so did you rebooted? it looks like nothing was removed…
provide output from:
cat /etc/modprobe.d/blacklist-nvidia.conf
cat /etc/modprobe.d/ec_sys.conf
cat /etc/modprobe.d/isw-ec_sys.conf
cat /etc/modprobe.d/mhwd-gpu.conf
Yeah, i rebooted before, and i just rebooted again just in case and ran the command you previously told me to and had the same output.
Here’s the output to the cat /ect/… command:
# Automatically generated by EnvyControl
blacklist nouveau
blacklist nvidia
blacklist nvidia_drm
blacklist nvidia_uvm
blacklist nvidia_modeset
alias nouveau off
alias nvidia off
alias nvidia_drm off
alias nvidia_uvm off
alias nvidia_modeset off
options ec_sys write_support=1
# This file is related to isw:
# https://github.com/YoyPa/isw
## Generated by mhwd - Manjaro Hardware Detection
so delete this one:
sudo rm /etc/modprobe.d/blacklist-nvidia.conf
install nvidia drivers:
sudo mhwd -a pci nonfree 0300
reboot and post again output from:
mhwd -l && mhwd -li
Ok, before i reboot, i just want to ask, i ran the sudo mhwd… command, and got this output, is this normal?
> Skipping already installed config 'video-linux' for device: 0000:00:02.0 (0300:8086:9bc4) Display controller Intel Corporation CometLake-H GT2 [UHD Graphics]
yes you have already installed the video linux drivers for your intel gpu
Ok thats good, so i just rebooted, here’s the output:
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0300:8086:9bc4) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
nothing is installed …
post output from:
pacman -Qs 'nvidia|bumblebee|optimus|bbswitch|envycontrol
pamac list -qm
I ran that command and it doesnt show any output, i just get a “>” and nothing else
theres a typo in the first command:
pacman -Qs 'nvidia|bumblebee|optimus|bbswitch|envycontrol'
pamac list -qm
Oh, ok here’s the output then
local/lib32-libvdpau 1.5-1
Nvidia VDPAU library
local/libvdpau 1.5-1
local/mhwd-nvidia 515.65.01-3
MHWD module-ids for nvidia 515.65.01
local/mhwd-nvidia-390xx 390.154-1
MHWD module-ids for nvidia 390.154
local/mhwd-nvidia-470xx 470.141.03-1
MHWD module-ids for nvidia 470.141.03
local/prime 1.0-14
Nvidia:PRIME Render Offload Launcher
local/xf86-video-nouveau 1.0.17-2 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
auto-cpufreq
cython2
discord-ptb
driconf
fancontrol-gui
libglade
nbfc
prime
prime-gpuchooser
pygtk
python2-cairo
python2-gobject2
python2-numpy
triehash
you installed probably every package related to switching between gpus… remove this:
pamac remove prime prime-gpuchooser
reboot and provide again output from:
mhwd -l && mhwd -li
Yeah, i had come to a point where i just didnt know what to do anymore, so i just started downloading every single thing that had to do with gpu switching, which looking back at it was not a good idea lol.
Here’s the ouput after a reboot:
its still not detected!!
do you remember what you installed?
post output from:
pacman -Qs 'offload|switch|gpu|prime'
From what i remember, i had installed bumblebee, optimus, and then recently prime, but i might have installed something else related to gpu, not sure.
Here’s the ouput:
local/libplacebo 4.208.0-1
Reusable library for GPU-accelerated video/image rendering primitives
local/mhwd-amdgpu 19.1.0-1
MHWD module-ids for amdgpu
local/python-pyamdgpuinfo 2.1.3-2
AMD GPU stats
local/usb_modeswitch 2.6.1-3
Activating switchable USB devices on Linux.
local/xf86-video-amdgpu 22.0.0-1 (xorg-drivers)
X.org amdgpu video driver
local/xfce4-xkb-plugin 0.8.3-1 (xfce4-goodies)
Plugin to switch keyboard layouts for the Xfce4 panel
why do you have installed this: python-pyamdgpuinfo
, since you dont have any amdgpu… you can remove it:
pamac remove python-pyamdgpuinfo
search in your root for the following:
bumblebee, envycontrol, optimus
and delete the folders/files, except the optimus one, results from optimus post here
Ok so i removed the pyamdgpuinfo, and in my root i had an envycontrol directory, which i removed, i also have a file named “ui_gpuchooser.py” should i delete that too? Also, i do not see any files/directories related to optimus on my root.
yes delete that gpuchooser too… also search for bbswitch
… if it didnt find anything, you can reboot, and post again output from:
mhwd -l
Ok, there was nothing related to bbswitch so i rebooted, here’s the output:
well nothing, nvidia is not being detected…
is nvidia disabled in bios? you mentioned something about windows, is nvidia detected there?
Yeah, i switched from windows not too long ago, and my nvidia card worked fine, when doing the switch the only thing i changed in the bios was disabling secure boot, so i dont think that i couldve disabled nvidia there, as i dont even know how to disable it lol. Some other people have suggested it may have to do with the UEFI, and when i go to that in my bios i can choose between legacy, uefi, and uefi csm. Currently i have that setting in uefi, do you think changing that would affect it?
