It is unrealistic to ask a question like “Is that normal?” – it simply cannot be answered with any authority.
The relative size of an ISO file will vary across Editions and/or Distributions, dependent upon the content it contains, its purpose, and the intended audience.
Suffice to say ISO’s are typically not getting any smaller for any OS; whether it might be any of the distributions you mentioned, Manjaro, BSD, MacOS or Windows.
Step 1. Download the ISO – Manjaro Downloads – Download the full ISO rather than minimal (personal recommendation).
Note that it is also possible to download an ISO via Torrent (a bit-torrent client is required).
Step 2. Verify the ISO against the provided checksum (SHA256) – See the More button of your chosen OS download.
In KDE Plasma: right-click an ISO, select Properties → Checksums and validate the checksum via that dialog.
A worthwhile alternative to writing the ISO content directly to USB is to create a Ventoy USB instead:
Ventoy
Boot with a Ventoy USB, and ISO files are automatically listed in the Ventoy menu, and can be booted directly. A 32GB capacity USB should allow ample space to store several ISOs of your choice; an 8GB capacity USB might hold one, or two ISO’s; do the math.
Ventoy is available from the official Manjaro extra repository:
sudo pacman -S ventoy
Write the Ventoy system to an empty USB drive;
- target the device itself
/dev/sdX, and not a partition
Create a Ventoy USB (for UEFI mode):
sudo sh ventoy -i -r 100 -S -g -L VOLUME /dev/sdX
Create a Ventoy USB (for BIOS mode):
sudo sh ventoy -i -r 100 -S -L VOLUME /dev/sdX
- Enable
-s or disable -S Secure Boot.
- Substitute
VOLUME for a volume label name to use.
- Substitute
/dev/sdX for the location of your USB device.
- Preserve some space on the target device (example allows 100mb).
Ventoy general usage
Type ventoy (without arguments) to see usage information:
Usage: Ventoy2Disk.sh CMD [ OPTION ] /dev/sdX
CMD:
-i install Ventoy to sdX (fails if disk already installed with Ventoy)
-I force install Ventoy to sdX (no matter if installed or not)
-u update Ventoy in sdX
-l list Ventoy information in sdX
OPTION: (optional)
-r SIZE_MB preserve some space at the bottom of the disk (only for install)
-s/-S enable/disable secure boot support (default is enabled)
-g use GPT partition style, default is MBR (only for install)
-L Label of the 1st exfat partition (default is Ventoy)
-n try non-destructive installation (only for install)
Update a Ventoy USB:
- ensure the updated Ventoy version is available in Manjaro; and then:
To update the Ventoy system on an existing Ventoy USB;
sudo ventoy -u /dev/sdX
- The Ventoy USB update process is non-destructive.
See also: Ventoy (GitHub);
Notes
There is a Windows GUI version of Ventoy. If you choose to use it please pay attention to available options in the File menu before creating the Ventoy USB.
This is noted (somewhere) in Ventoy’s own documentation, but I’ll add it here for convenience; When an ISO is dragged/copied to the Ventoy USB it’s recommended to rename the ISO (using underscores) so that no blank spaces appear in the filename.
Welcome to the Manjaro community.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Resources:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
