I tried propierty and open source drivers. It crashes after install now. I redownloaded the iso and reflashed it 3 times nothing. It has eMMc and it crashes after I select erase disk.
With a recent change to the Calamares installer and the general size of the ISO the system requirements is at least 4G RAM
Most likely the new dynamic slideshow we added doesn’t work on your PC. You can try the older Ruah ISOs and see if that changes things.
It worked! Thank you.
Assuming the earlier ISO solved it?
