I’m trying to install Manjaro on an ssd drive (oczssdpx-1rvd0180), but my drive shows up as two 83.84 GiB drives, with the first (/dev/sdd) having partitions on that drive, and the second (/dev/sde) nothing.
if I write sudo dmraid -a y the partitions appear in Dolphin (displayed as dm-1 and dm-2), the path for example is /run/media/manjaro/BAA212D3A21293CB/. Below is the result of the command.
RAID set "sil_acaeahbifeca" was activated
RAID set "sil_acaeahbifecap1" was activated
RAID set "sil_acaeahbifecap2" was activated
But the installer still does not have a full disk
sudo fdisk -l
Disk /dev/sdd: 83,85 GiB, 90028302336 bytes, 175836528 sectors
Disk model: OCZ-REVODRIVE
Disklabel type: dos
Disk identifier: 0x237287e0
Device Boot Start End Sectors Size Id Type
/dev/sdd1 * 2048 350598640 350596593 167,2G 7 HPFS/NTFS/exFAT
/dev/sdd2 350599168 351664127 1064960 520M 27 Hidden NTFS WinRE
Disk /dev/sde: 83,85 GiB, 90028302336 bytes, 175836528 sectors
Disk /dev/mapper/sil_acaeahbifeca: 167,69 GiB, 180054392832 bytes, 351668736 sectors
I/O size (minimum/optimal): 65536 bytes / 131072 bytes
Disklabel type: dos
/dev/mapper/sil_acaeahbifecap1 * 2048 350598640 350596593 167,2G 7 HPFS/NTFS/exFAT
/dev/mapper/sil_acaeahbifecap2 350599168 351664127 1064960 520M 27 Hidden NTFS WinRE
Disk /dev/mapper/sil_acaeahbifecap1: 167,18 GiB, 179505455616 bytes, 350596593 sectors
Disklabel type: dos
Disk identifier: 0x73736572
/dev/mapper/sil_acaeahbifecap1-part1 1920221984 3736432267 1816210284 866G 72 unknown
/dev/mapper/sil_acaeahbifecap1-part2 1936028192 3889681299 1953653108 931,6G 6c unknown
/dev/mapper/sil_acaeahbifecap1-part3 0 0 0 0B 0 Empty
/dev/mapper/sil_acaeahbifecap1-part4 27722122 27722568 447 223,5K 0 Empty
Partition 1 does not start on physical sector boundary.
Partition 2 does not start on physical sector boundary.
Partition 4 does not start on physical sector boundary.
Partition table entries are not in disk order.
Disk /dev/mapper/sil_acaeahbifecap2: 520 MiB, 545259520 bytes, 1064960 sectors
Disklabel type: dos
/dev/mapper/sil_acaeahbifecap2-part1 1920221984 3736432267 1816210284 866G 72 unknown
/dev/mapper/sil_acaeahbifecap2-part2 1936028192 3889681299 1953653108 931,6G 6c unknown
/dev/mapper/sil_acaeahbifecap2-part3 0 0 0 0B 0 Empty
/dev/mapper/sil_acaeahbifecap2-part4 27722122 27722568 447 223,5K 0 Empty
blkid
/dev/sde: TYPE="silicon_medley_raid_member"
/dev/sda1: BLOCK_SIZE="512" UUID="AAF0005BF000305D" TYPE="ntfs" PARTUUID="c42ca7b2-01"
/dev/sda2: LABEL_FATBOOT="NO_LABEL" LABEL="EFI" UUID="C420-8D12" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="c42ca7
b2-02"
/dev/sdb1: BLOCK_SIZE="512" UUID="A8660B12660AE0C4" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="c67
686e2-60a5-4334-b568-358a88fc34bc"
/dev/loop1: TYPE="squashfs"
/dev/mapper/sil_acaeahbifecap1: BLOCK_SIZE="512" UUID="BAA212D3A21293CB" TYPE="ntfs"
/dev/loop2: TYPE="squashfs"
/dev/mapper/sil_acaeahbifecap2: BLOCK_SIZE="512" UUID="3C30BC5A30BC1CB8" TYPE="ntfs"
/dev/loop0: TYPE="squashfs"
/dev/sdc2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="3F87-ED74" BLOCK_SIZE="512" TYPE="
vfat"
/dev/sdc1: BLOCK_SIZE="2048" UUID="2022-07-21-09-20-14-00" LABEL="MANJARO_KDE_2135" TYPE="iso9660"
/dev/loop3: TYPE="squashfs"
What needs to be done to install Manjaro on such a drive?
