no thats not related … so if you didnt disable it manually in bios, it has to be something messed up here in linux… or maybe the card is dead? … post output from:
sudo dmesg | grep -E 'nvidia|gpu|nvrm'
I really hope the card is not dead, but here’s the output:
[ 1.616700] audit: type=1400 audit(1664479536.594:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=293 comm="apparmor_parser"
[ 1.617740] audit: type=1400 audit(1664479536.594:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=293 comm="apparmor_parser"
[ 2.589723] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
EDIT:
Can you also tell me how i would disable the gpu in bios? Cause i just want to check that i havent accidentally disabled it before
nothing in logs except the apparmor, but thats not important … so since its not being detected, boot into manjaro live usb, select proprietary drivers, and check with:
inxi -G
if the nvidia is detected …
before you do that post output from:
sudo dmesg | grep -E 'bbswitch|bumblebee'
journalctl -b0 --no-pager | grep -E 'nvidia|gpu|nvrm|bumblebee|bbswitch'
that i cant tell you, you just have to go trough each setting in bios and check anything related to graphics/nvidia … but since you dont know, you probably didnt disable it… and also not every bios has the option to switch between gpus - mine laptop for example doesnt have the option…
Here’s the output of the sudo dmesg…:
Sep 29 16:25:36 rojoxis-laptop kernel: audit: type=1400 audit(1664479536.594:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=293 comm="apparmor_parser"
Sep 29 16:25:36 rojoxis-laptop kernel: audit: type=1400 audit(1664479536.594:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=293 comm="apparmor_parser"
Sep 29 16:25:36 rojoxis-laptop audit[293]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=293 comm="apparmor_parser"
Sep 29 16:25:36 rojoxis-laptop audit[293]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=293 comm="apparmor_parser"
Sep 29 16:25:37 rojoxis-laptop kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
nothing there… post also from the journalctl output, then prepare the live usb, and check bios settings
I just checked the live usb and the nvidia gpu is detected after running the inxi -G
command.
Here’s the journalctl output:
Sep 29 16:59:19 rojoxis-laptop kernel: audit: type=1400 audit(1664481559.638:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=306 comm="apparmor_parser"
Sep 29 16:59:19 rojoxis-laptop audit[306]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=306 comm="apparmor_parser"
Sep 29 16:59:19 rojoxis-laptop audit[306]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=306 comm="apparmor_parser"
Sep 29 16:59:20 rojoxis-laptop kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
so its something your linux installation… provide output from:
ls /etc/modules-load.d
ls /etc/udev/rules.d
ls /etc/modprobe.d
Ok, here’s the output:
ec_sys.conf isw-ec_sys.conf mhwd-gpu.conf modules.conf
70-snap.snapd.rules 83.ac_power.rules
Would u suggest making a clean install of manjaro to undo all the dumb mistakes i made?
so post output from:
cat /etc/modules-load.d/modules.conf
cat /etc/modules-load.d/mhwd-gpu.conf
cat /etc/udev/rules.d/70-snap.snapd.rules
cat /etc/udev/rules.d/83.ac_power.rules
the reinstall would be the last option …
# List of modules to load at boot
## Generated by mhwd - Manjaro Hardware Detection
# This file is automatically generated.
# Concatenation of all ModemManager udev rules
# do not edit this file, it will be overwritten on update
ACTION!="add|change|move|bind", GOTO="mm_cinterion_port_types_end"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="1e2d", GOTO="mm_cinterion_port_types"
LABEL="mm_cinterion_port_types"
SUBSYSTEMS=="usb", ATTRS{bInterfaceNumber}=="?*", ENV{.MM_USBIFNUM}="$attr{bInterfaceNumber}"
# PHS8
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0053", ENV{.MM_USBIFNUM}=="01", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_GPS}="1"
# PLS8 port types
# ttyACM0 (if #0): AT port
# ttyACM1 (if #2): AT port
# ttyACM2 (if #4): GPS data port
# ttyACM3 (if #6): unknown
# ttyACM4 (if #8): unknown
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0061", ENV{.MM_USBIFNUM}=="00", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_PRIMARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0061", ENV{.MM_USBIFNUM}=="02", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_SECONDARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0061", ENV{.MM_USBIFNUM}=="04", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_GPS}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0061", ENV{.MM_USBIFNUM}=="06", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0061", ENV{.MM_USBIFNUM}=="08", ENV{ID_MM_PORT_IGNORE}="1"
# PLS62 family non-mbim enumeration uses alternate settings for 2G band management
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005b", ENV{ID_MM_CINTERION_MODEM_FAMILY}="imt"
# ttyACM2 (if #4): can be AT or GNSS in some models
# ttyACM3 (if #6): AT port (but just ignore)
# ttyACM4 (if #8): DIAG/QCDM
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005b", ENV{.MM_USBIFNUM}=="00", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_PRIMARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005b", ENV{.MM_USBIFNUM}=="02", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_SECONDARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005b", ENV{.MM_USBIFNUM}=="04", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_GPS}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005b", ENV{.MM_USBIFNUM}=="06", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005b", ENV{.MM_USBIFNUM}=="08", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_QCDM}="1"
# PLS62 family mbim enumeration
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005d", ENV{.MM_USBIFNUM}=="00", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_PRIMARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005d", ENV{.MM_USBIFNUM}=="02", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_SECONDARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005d", ENV{.MM_USBIFNUM}=="04", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_GPS}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005d", ENV{.MM_USBIFNUM}=="06", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="005d", ENV{.MM_USBIFNUM}=="08", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_QCDM}="1"
# PLS63
# ttyACM3 (if #6): DIAG/QCDM
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0069", ENV{.MM_USBIFNUM}=="00", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_PRIMARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0069", ENV{.MM_USBIFNUM}=="02", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_SECONDARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0069", ENV{.MM_USBIFNUM}=="04", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_GPS}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="0069", ENV{.MM_USBIFNUM}=="06", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_QCDM}="1"
# PLS83
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="006F", ENV{.MM_USBIFNUM}=="00", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_PRIMARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="006F", ENV{.MM_USBIFNUM}=="02", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_AT_SECONDARY}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="006F", ENV{.MM_USBIFNUM}=="04", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_GPS}="1"
ATTRS{idVendor}=="1e2d", ATTRS{idProduct}=="006F", ENV{.MM_USBIFNUM}=="06", SUBSYSTEM=="tty", ENV{ID_MM_PORT_TYPE_QCDM}="1"
LABEL="mm_cinterion_port_types_end"
ACTION!="add|change|move", GOTO="mm_mbm_end"
SUBSYSTEMS=="usb", GOTO="mm_mbm_check"
GOTO="mm_mbm_end"
LABEL="mm_mbm_check"
# Ericsson F3507g
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1900", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1902", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson F3607gw
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1904", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1905", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1906", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson F3307
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="190a", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1909", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson F3307 R2
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1914", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson C3607w
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1049", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson C3607w v2
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="190b", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson F5521gw
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="190d", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1911", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson H5321gw
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1919", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson H5321w
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="191d", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson F5321gw
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1917", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson F5321w
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="191b", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson C5621gw
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="191f", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson C5621w
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1921", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson H5321gw
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1926", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1927", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson C3304w
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1928", ENV{ID_MM_ERICSSON_MBM}="1"
# Ericsson C5621 TFF
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1936", ENV{ID_MM_ERICSSON_MBM}="1"
# Sony-Ericsson MD300
ATTRS{idVendor}=="0fce", ATTRS{idProduct}=="d0cf", ENV{ID_MM_ERICSSON_MBM}="1"
# Sony-Ericsson MD400
ATTRS{idVendor}=="0fce", ATTRS{idProduct}=="d0e1", ENV{ID_MM_ERICSSON_MBM}="1"
# Sony-Ericsson MD400G
ATTRS{idVendor}=="0fce", ATTRS{idProduct}=="d103", ENV{ID_MM_ERICSSON_MBM}="1"
# Dell 5560
ATTRS{idVendor}=="413c", ATTRS{idProduct}=="818e", ENV{ID_MM_ERICSSON_MBM}="1"
# Dell 5550
ATTRS{idVendor}=="413c", ATTRS{idProduct}=="818d", ENV{ID_MM_ERICSSON_MBM}="1"
# Dell 5530 HSDPA
ATTRS{idVendor}=="413c", ATTRS{idProduct}=="8147", ENV{ID_MM_ERICSSON_MBM}="1"
# Dell F3607gw
ATTRS{idVendor}=="413c", ATTRS{idProduct}=="8183", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="413c", ATTRS{idProduct}=="8184", ENV{ID_MM_ERICSSON_MBM}="1"
# Dell F3307
ATTRS{idVendor}=="413c", ATTRS{idProduct}=="818b", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="413c", ATTRS{idProduct}=="818c", ENV{ID_MM_ERICSSON_MBM}="1"
# HP hs2330 Mobile Broadband Module
ATTRS{idVendor}=="03f0", ATTRS{idProduct}=="271d", ENV{ID_MM_ERICSSON_MBM}="1"
# HP hs2320 Mobile Broadband Module
ATTRS{idVendor}=="03f0", ATTRS{idProduct}=="261d", ENV{ID_MM_ERICSSON_MBM}="1"
# HP hs2340 Mobile Broadband Module
ATTRS{idVendor}=="03f0", ATTRS{idProduct}=="3a1d", ENV{ID_MM_ERICSSON_MBM}="1"
# HP hs2350 Mobile Broadband Module
ATTRS{idVendor}=="03f0", ATTRS{idProduct}=="3d1d", ENV{ID_MM_ERICSSON_MBM}="1"
# HP lc2000 Mobile Broadband Module
ATTRS{idVendor}=="03f0", ATTRS{idProduct}=="301d", ENV{ID_MM_ERICSSON_MBM}="1"
# HP lc2010 Mobile Broadband Module
ATTRS{idVendor}=="03f0", ATTRS{idProduct}=="2f1d", ENV{ID_MM_ERICSSON_MBM}="1"
# Toshiba
ATTRS{idVendor}=="0930", ATTRS{idProduct}=="130b", ENV{ID_MM_ERICSSON_MBM}="1"
# Toshiba F3607gw
ATTRS{idVendor}=="0930", ATTRS{idProduct}=="130c", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0930", ATTRS{idProduct}=="1311", ENV{ID_MM_ERICSSON_MBM}="1"
# Toshiba F3307
ATTRS{idVendor}=="0930", ATTRS{idProduct}=="1315", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0930", ATTRS{idProduct}=="1316", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0930", ATTRS{idProduct}=="1317", ENV{ID_MM_ERICSSON_MBM}="1"
# Toshiba F5521gw
ATTRS{idVendor}=="0930", ATTRS{idProduct}=="1313", ENV{ID_MM_ERICSSON_MBM}="1"
ATTRS{idVendor}=="0930", ATTRS{idProduct}=="1314", ENV{ID_MM_ERICSSON_MBM}="1"
# Toshiba H5321gw
ATTRS{idVendor}=="0930", ATTRS{idProduct}=="1319", ENV{ID_MM_ERICSSON_MBM}="1"
# Lenovo N5321gw
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="193e", ENV{ID_MM_ERICSSON_MBM}="1"
LABEL="mm_mbm_end"
ACTION!="add|change|move", GOTO="mm_huawei_port_types_end"
ENV{ID_VENDOR_ID}!="12d1", GOTO="mm_huawei_port_types_end"
# MU609 does not support getportmode (crashes modem with default firmware)
ATTRS{idProduct}=="1573", ENV{ID_MM_HUAWEI_DISABLE_GETPORTMODE}="1"
# Mark the modem and at port flags for ModemManager
SUBSYSTEMS=="usb", ATTRS{bInterfaceClass}=="ff", ATTRS{bInterfaceSubClass}=="01", ATTRS{bInterfaceProtocol}=="01", ENV{ID_MM_HUAWEI_MODEM_PORT}="1"
SUBSYSTEMS=="usb", ATTRS{bInterfaceClass}=="ff", ATTRS{bInterfaceSubClass}=="01", ATTRS{bInterfaceProtocol}=="02", ENV{ID_MM_HUAWEI_AT_PORT}="1"
SUBSYSTEMS=="usb", ATTRS{bInterfaceClass}=="ff", ATTRS{bInterfaceSubClass}=="02", ATTRS{bInterfaceProtocol}=="01", ENV{ID_MM_HUAWEI_MODEM_PORT}="1"
SUBSYSTEMS=="usb", ATTRS{bInterfaceClass}=="ff", ATTRS{bInterfaceSubClass}=="02", ATTRS{bInterfaceProtocol}=="02", ENV{ID_MM_HUAWEI_AT_PORT}="1"
# GPS NMEA port on MU609
SUBSYSTEMS=="usb", ATTRS{bInterfaceClass}=="ff", ATTRS{bInterfaceSubClass}=="01", ATTRS{bInterfaceProtocol}=="05", ENV{ID_MM_HUAWEI_GPS_PORT}="1"
# GPS NMEA port on MU909
SUBSYSTEMS=="usb", ATTRS{bInterfaceClass}=="ff", ATTRS{bInterfaceSubClass}=="01", ATTRS{bInterfaceProtocol}=="14", ENV{ID_MM_HUAWEI_GPS_PORT}="1"
# Only the standard ECM or NCM port can support dial-up with AT NDISDUP through AT port
SUBSYSTEMS=="usb", ATTRS{bInterfaceClass}=="02", ATTRS{bInterfaceSubClass}=="06",ATTRS{bInterfaceProtocol}=="00", ENV{ID_MM_HUAWEI_NDISDUP_SUPPORTED}="1"
SUBSYSTEMS=="usb", ATTRS{bInterfaceClass}=="02", ATTRS{bInterfaceSubClass}=="0d",ATTRS{bInterfaceProtocol}=="00", ENV{ID_MM_HUAWEI_NDISDUP_SUPPORTED}="1"
LABEL="mm_huawei_port_types_end"
# Longcheer makes modules that other companies rebrand, like:
# Alcatel One Touch X020
# Alcatel One Touch X030
# MobiData MBD-200HU
# ST Mobile Connect HSUPA USB Modem
# Most of these values were scraped from various Longcheer-based Windows
# driver .inf files. cmmdm.inf lists the actual data (ie PPP) ports, while
# cmser.inf lists the aux ports that may be either AT-capable or not but
# cannot be used for PPP.
ACTION!="add|change|move", GOTO="mm_longcheer_port_types_end"
SUBSYSTEM!="tty", GOTO="mm_longcheer_port_types_end"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="1c9e", GOTO="mm_longcheer_vendorcheck"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="1bbb", GOTO="mm_tamobile_vendorcheck"
LABEL="mm_longcheer_vendorcheck"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="3197", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="3197", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="3197", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="6000", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="6000", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="6000", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="6060", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="6060", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="6060", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="6061", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="6061", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="6061", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7001", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7001", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7001", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7001", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7002", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7002", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7002", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7002", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7002", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7101", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7101", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7101", ENV{.MM_USBIFNUM}=="05", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7101", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7102", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7102", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7102", ENV{.MM_USBIFNUM}=="05", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7102", ENV{.MM_USBIFNUM}=="06", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="7102", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8000", ENV{.MM_USBIFNUM}=="05", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8000", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8000", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8000", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8001", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8001", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8001", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8001", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8002", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8002", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8002", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="8002", ENV{ID_MM_LONGCHEER_TAGGED}="1"
# ChinaBird PL68
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9000", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9000", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9000", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9001", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9001", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9001", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9001", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9002", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9002", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9002", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9002", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9003", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9003", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9003", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9003", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9003", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9004", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9004", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9004", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9005", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9005", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9005", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9010", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9010", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9010", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9010", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9012", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9012", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9012", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9012", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9020", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9020", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9020", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9020", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9022", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9022", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9022", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9022", ENV{ID_MM_LONGCHEER_TAGGED}="1"
# Zoom products
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9602", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9602", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9602", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9602", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9603", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9603", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9603", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9603", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9604", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9604", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9604", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9604", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9605", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9605", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9605", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9605", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9605", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9606", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9606", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9606", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9606", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9606", ENV{ID_MM_LONGCHEER_TAGGED}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9607", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9607", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9607", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9607", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9607", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9607", ENV{ID_MM_LONGCHEER_TAGGED}="1"
LABEL="mm_tamobile_vendorcheck"
# Alcatel One Touch X060s
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0000", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_LONGCHEER_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0000", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_LONGCHEER_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0000", ENV{ID_MM_LONGCHEER_TAGGED}="1"
LABEL="mm_longcheer_port_types_end"
ACTION!="add|change|move", GOTO="mm_mtk_port_types_end"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="0e8d", GOTO="mm_mtk_port_types_vendorcheck"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="2001", GOTO="mm_dlink_port_types_vendorcheck"
# MediaTek devices ---------------------------
LABEL="mm_mtk_port_types_vendorcheck"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a1", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_MTK_MODEM_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a1", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_MTK_AT_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a1", ENV{ID_MM_MTK_TAGGED}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a2", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_MTK_MODEM_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a2", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_MTK_AT_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a2", ENV{ID_MM_MTK_TAGGED}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a4", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_MTK_MODEM_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a4", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_MTK_AT_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a4", ENV{ID_MM_MTK_TAGGED}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a5", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_MTK_MODEM_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a5", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_MTK_AT_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a5", ENV{ID_MM_MTK_TAGGED}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a7", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_MTK_MODEM_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a7", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_MTK_AT_PORT}="1"
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="00a7", ENV{ID_MM_MTK_TAGGED}="1"
# D-Link devices ---------------------------
LABEL="mm_dlink_port_types_vendorcheck"
# D-Link DWM-156 A5 (and later?)
ATTRS{idVendor}=="2001", ATTRS{idProduct}=="7d00", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_MTK_MODEM_PORT}="1"
ATTRS{idVendor}=="2001", ATTRS{idProduct}=="7d00", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_MTK_AT_PORT}="1"
ATTRS{idVendor}=="2001", ATTRS{idProduct}=="7d00", ENV{ID_MM_MTK_TAGGED}="1"
LABEL="mm_mtk_port_types_end"
ACTION!="add|change|move", GOTO="mm_nokia_port_types_end"
SUBSYSTEM!="tty", GOTO="mm_nokia_port_types_end"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="0421", GOTO="mm_nokia_port_types_vendorcheck"
LABEL="mm_nokia_port_types_vendorcheck"
# For Nokia Internet Sticks (CS-xx) the modem/PPP port appears to always be USB interface 1
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="060D", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="0611", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="061A", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="061B", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="061F", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="0619", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="0620", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="0623", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="0624", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="0625", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="062A", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="062E", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="062F", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_NOKIA_PORT_TYPE_MODEM}="1"
LABEL="mm_nokia_port_types_end"
ACTION!="add|change|move", GOTO="mm_pcmcia_device_blacklist_end"
SUBSYSTEM!="pcmcia", GOTO="mm_pcmcia_device_blacklist_end"
# Gemplus Serial Port smartcard adapter
ATTRS{prod_id1}=="Gemplus", ATTRS{prod_id2}=="SerialPort", ATTRS{prod_id3}=="GemPC Card", ENV{ID_MM_DEVICE_IGNORE}="1"
LABEL="mm_pcmcia_device_blacklist_end"
ACTION!="add|change|move", GOTO="mm_platform_device_whitelist_end"
SUBSYSTEM!="platform", GOTO="mm_platform_device_whitelist_end"
# Be careful here since many devices connected to platform drivers on PCs
# are legacy devices that won't like probing. But often on embedded
# systems serial ports are provided by platform devices.
# Allow atmel_usart
DRIVERS=="atmel_usart", ENV{ID_MM_PLATFORM_DRIVER_PROBE}="1"
LABEL="mm_platform_device_whitelist_end"
# Simtech makes modules that other companies rebrand, like:
# A-LINK 3GU
# SCT UM300
# Most of these values were scraped from various SimTech-based Windows
# driver .inf files. *mdm.inf lists the main command ports, while
# *ser.inf lists the aux ports that may be used for PPP.
ACTION!="add|change|move", GOTO="mm_simtech_port_types_end"
SUBSYSTEM!="tty", GOTO="mm_simtech_port_types_end"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="1e0e", GOTO="mm_alink_vendorcheck"
LABEL="mm_alink_vendorcheck"
# A-LINK 3GU
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="cefe", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_SIMTECH_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="cefe", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_SIMTECH_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="cefe", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_SIMTECH_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="cefe", ENV{ID_MM_SIMTECH_TAGGED}="1"
# Prolink PH-300
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="9100", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_SIMTECH_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="9100", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_SIMTECH_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="9100", ENV{ID_MM_SIMTECH_TAGGED}="1"
# SCT UM300
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="9200", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_SIMTECH_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="9200", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_SIMTECH_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1e0e", ATTRS{idProduct}=="9200", ENV{ID_MM_SIMTECH_TAGGED}="1"
LABEL="mm_simtech_port_types_end"
ACTION!="add|change|move", GOTO="mm_telit_port_types_end"
SUBSYSTEM!="tty", GOTO="mm_telit_port_types_end"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="1bc7", GOTO="mm_telit_vendorcheck"
LABEL="mm_telit_vendorcheck"
# UC864-E, UC864-E-AUTO, UC864-K, UC864-WD, UC864-WDU
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1003", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_TELIT_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1003", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_TELIT_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1003", ENV{ID_MM_TELIT_TAGGED}="1"
# UC864-G
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1004", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_TELIT_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1004", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_TELIT_PORT_TYPE_NMEA}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1004", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_TELIT_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1004", ENV{ID_MM_TELIT_TAGGED}="1"
# CC864-DUAL
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1005", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_TELIT_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1005", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_TELIT_PORT_TYPE_NMEA}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1005", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_TELIT_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1005", ENV{ID_MM_TELIT_TAGGED}="1"
# CC864-SINGLE, CC864-KPS
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1006", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_TELIT_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1006", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_TELIT_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1006", ENV{ID_MM_TELIT_TAGGED}="1"
# DE910-DUAL
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1010", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_TELIT_PORT_TYPE_NMEA}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1010", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_TELIT_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1010", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_TELIT_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1010", ENV{ID_MM_TELIT_TAGGED}="1"
# CE910-DUAL
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1011", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_TELIT_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bc7", ATTRS{idProduct}=="1011", ENV{ID_MM_TELIT_TAGGED}="1"
# NOTE: Qualcomm Gobi-based devices like the LE920 should not be handled
# by this plugin, but by the Gobi plugin.
LABEL="mm_telit_port_types_end"
ACTION!="add|change|move", GOTO="mm_usb_device_blacklist_end"
SUBSYSTEM!="usb", GOTO="mm_usb_device_blacklist_end"
ENV{DEVTYPE}!="usb_device", GOTO="mm_usb_device_blacklist_end"
# Telegesis zigbee dongle
ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="0003", ENV{ID_MM_DEVICE_IGNORE}="1"
# APC UPS devices
ATTRS{idVendor}=="051d", ENV{ID_MM_DEVICE_IGNORE}="1"
# Sweex 1000VA
ATTRS{idVendor}=="0925", ATTRS{idProduct}=="1234", ENV{ID_MM_DEVICE_IGNORE}="1"
# Agiler UPS
ATTRS{idVendor}=="05b8", ATTRS{idProduct}=="0000", ENV{ID_MM_DEVICE_IGNORE}="1"
# Krauler UP-M500VA
ATTRS{idVendor}=="0001", ATTRS{idProduct}=="0000", ENV{ID_MM_DEVICE_IGNORE}="1"
# Ablerex 625L USB
ATTRS{idVendor}=="ffff", ATTRS{idProduct}=="0000", ENV{ID_MM_DEVICE_IGNORE}="1"
# Belkin F6C1200-UNV
ATTRS{idVendor}=="0665", ATTRS{idProduct}=="5161", ENV{ID_MM_DEVICE_IGNORE}="1"
# Various Liebert and Phoenixtec Power devices
ATTRS{idVendor}=="06da", ENV{ID_MM_DEVICE_IGNORE}="1"
# Unitek Alpha 1200Sx
ATTRS{idVendor}=="0f03", ATTRS{idProduct}=="0001", ENV{ID_MM_DEVICE_IGNORE}="1"
# Various Tripplite devices
ATTRS{idVendor}=="09ae", ENV{ID_MM_DEVICE_IGNORE}="1"
# Various MGE Office Protection Systems devices
ATTRS{idVendor}=="0463", ATTRS{idProduct}=="0001", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="0463", ATTRS{idProduct}=="ffff", ENV{ID_MM_DEVICE_IGNORE}="1"
# CyberPower 900AVR/BC900D
ATTRS{idVendor}=="0764", ATTRS{idProduct}=="0005", ENV{ID_MM_DEVICE_IGNORE}="1"
# CyberPower CP1200AVR/BC1200D
ATTRS{idVendor}=="0764", ATTRS{idProduct}=="0501", ENV{ID_MM_DEVICE_IGNORE}="1"
# Various Belkin devices
ATTRS{idVendor}=="050d", ATTRS{idProduct}=="0980", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="050d", ATTRS{idProduct}=="0900", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="050d", ATTRS{idProduct}=="0910", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="050d", ATTRS{idProduct}=="0912", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="050d", ATTRS{idProduct}=="0551", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="050d", ATTRS{idProduct}=="0751", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="050d", ATTRS{idProduct}=="0375", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="050d", ATTRS{idProduct}=="1100", ENV{ID_MM_DEVICE_IGNORE}="1"
# HP R/T 2200 INTL (like SMART2200RMXL2U)
ATTRS{idVendor}=="03f0", ATTRS{idProduct}=="1f0a", ENV{ID_MM_DEVICE_IGNORE}="1"
# Powerware devices
ATTRS{idVendor}=="0592", ATTRS{idProduct}=="0002", ENV{ID_MM_DEVICE_IGNORE}="1"
# Palm Treo 700/900/etc
# Shouldn't be probed themselves, but you can install programs like
# "MobileStream USB Modem" which changes the USB PID of the device to something
# that isn't blacklisted.
ATTRS{idVendor}=="0830", ATTRS{idProduct}=="0061", ENV{ID_MM_DEVICE_IGNORE}="1"
# GlobalScaleTechnologies SheevaPlug
ATTRS{idVendor}=="9e88", ATTRS{idProduct}=="9e8f", ENV{ID_MM_DEVICE_IGNORE}="1"
# Atmel Corp at91sam SAMBA bootloader
ATTRS{idVendor}=="03eb", ATTRS{idProduct}=="6124", ENV{ID_MM_DEVICE_IGNORE}="1"
# Dangerous Prototypes Bus Pirate v4
ATTRS{idVendor}=="04d8", ATTRS{idProduct}=="fb00", ENV{ID_MM_DEVICE_IGNORE}="1"
# All devices from the Swiss Federal Institute of Technology
ATTRS{idVendor}=="0617", ENV{ID_MM_DEVICE_IGNORE}="1"
# West Mountain Radio devices
ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="814a", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="814b", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="2405", ATTRS{idProduct}=="0003", ENV{ID_MM_DEVICE_IGNORE}="1"
# Arduinos
ATTRS{idVendor}=="2341", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="1b4f", ATTRS{idProduct}=="9207", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="1b4f", ATTRS{idProduct}=="9208", ENV{ID_MM_DEVICE_IGNORE}="1"
# Adafruit Flora
ATTRS{idVendor}=="239a", ATTRS{idProduct}=="0004", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="239a", ATTRS{idProduct}=="8004", ENV{ID_MM_DEVICE_IGNORE}="1"
# All devices from Pololu Corporation
# except some possible future products.
ATTRS{idVendor}=="1ffb", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="1ffb", ATTRS{idProduct}=="00ad", ENV{ID_MM_DEVICE_IGNORE}="0"
ATTRS{idVendor}=="1ffb", ATTRS{idProduct}=="00ae", ENV{ID_MM_DEVICE_IGNORE}="0"
# Altair U-Boot device
ATTRS{idVendor}=="0216", ATTRS{idProduct}=="0051", ENV{ID_MM_DEVICE_IGNORE}="1"
# Bluegiga BLE112B
ATTRS{idVendor}=="2458", ATTRS{idProduct}=="0001", ENV{ID_MM_DEVICE_IGNORE}="1"
# Analog Devices BLIP camera
ATTRS{idVendor}=="064b", ATTRS{idProduct}=="7823", ENV{ID_MM_DEVICE_IGNORE}="1"
# MediaTek GPS chip (HOLUX M-1200E, GlobalTop Gms-d1, etc)
ATTRS{idVendor}=="0e8d", ATTRS{idProduct}=="3329", ENV{ID_MM_DEVICE_IGNORE}="1"
# PS-360 OEM (GPS sold with MS Street and Trips 2005)
ATTRS{idVendor}=="067b", ATTRS{idProduct}=="aaa0", ENV{ID_MM_DEVICE_IGNORE}="1"
# u-blox AG, u-blox 5 GPS chips
ATTRS{idVendor}=="1546", ATTRS{idProduct}=="01a5", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="1546", ATTRS{idProduct}=="01a6", ENV{ID_MM_DEVICE_IGNORE}="1"
# Garmin GPS devices
DRIVERS=="garmin_gps", ENV{ID_MM_DEVICE_IGNORE}="1"
# Cypress M8-based GPS devices, UPSes, and serial converters
DRIVERS=="cypress_m8", ENV{ID_MM_DEVICE_IGNORE}="1"
# All devices in the Openmoko vendor ID
ATTRS{idVendor}=="1d50", ENV{ID_MM_DEVICE_IGNORE}="1"
# All devices from 3D Robotics
ATTRS{idVendor}=="26ac", ENV{ID_MM_DEVICE_IGNORE}="1"
# empiriKit science lab controller device
ATTRS{idVendor}=="0425", ATTRS{idProduct}=="0408", ENV{ID_MM_DEVICE_IGNORE}="1"
# Infineon Flashloader used by Intel XMM modem bootloader
ATTRS{idVendor}=="8087", ATTRS{idProduct}=="0716", ENV{ID_MM_DEVICE_IGNORE}="1"
LABEL="mm_usb_device_blacklist_end"
ACTION!="add|change|move", GOTO="mm_usb_serial_adapters_greylist_end"
SUBSYSTEM!="usb", GOTO="mm_usb_serial_adapters_greylist_end"
ENV{DEVTYPE}!="usb_device", GOTO="mm_usb_serial_adapters_greylist_end"
# Belkin F5U183 Serial Adapter
ATTRS{idVendor}=="050d", ATTRS{idProduct}=="0103", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
# FTDI-based serial adapters
# FTDI does USB to serial converter ICs; and it's very likely that they'll
# never do modems themselves, so it should be safe to add a rule only based
# on the vendor Id.
ATTRS{idVendor}=="0403", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
# ATEN Intl UC-232A (Prolific)
ATTRS{idVendor}=="0557", ATTRS{idProduct}=="2008", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
# Prolific USB to Serial adapter
ATTRS{idVendor}=="067b", ATTRS{idProduct}=="2303", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
# Magic Control Technology Corp adapters
ATTRS{idVendor}=="0711", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
# Cygnal Integrated Products, Inc. CP210x
ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea71", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
# QinHeng Electronics HL-340
ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
# Atmel Corp. LUFA USB to Serial Adapter Project (Arduino)
ATTRS{idVendor}=="03eb", ATTRS{idProduct}=="204b", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
# Netchip Technology, Inc. Linux-USB Serial Gadget (CDC ACM mode)
ATTRS{idVendor}=="0525", ATTRS{idProduct}=="a4a7", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
LABEL="mm_usb_serial_adapters_greylist_end"
# Alcatel One Touch X220D
# Alcatel One Touch X200
# These values were scraped from the X220D's Windows .inf files. jrdmdm.inf
# lists the actual command and data (ie PPP) ports, while jrdser.inf lists the
# aux ports that may be either AT-capable or not but cannot be used for PPP.
ACTION!="add|change|move", GOTO="mm_x22x_port_types_end"
SUBSYSTEM!="tty", GOTO="mm_x22x_port_types_end"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="1bbb", GOTO="mm_x22x_generic_vendorcheck"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="0b3c", GOTO="mm_x22x_olivetti_vendorcheck"
# Generic JRD devices ---------------------------
LABEL="mm_x22x_generic_vendorcheck"
# Alcatel X200
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0000", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_X22X_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0000", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0000", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0000", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0000", ENV{ID_MM_X22X_TAGGED}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0017", ENV{.MM_USBIFNUM}=="05", ENV{ID_MM_X22X_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0017", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0017", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0017", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0017", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="0017", ENV{ID_MM_X22X_TAGGED}="1"
# Archos G9
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="00B7", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_X22X_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="00B7", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="00B7", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_X22X_PORT_TYPE_NMEA}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="00B7", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_X22X_PORT_TYPE_VOICE}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="00B7", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="1bbb", ATTRS{idProduct}=="00B7", ENV{ID_MM_X22X_TAGGED}="1"
# Olivetti devices ---------------------------
LABEL="mm_x22x_olivetti_vendorcheck"
# Olicard 200
ATTRS{idVendor}=="0b3c", ATTRS{idProduct}=="c005", ENV{.MM_USBIFNUM}=="05", ENV{ID_MM_X22X_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="0b3c", ATTRS{idProduct}=="c005", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="0b3c", ATTRS{idProduct}=="c005", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="0b3c", ATTRS{idProduct}=="c005", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="0b3c", ATTRS{idProduct}=="c005", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="0b3c", ATTRS{idProduct}=="c005", ENV{.MM_USBIFNUM}=="06", ENV{ID_MM_X22X_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="0b3c", ATTRS{idProduct}=="c005", ENV{ID_MM_X22X_TAGGED}="1"
LABEL="mm_x22x_port_types_end"
ACTION!="add|change|move", GOTO="mm_zte_port_types_end"
SUBSYSTEM!="tty", GOTO="mm_zte_port_types_end"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="19d2", GOTO="mm_zte_port_types_vendorcheck"
LABEL="mm_zte_port_types_vendorcheck"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0001", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0001", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0002", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0002", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0003", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0003", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0004", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0004", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0005", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0005", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0006", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0006", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0007", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0007", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0008", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0008", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0009", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0009", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="000A", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="000A", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0012", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0012", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0015", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0015", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0016", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0016", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0017", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0017", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0018", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0018", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0019", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0019", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0021", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0021", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0024", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0024", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0025", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0025", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0030", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0030", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0031", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0031", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0033", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0033", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0037", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0037", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0039", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0039", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0042", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0042", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0043", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0043", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0048", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0048", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0049", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0049", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0052", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0052", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0054", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0054", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0055", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0055", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0057", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0057", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0058", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0058", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0061", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0061", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0063", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0063", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0064", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0064", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0066", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0066", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0078", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0078", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0082", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0082", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0091", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0091", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0104", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0104", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0106", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0106", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0108", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0108", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0113", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0113", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0117", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0117", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0118", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0118", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0121", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0121", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0122", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0122", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0123", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0123", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0124", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0124", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0125", ENV{.MM_USBIFNUM}=="05", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0125", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0126", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0126", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0128", ENV{.MM_USBIFNUM}=="04", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="0128", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1007", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1007", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1008", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1008", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1010", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1010", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1254", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1254", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1515", ENV{.MM_USBIFNUM}=="00", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="1515", ENV{.MM_USBIFNUM}=="02", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="2002", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="2002", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="2003", ENV{.MM_USBIFNUM}=="03", ENV{ID_MM_ZTE_PORT_TYPE_MODEM}="1"
ATTRS{idVendor}=="19d2", ATTRS{idProduct}=="2003", ENV{.MM_USBIFNUM}=="01", ENV{ID_MM_ZTE_PORT_TYPE_AUX}="1"
# Icera-based devices that use DHCP, not AT%IPDPADDR
ATTRS{product}=="K3805-z", ENV{ID_MM_ZTE_ICERA_DHCP}="1"
LABEL="mm_zte_port_types_end"
# Tag any devices that MM might be interested in; if ModemManager is started
# up right after udev, when MM explicitly requests devices on startup it may
# get devices that haven't had all rules run yet. Thus, we tag devices we're
# interested in and when handling devices during MM startup we ignore any
# that don't have this tag. MM will still get the udev 'add' event for the
# device a short while later and then process it as normal.
ACTION!="add|change|move|bind", GOTO="mm_candidate_end"
# Opening bound but disconnected Bluetooth RFCOMM ttys would initiate the
# connection. Don't do that.
KERNEL=="rfcomm*", DEVPATH=="*/virtual/*", GOTO="mm_candidate_end"
SUBSYSTEM=="tty", ENV{ID_MM_CANDIDATE}="1"
SUBSYSTEM=="net", ENV{ID_MM_CANDIDATE}="1"
KERNEL=="cdc-wdm[0-9]*", SUBSYSTEM=="usb", ENV{ID_MM_CANDIDATE}="1"
KERNEL=="cdc-wdm[0-9]*", SUBSYSTEM=="usbmisc", ENV{ID_MM_CANDIDATE}="1"
# WWAN subsystem port handling
# - All USB devices ignored for now, only PCI devices expected
# - Only "wwan_port" device types processed (single ports); we fully ignore
# the "wwan_dev" device type (full device, not just one port)
SUBSYSTEMS=="usb", GOTO="mm_candidate_end"
SUBSYSTEM=="wwan", ENV{DEVTYPE}=="wwan_dev", GOTO="mm_candidate_end"
SUBSYSTEM=="wwan", ENV{ID_MM_CANDIDATE}="1"
SUBSYSTEM=="wwan", KERNEL=="*MBIM", ENV{ID_MM_PORT_TYPE_MBIM}="1"
SUBSYSTEM=="wwan", KERNEL=="*QMI", ENV{ID_MM_PORT_TYPE_QMI}="1"
SUBSYSTEM=="wwan", KERNEL=="*AT", ENV{ID_MM_PORT_TYPE_AT_PRIMARY}="1"
SUBSYSTEM=="wwan", KERNEL=="*QCDM", ENV{ID_MM_PORT_TYPE_QCDM}="1"
LABEL="mm_candidate_end"
## Concatenation of all ofono udev rules (plugins/*.rules in ofono sources)
## Note that ofono uses this for very few modems and that in most cases it finds
## modems by checking directly in code udev events, so changes here will be rare
## plugins/ofono.rules
ACTION!="add|change", GOTO="ofono_end"
# ISI/Phonet drivers
SUBSYSTEM!="net", GOTO="ofono_isi_end"
ATTRS{type}!="820", GOTO="ofono_isi_end"
KERNELS=="gadget", GOTO="ofono_isi_end"
# Nokia N900 modem
SUBSYSTEMS=="hsi", ENV{OFONO_DRIVER}="n900", ENV{OFONO_ISI_ADDRESS}="108"
KERNEL=="phonet*", ENV{OFONO_DRIVER}="n900", ENV{OFONO_ISI_ADDRESS}="108"
# STE u8500
KERNEL=="shrm0", ENV{OFONO_DRIVER}="u8500"
LABEL="ofono_isi_end"
SUBSYSTEM!="usb", GOTO="ofono_end"
ENV{DEVTYPE}!="usb_device", GOTO="ofono_end"
# Ignore fake serial number
ATTRS{serial}=="1234567890ABCDEF", ENV{ID_SERIAL_SHORT}=""
# Nokia CDMA Device
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="023e", ENV{OFONO_DRIVER}="nokiacdma"
ATTRS{idVendor}=="0421", ATTRS{idProduct}=="00b6", ENV{OFONO_DRIVER}="nokiacdma"
# Lenovo H5321gw 0bdb:1926
ATTRS{idVendor}=="0bdb", ATTRS{idProduct}=="1926", ENV{OFONO_DRIVER}="mbm"
LABEL="ofono_end"
## plugins/ofono-speedup.rules
ACTION!="add|change", GOTO="ofono_speedup_end"
SUBSYSTEM!="tty", GOTO="ofono_speedup_end"
KERNEL!="ttyUSB[0-9]*", GOTO="ofono_speedup_end"
# SpeedUp 7300
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9e00", ENV{ID_USB_INTERFACE_NUM}=="00", ENV{OFONO_LABEL}="modem"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9e00", ENV{ID_USB_INTERFACE_NUM}=="03", ENV{OFONO_LABEL}="aux"
# SpeedUp
ATTRS{idVendor}=="2020", ATTRS{idProduct}=="1005", ENV{ID_USB_INTERFACE_NUM}=="03", ENV{OFONO_LABEL}="modem"
ATTRS{idVendor}=="2020", ATTRS{idProduct}=="1005", ENV{ID_USB_INTERFACE_NUM}=="01", ENV{OFONO_LABEL}="aux"
ATTRS{idVendor}=="2020", ATTRS{idProduct}=="1008", ENV{ID_USB_INTERFACE_NUM}=="03", ENV{OFONO_LABEL}="modem"
ATTRS{idVendor}=="2020", ATTRS{idProduct}=="1008", ENV{ID_USB_INTERFACE_NUM}=="01", ENV{OFONO_LABEL}="aux"
# SpeedUp 9800
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9800", ENV{ID_USB_INTERFACE_NUM}=="01", ENV{OFONO_LABEL}="modem"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9800", ENV{ID_USB_INTERFACE_NUM}=="02", ENV{OFONO_LABEL}="aux"
# SpeedUp U3501
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9605", ENV{ID_USB_INTERFACE_NUM}=="03", ENV{OFONO_LABEL}="modem"
ATTRS{idVendor}=="1c9e", ATTRS{idProduct}=="9605", ENV{ID_USB_INTERFACE_NUM}=="01", ENV{OFONO_LABEL}="aux"
LABEL="ofono_speedup_end"
ACTION=="change", SUBSYSTEM=="power_supply", RUN+="/usr/share/slimbookbattery/src/ac_power.py"
so nothing related to nvidia… those were the last places i knew where there could something be…
the last option is the apparmor … do you use snap? if yes post output from:
snap list
I dont use snap much, as i am new to linux as a whole, so i mainly use the add/remove software program included in manjaro.
Here’s the output from the snap list
command:
Name Version Rev Tracking Publisher Notes
auto-cpufreq 1.9.6 122 latest/stable fooctrl -
core18 20220831 2566 latest/stable canonical✓ base
core22 20220706 275 latest/stable canonical✓ base
exercism SNAPSHOT-ba48dcd 5 latest/stable exercism -
snapd 2.57.2 17029 latest/stable canonical✓ snapd
@newtom Well another idea would be:
That method pretends to the UEFI that it is Windows by the OSI Parameter. Some UEFIs don’t work well, if they get to know that the OS is not Windows.
so try to remove this:
auto-cpufreq
reboot
does this acpi affects only installed systems? since the nvidia is detected in the live usb?
In general no, but who knows? UEFIs are closed and proprietary, so a blackbox.
I cannot see where @newtom said, that it worked on Live Session. Can you link it?
we tried the live usb above to rule out that the nvidia is dead:
Ok, i removed the auto-cpufreq
and rebooted, what now?
check if nvidia is detected: inxi -G
for example…
i wanted you to suggest to try the acpi parameter, for example try this:
acpi_osi='Windows 2017'
follow the instruction from the link on how to add it to grub and before you reboot post also output of this:
grep installed /var/log/pacman.log | tail -50
Ok, i checked inxi -G
and it is still not detected, i also ran the grep installed /var/log/pacman.log | tail -50
and here’s the output:
[2022-09-18T23:44:12-0300] [ALPM] installed torsocks (2.3.0-2)
[2022-09-21T16:01:36-0300] [ALPM] reinstalled lightdm (1:1.32.0-4)
[2022-09-21T16:09:03-0300] [ALPM] installed gnome-backgrounds (42.0-1)
[2022-09-21T16:09:03-0300] [ALPM] installed lightdm-webkit2-greeter (2.2.5-6)
[2022-09-26T09:12:42-0300] [ALPM] installed xf86-video-ati (1:19.1.0.r15.g7a6a34af-1)
[2022-09-26T09:12:42-0300] [ALPM] installed xf86-video-amdgpu (22.0.0-1)
[2022-09-26T09:12:42-0300] [ALPM] installed vulkan-intel (22.1.7-1)
[2022-09-26T09:12:42-0300] [ALPM] installed vulkan-radeon (22.1.7-1)
[2022-09-26T09:12:43-0300] [ALPM] installed mesa-vdpau (22.1.7-1)
[2022-09-26T09:12:43-0300] [ALPM] installed lib32-libtirpc (1.3.3-1)
[2022-09-26T09:12:43-0300] [ALPM] installed lib32-pam (1.5.2-1)
[2022-09-26T09:12:43-0300] [ALPM] installed lib32-libcap (2.65-1)
[2022-09-26T09:12:43-0300] [ALPM] installed lib32-libgcrypt (1.10.1-1)
[2022-09-26T09:12:43-0300] [ALPM] installed lib32-systemd (251.4-1.1)
[2022-09-26T09:12:43-0300] [ALPM] installed lib32-vulkan-intel (22.1.7-1)
[2022-09-26T09:12:43-0300] [ALPM] installed lib32-vulkan-radeon (22.1.7-1)
[2022-09-26T09:12:43-0300] [ALPM] installed lib32-mesa-vdpau (22.1.7-1)
[2022-09-26T10:18:28-0300] [ALPM] reinstalled python-pip (22.2.2-2)
[2022-09-26T10:18:34-0300] [ALPM] installed tk (8.6.12-1)
[2022-09-26T10:35:56-0300] [ALPM] installed isw (1.10-1)
[2022-09-26T10:59:28-0300] [ALPM] installed pahole (1:1.23-1)
[2022-09-26T10:59:29-0300] [ALPM] installed linux419-headers (4.19.257-1)
[2022-09-26T10:59:29-0300] [ALPM] installed dkms (3.0.6-1)
[2022-09-26T11:06:08-0300] [ALPM] reinstalled acpi (1.7-3)
[2022-09-26T11:08:37-0300] [ALPM] reinstalled linux419-headers (4.19.257-1)
[2022-09-26T11:08:37-0300] [ALPM] reinstalled dkms (3.0.6-1)
[2022-09-26T11:09:21-0300] [ALPM] reinstalled linux419-headers (4.19.257-1)
[2022-09-26T11:09:21-0300] [ALPM] reinstalled dkms (3.0.6-1)
[2022-09-26T11:10:05-0300] [ALPM] reinstalled linux419-headers (4.19.257-1)
[2022-09-26T11:10:05-0300] [ALPM] reinstalled dkms (3.0.6-1)
[2022-09-28T19:51:53-0300] [ALPM] installed libgdiplus (5.6.1-3)
[2022-09-28T19:51:54-0300] [ALPM] installed mono (6.12.0.177-1)
[2022-09-28T19:51:54-0300] [ALPM] installed nuget (5.10.0-1)
[2022-09-28T19:52:59-0300] [ALPM] installed nbfc (1.6.3-3)
[2022-09-28T20:15:30-0300] [ALPM] reinstalled lm_sensors (1:3.6.0.r41.g31d1f125-1)
[2022-09-29T00:14:04-0300] [ALPM] installed python2 (2.7.18-5)
[2022-09-29T00:14:04-0300] [ALPM] installed python2-setuptools (2:44.1.1-2)
[2022-09-29T00:14:04-0300] [ALPM] installed gcc-fortran (12.2.0-1)
[2022-09-29T00:14:04-0300] [ALPM] installed xorg-xdriinfo (1.0.6-3)
[2022-09-29T00:17:11-0300] [ALPM] installed cython2 (0.29.32-2)
[2022-09-29T00:23:45-0300] [ALPM] installed libglade (2.6.4-8)
[2022-09-29T00:23:45-0300] [ALPM] installed python2-cairo (1.18.2-4)
[2022-09-29T00:23:46-0300] [ALPM] installed python2-numpy (1.16.6-2)
[2022-09-29T00:23:46-0300] [ALPM] installed python2-gobject2 (2.28.7-7)
[2022-09-29T00:26:09-0300] [ALPM] installed pygtk (2.24.0-12)
[2022-09-29T00:26:24-0300] [ALPM] installed driconf (0.9.1-14)
[2022-09-29T00:26:37-0300] [ALPM] installed prime-gpuchooser (r10.26a36a6-1)
[2022-09-29T00:29:11-0300] [ALPM] installed prime (1.0-14)
[2022-09-29T14:12:02-0300] [ALPM] installed prime-switcher (1.0.2-1)
[2022-09-29T14:12:55-0300] [ALPM] reinstalled prime-switcher (1.0.2-1)
