Hello I just have installed Manjaro on Acer Chromebook R11, and It works really better, all drivers recognized, but I have little issue on audio driver.
I first tryed with plasma, and I gone to xfce and the same issue ocours.
The audio works without any trouble but the optput goes to the headphones and to the speakers in same time how to solve this issue.
In old UCM drivers is possible enable the internal jack switch but in this new version UCM2, It don`t work.
Here old ucm hifi.conf
# command-line sequence to switch playback/capture
# alsaucm -c chtmax98090 set _verb HiFi set _enadev Headphone
# alsaucm -c chtmax98090 set _verb HiFi set _enadev Speakers
# alsaucm -c chtmax98090 set _verb HiFi set _enadev HeadsetMic
# alsaucm -c chtmax98090 set _verb HiFi set _enadev InternalMic
SectionVerb {
EnableSequence [
cdev "hw:chtmax98090"
# media mixer settings
# compress
cset "name='media0_in Gain 0 Switch' on"
cset "name='media0_in Gain 0 Volume' 0"
# normal
cset "name='media1_in Gain 0 Switch' on"
cset "name='media1_in Gain 0 Volume' 0"
# deep buffer
cset "name='media3_in Gain 0 Switch' on"
cset "name='media3_in Gain 0 Volume' 0"
cset "name='media0_out mix 0 media0_in Switch' on"
cset "name='media0_out mix 0 media1_in Switch' on"
cset "name='media0_out mix 0 media2_in Switch' off"
cset "name='media0_out mix 0 media3_in Switch' on"
cset "name='pcm0_in Gain 0 Switch' on"
cset "name='pcm0_in Gain 0 Volume' 0"
cset "name='pcm1_in Gain 0 Switch' off"
cset "name='pcm1_in Gain 0 Volume' 0%"
# codec0_out settings (used if ssp2 is connected to aif1)
cset "name='codec_out0 mix 0 pcm0_in Switch' on"
cset "name='codec_out0 Gain 0 Switch' on"
cset "name='codec_out0 Gain 0 Volume' 0"
# input settings
# pcm1_out settings
# input used when SSP2 is connected
cset "name='codec_in0 Gain 0 Switch' on"
cset "name='codec_in0 Gain 0 Volume' 7"
cset "name='pcm1_out mix 0 codec_in0 Switch' on"
cset "name='pcm1_out Gain 0 Switch' on"
cset "name='pcm1_out Gain 0 Volume' 7"
cset "name='Left Speaker Mixer Left DAC Switch' on"
cset "name='Right Speaker Mixer Right DAC Switch' on"
cset "name='Digital EQ 3 Band Switch' off"
cset "name='Digital EQ 5 Band Switch' off"
cset "name='Digital EQ 7 Band Switch' off"
cset "name='Biquad Switch' off"
cset "name='Filter Mode' Music"
cset "name='ADC Oversampling Rate' 0"
cset "name='DMIC Mux' DMIC"
cset "name='MIC2 Mux' IN34"
cset "name='MIC2 Volume' 10"
cset "name='MIC2 Boost Volume' 0"
cset "name='ADCR Boost Volume' 5"
cset "name='ADCL Boost Volume' 5"
cset "name='ADCR Volume' 13"
cset "name='ADCL Volume' 13"
cset "name='Headphone Volume' 22"
cset "name='Speaker Volume' 220"
cset "name='Speaker Left Mixer Volume' 7"
cset "name='Speaker Right Mixer Volume' 7"
cset "name='Record Path DC Blocking' on"
cset "name='Playback Path DC Blocking' on"
cset "name='Headphone Left Switch' on"
cset "name='Headphone Right Switch' on"
cset "name='Headphone Switch' on"
cset "name='Speaker Left Switch' off"
cset "name='Speaker Right Switch' off"
cset "name='Ext Spk Switch' off"
cset "name='Headset Mic Switch' off"
cset "name='Int Mic Switch' off"
DisableSequence [
# ALSA PCM
Value {
# ALSA PCM device for HiFi
PlaybackPCM "hw:chtmax98090"
CapturePCM "hw:chtmax98090"
SectionDevice."Headphone" {
Comment "Headphone"
ConflictingDevice [
"Speakers"
Value {
JackControl "Headphone Jack"
JackHWMute "Speakers"
EnableSequence [
DisableSequence [
cset "name='Headphone Left Switch' off"
cset "name='Headphone Right Switch' off"
cset "name='Headphone Switch' off"
Value {
PlaybackChannels 2
SectionDevice."Speakers" {
Comment "Speakers"
ConflictingDevice [
"Headphone"
EnableSequence [
cset "name='Speaker Left Switch' on"
cset "name='Speaker Right Switch' on"
cset "name='Ext Spk Switch' on"
DisableSequence [
Value {
PlaybackChannels 2
SectionDevice."HeadsetMic" {
Comment "Headset Mic"
Value {
JackControl "Headset Mic Jack"
#FIXME CaptureControl "MIC2"
ConflictingDevice [
"InternalMic"
EnableSequence [
cset "name='Headset Mic Switch' on"
cset "name='DMIC Mux' ADC"
DisableSequence [
cset "name='Record Path DC Blocking' off"
Value {
CaptureChannels 2
SectionDevice."InternalMic" {
Comment "Internal Mic"
Value {
ConflictingDevice [
"HeadsetMic"
EnableSequence [
cset "name='Int Mic Switch' on"
DisableSequence [
Value {
CaptureChannels 2
