Hello,
I am in the process of setting up a dual boot of Windows 11 and Manjaro i3, on a Lenovo T14 Gen 3, (AMD). I have scoured the internet searching for solutions, but haven’t found one yet. Some help would be much appreciated!
Here is the output of inxi -Fazy
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3afe7222-2920-4bf6-8be4-c4553bc4458b rw quiet apparmor=1
Desktop: i3 v: 4.21 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 21CF003YUS v: ThinkPad T14 Gen 3
Mobo: LENOVO model: 21CF003YUS v: ThinkPad serial: <superuser required>
UEFI: LENOVO v: R23ET60W (1.30 ) date: 09/14/2022
ID-1: BAT0 charge: 39.3 Wh (100.0%) condition: 39.3/39.3 Wh (100.0%)
volts: 13.3 min: 11.6 model: LGES LNV-5B10W51860Àà type: Li-poly
serial: <filter> status: full cycles: 3
Info: model: AMD Ryzen 7 PRO 6850U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1742 high: 2314 min/max: 1600/4767 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1801 2: 2094
3: 1735 4: 1428 5: 2314 6: 1509 7: 1414 8: 1551 9: 1366 10: 1552 11: 1825
12: 1805 13: 1747 14: 2096 15: 1548 16: 2095 bogomips: 86258
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 45.0 C
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 5-1:2 chip-ID: 174f:1812 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-7e568
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 mapped: eDP model-id: CTO 0x1416 built: 2020
res: 1920x1200 hz: 60 dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4")
diag: 355mm (14") ratio: 16:10 modes: max: 1920x1200 min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: no
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: N/A modules: ath11k_pci pcie: gen: 2 speed: 5 GT/s lanes: 1
link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 17cb:1103
class-ID: 0280
Device-1: USI type: USB driver: btusb v: 0.8 bus-ID: 1-3.1:3
chip-ID: 10ab:9309 class-ID: e001
Local Storage: total: 953.87 GiB used: 9.73 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk
model: SKHynix HFS001TEJ9X102N size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 51720A10 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 732.42 GiB size: 719.86 GiB (98.28%) used: 9.7 GiB (1.3%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 33.3 MiB
(13.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): fan-1: 0
Processes: 289 Uptime: 57m wakeups: 5906 Memory: 30.13 GiB used: 1.49 GiB
(4.9%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1103 libs: 330
tools: pamac,yay Shell: Bash v: 5.1.16 running-in: urxvtd inxi: 3.3.22
Here is the output of uname -a
Linux rolandT14 5.15.74-3-MANJARO #1 SMP PREEMPT Sat Oct 15 13:39:11 UTC 2022 x86_64 GNU/Linux
I have installed the proper Linux headers:
core/linux515-headers 5.15.74-3 [installed]
One thing I have noticed about my problem that is different from others I have encountered online is the output of rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: no
In other posts, there is usually some item representing Wlan.
It should not be a hardware problem, as Wifi works perfectly in my windows partition. I have disabled fast startup in the windows partition, and secure boot is off in the BIOS.
Most of the posts I have seen are solved by installing some realtek driver. I have looked for drivers corresponding to this Qualcomm device, and have stumbled upon a little documentation on linux-hardware. I can’t include links, but if you search linux-hardware with Qualcomm QCNFA765
it should come up. It seems that the device works with versions 5.14 - 6.0 (I am running 5.15). I believe my install should have come with ath11k
Any help solving this problem is appreciated! Cheers
Edit: Some extra information –
Ethernet is working well. If I run nmcli dev wifi rescan
I get
Error: No Wi-Fi device found.
