Manjaro Installation Failed
Hello, I’ve just got my laptop and I can’t install Manjaro Kde… it won’t create a partition neither with Delete Disks nor with Manual Partitioning(Even if I manually allocate it won’t let me go to the user credentials)
I’ve tried with other file types (ext4 and the other) still the same error…
Do you guys know a fix for this? :sweat_smile:
Might be related to this thread
Probably, I installed xfce and I didn’t encounter this error with ext4 so probably it’s because of Plasma
Yep, it works now
Apparently the issue is fixed in the latest version of calamares so hopefully the team will release a new iso soon or someone more knowledgeable than me knows a work around
