I am trying to install deepin-music on manjaro linux, but it does not seem to run.
OS: Manjaro Linux x86_64
Kernel: 6.6.10-1-MANJARO
CPU: AMD Ryzen 7 7700X (16) @ 5.573GHz
GPU: AMD ATI 10:00.0 Raphael
GPU: NVIDIA GeForce RTX 4060 Ti 16GB
deepin-music 7.0.3-2
OBSERVED RESULT
it shows this error when I run it from the terminal
deepin-music: symbol lookup error: /usr/lib/libdmusic.so.1.0: undefined symbol: ucsdet_close_73
Teo
6 February 2024 23:44
2
Since this library is part of the same package and it is directly taken from arch, it will make more sense to file a bug report at the deepin github or write the packager A.Rojas. Does not seem like a manjaro problem to me.
cscs
6 February 2024 23:54
3
After quick install it ran here (on Unstable branch).
So I must assume that the next version will work for you.
https://packages.manjaro.org/?query=deepin-music
I have written there as well. still waiting for a reply.
Ditch Deepin Music, go QuodLibet, it’s gapless
https://packages.manjaro.org/?query=quodlibet
Nonetheless, i installed deepin music about 3 weeks ago, without issue either
