaresUtils::GeoIP::Handler*)
Unusable country code ""
2020-11-24 - 16:45:08 [6]: .. Obtained from "https://ipapi.co/json" ( 1 "country" )
2020-11-24 - 16:45:08 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 0 requirement results from "bootloader"
Got 0 requirement results from "displaymanager"
Got 0 requirement results from "finished"
Got 0 requirement results from "fstab"
Got 0 requirement results from "grubcfg"
Got 0 requirement results from "hwclock"
Got 0 requirement results from "initcpio"
Got 0 requirement results from "initcpiocfg"
Got 0 requirement results from "keyboard"
Got 0 requirement results from "locale"
Got 0 requirement results from "localecfg"
Got 0 requirement results from "luksbootkeyfile"
Got 0 requirement results from "luksopenswaphookcfg"
Got 0 requirement results from "machineid"
Got 0 requirement results from "mhwdcfg"
Got 0 requirement results from "mount"
Got 0 requirement results from "networkcfg"
2020-11-24 - 16:45:08 [6]: KeyboardPage::onListVariantCurrentItemChanged(QListWidgetItem*, QListWidgetItem*)::<lambda()>
xkbmap selection changed to: "de" - ""
2020-11-24 - 16:45:08 [8]: getting temp failed for "/dev/nvme0n1" : Success
2020-11-24 - 16:45:08 [8]: getting powered on time failed for "/dev/nvme0n1" : Success
2020-11-24 - 16:45:08 [8]: getting power cycles failed for "/dev/nvme0n1" : Success
2020-11-24 - 16:45:09 [8]: smartctl initialization failed for "/dev/sda" : No such file or directory
2020-11-24 - 16:45:09 [8]: error during smart output parsing for "/dev/sda" : Success
2020-11-24 - 16:45:09 [6]: QList<Device*> PartUtils::getDevices(PartUtils::DeviceType)
Removing unsuitable devices: 2 candidates.
2020-11-24 - 16:45:09 [6]: void PartitionCoreModule::doInit()
LIST OF DETECTED DEVICES:
node capacity name prettyName
"/dev/nvme0n1" 16812472320 "ORCL-VBOX-NVME-VER12" "ORCL-VBOX-NVME-VER12 – 15.66 GiB (/dev/nvme0n1)"
"/dev/sda" 2199020382720 "VBOX HARDDISK" "VBOX HARDDISK – 2.00 TiB (/dev/sda)"
2020-11-24 - 16:45:09 [6]: .. 2 devices detected.
2020-11-24 - 16:45:09 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 8
"partition"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
2020-11-24 - 16:45:10 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
2020-11-24 - 16:45:11 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "env" ("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p1")
2020-11-24 - 16:45:11 [6]: .. Finished. Exit code: 0
2020-11-24 - 16:45:11 [6]: .. Target cmd: ("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p1") output:
ext4
2020-11-24 - 16:45:11 [6]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
Checking device "/dev/nvme0n1p1" for fstab (fs= "ext4" )
Running "env" ("mount", "-o", "ro,noload", "/dev/nvme0n1p1", "/tmp/calamares-BkVffH")
2020-11-24 - 16:45:11 [6]: .. Target cmd: ("mount", "-o", "ro,noload", "/dev/nvme0n1p1", "/tmp/calamares-BkVffH") output:
Running "env" ("udevadm", "settle")
2020-11-24 - 16:45:11 [6]: .. Target cmd: ("udevadm", "settle") output:
Running "env" ("sync")
2020-11-24 - 16:45:11 [6]: .. Target cmd: ("sync") output:
2020-11-24 - 16:45:11 [6]: .. reading "/tmp/calamares-BkVffH/etc/fstab"
2020-11-24 - 16:45:11 [6]: .. got 9 lines.
2020-11-24 - 16:45:11 [6]: .. got 9 fstab entries.
Running "env" ("umount", "-R", "/tmp/calamares-BkVffH")
2020-11-24 - 16:45:11 [6]: .. Target cmd: ("umount", "-R", "/tmp/calamares-BkVffH") output:
2020-11-24 - 16:45:11 [6]: bool PartUtils::canBeResized(PartitionCoreModule*, const QString&)
Checking if "/dev/nvme0n1p1" can be resized.
2020-11-24 - 16:45:11 [6]: bool PartUtils::canBeResized(Partition*)
Partition "/dev/nvme0n1p1" authorized for resize + autopartition install.
2020-11-24 - 16:45:11 [6]: OsproberEntryList PartUtils::runOsprober(PartitionCoreModule*)
os-prober lines after cleanup:
"/dev/nvme0n1p1:Manjaro Linux (20.1.2):ManjaroLinux:linux"
2020-11-24 - 16:45:11 [6]: void BootLoaderModel::init(const QList<Device*>&)
BLM::init with 2 devices 0 rows
2020-11-24 - 16:45:11 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 0 requirement results from "postcfg"
Got 0 requirement results from "services"
Got 1 requirement results from "partition"
Got 0 requirement results from "summary"
Got 0 requirement results from "umount"
Got 0 requirement results from "users"
2020-11-24 - 16:45:11 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
Need at least storage bytes: 8482560409
Got 0 requirement results from "unpackfs"
2020-11-24 - 16:45:11 [6]: void ChoicePage::updateDeviceStatePreview()
Updating partitioning state widgets.
2020-11-24 - 16:45:11 [6]: void ChoicePage::setupActions()
Setting up actions for "/dev/nvme0n1" with 1 entries.
2020-11-24 - 16:45:11 [6]: .. contains resizable "/dev/nvme0n1p1"
2020-11-24 - 16:45:11 [6]: bool PartUtils::canBeReplaced(Partition*)
Checking if "/dev/nvme0n1p1" can be replaced.
Partition "/dev/nvme0n1p1" authorized for replace install.
2020-11-24 - 16:45:11 [6]: .. contains replaceable "/dev/nvme0n1p1"
2020-11-24 - 16:45:11 [6]: ChoicePage::setupActions()::<lambda()>
Setting texts for 1 non-empty osprober entry
2020-11-24 - 16:45:11 [6]: void ChoicePage::updateActionChoicePreview(ChoicePage::InstallChoice)
Updating partitioning preview widgets.
Need at least ram bytes: 1073741824
GeneralRequirements output:
enoughStorage : true
enoughRam : true
hasPower : true
hasInternet : true
isRoot : true
Got 5 requirement results from "welcome"
2020-11-24 - 16:45:11 [6]: void Calamares::RequirementsChecker::finished()
All requirements have been checked.
2020-11-24 - 16:45:11 [6]: void Calamares::RequirementsModel::describe() const
Requirements model has 6 items
2020-11-24 - 16:45:11 [6]: .. requirement 0 "partitions" satisfied? true mandatory? true
2020-11-24 - 16:45:11 [6]: .. requirement 1 "storage" satisfied? true mandatory? true
2020-11-24 - 16:45:11 [6]: .. requirement 2 "ram" satisfied? true mandatory? true
2020-11-24 - 16:45:11 [6]: .. requirement 3 "power" satisfied? true mandatory? false
2020-11-24 - 16:45:11 [6]: .. requirement 4 "internet" satisfied? true mandatory? false
2020-11-24 - 16:45:11 [6]: .. requirement 5 "root" satisfied? true mandatory? true
$ lsb_release -r
Release: 20.1.2
Which version are you using?
@megavolt 20.1.2 if you’re asking about the distro. I just downloaded it so it’s the latest stable one.
It happened to me too, But after it waits for 120 seconds it automatically loads idk why.
Maybe try to connect to internet and then try. Cause after waiting it says no internet connection.
Hope it helps.
I’ve waited for more than 4000 seconds, and I’ve tried connecting to internet, also without it. Same problem every time.
I was trying to install the KDE plasma DE 20.1.2 and i ran into the waiting for 1 module issue repeatedly across multiple tries and reflashing the bootable usb. Wierdly enough i connected to wifi and waited for about 120s and it worked…
I can confirm this is still an issue with Manjaro KDE Plasma 21.1.6 Installer. The XFCE installer worked fine for me. This only happed with the KDE one.
I tried start with Open Source and Proprietary Drivers.
For me, connecting to the internet did not fix it and I was never able to install.
Is there a known fix for this?
