Hello!
I had updated the system after many months (My bad. There are certain reasons as to why).
Now I am unable to view the login screen. After I see my system logo (Acer), I do not see any screen. It seems to refreshing constantly. I can briefly (couple of seconds) view the TTY but it get refreshed to a blank screen again.
I’m suspecting the issue might be Nvidia related (Please note that I had optimus-manager installed as well)
Currently booted in using Manjaro Gnome Live usb with propriety drivers. Have already performed chroot and update. No difference.
1) Please find my system info below
12System:
12Kernel 6.6.8-2-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1
12clocksource tsc 12available hpet,acpi_pm
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_GNOME_2312 quiet
systemd.show_status=1 splash driver=nonfree nouveau.modeset=0
i915.modeset=1 radeon.modeset=1
12Desktop GNOME 12tk GTK 12v 3.24.39 12dm N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
12Type Laptop 12System Acer 12product Nitro AN515-51 12v V1.22 12serial <filter>
12Mobo KBL 12model Freed_KLS 12v V1.22 12serial <filter> 12UEFI Insyde 12v 1.22
12date 03/15/2019
(upower:183): UPower-WARNING **: 12:12:33.088: Cannot connect to upowerd: Could not connect: No such file or directory
12CPU:
12Info 12model Intel Core i5-7300HQ 12socket U3E1 12bits 64 12type MCP 12arch Kaby Lake
12gen core 7 12level v3 12note check 12built 2018 12process Intel 14nm 12family 6
12model-id 0x9E (158) 12stepping 9 12microcode 0xF4
12Topology 12cpus 1x 12cores 4 12smt <unsupported> 12cache 12L1 256 KiB
12desc d-4x32 KiB; i-4x32 KiB 12L2 1024 KiB 12desc 4x256 KiB 12L3 6 MiB 12desc 1x6 MiB
12Speed (MHz) 12avg 800 12min/max 800/3500 12base/boost 3100/8300 12scaling
12driver intel_pstate 12governor powersave 12volts 0.9 V 12ext-clock 100 MHz 12cores
121 800 122 800 123 800 124 800 12bogomips 20004
12Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
12Vulnerabilities
12Type gather_data_sampling 12mitigation Microcode
12Type itlb_multihit 12status KVM: VMX disabled
12Type l1tf 12mitigation PTE Inversion; VMX: conditional cache flushes, SMT
disabled
12Type mds 12mitigation Clear CPU buffers; SMT disabled
12Type meltdown 12mitigation PTI
12Type mmio_stale_data 12mitigation Clear CPU buffers; SMT disabled
12Type retbleed 12mitigation IBRS
12Type spec_rstack_overflow 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
12Type spectre_v2 12mitigation IBRS, IBPB: conditional, STIBP: disabled, RSB
filling, PBRSB-eIBRS: Not affected
12Type srbds 12mitigation Microcode
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Intel HD Graphics 630 12vendor Acer Incorporated ALI 12driver i915
12v kernel 12arch Gen-9.5 12process Intel 14nm 12built 2016-20 12ports 12active eDP-1
12empty none 12bus-ID 00:02.0 12chip-ID 8086:591b 12class-ID 0300
12Device-2 NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
12vendor Acer Incorporated ALI 12driver nvidia 12v 545.29.06 12non-free 545.xx+
12status current (as of 2023-11; EOL~2026-12-xx) 12arch Pascal 12code GP10x
12process TSMC 16nm 12built 2016-2021 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 16
12link-max 12gen 3 12speed 8 GT/s 12bus-ID 01:00.0 12chip-ID 10de:1c8c 12class-ID 0300
12Device-3 Chicony Integrated HD WebCam 12driver uvcvideo 12type USB 12rev 2.0
12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 1-9:6 12chip-ID 04f2:b5f7 12class-ID 0e02
12Display 12server X.org 12v 1.21.1.10 12with Xwayland 12v 23.2.3 12driver 12X
12loaded modesetting 12failed nvidia 12dri iris 12gpu i915 12display-ID :0
12Monitor-1 eDP-1 12model LG Display 0x0590 12built 2017 12res 1920x1080 12dpi 142
12gamma 1.2 12size 344x194mm (13.54x7.64") 12diag 395mm (15.5") 12ratio 16:9
12modes 1920x1080
12API EGL 12v 1.5 12hw 12drv intel iris 12drv nvidia 12platforms 12device 0 12drv nvidia
12device 1 12drv iris 12device 3 12drv swrast 12gbm 12drv kms_swrast 12surfaceless
12drv nvidia 12inactive wayland,x11,device-2
12API OpenGL 12v 4.6.0 12compat-v 4.5 12vendor mesa 12v 23.1.9-manjaro1.1
12note incomplete (EGL sourced) 12renderer llvmpipe (LLVM 16.0.6 256 bits),
NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2, Mesa Intel HD Graphics 630 (KBL GT2)
12API Vulkan 12Message No Vulkan data available.
2) Driver info:
[manjaro-gnome /]# mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
> 0000:01:00.0 (0300:10de:1c8c) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime 2023.03.23 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2023.03.23 false PCI
video-nvidia 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-nvidia-390xx 2023.03.23 false PCI
video-vesa 2017.03.12 true PCI
> 0000:03:00.1 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
> 0000:00:02.0 (0300:8086:591b) Display controller Intel Corporation:
3) Kernel info:
[manjaro-gnome /]# mhwd-kernel -li
Currently running: 6.6.8-2-MANJARO (linux66)
* linux510
4) Journalctl info below,
[manjaro-gnome realk]# journalctl -b -1 -p 4
Jan 10 09:40:41 realkj kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jan 10 09:40:41 realkj kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Jan 10 09:40:41 realkj kernel: resource sanity check: requesting [mem 0xfdffe800-0xfe0007ff], which spans more than pnp 00:00 [mem 0xfdb00000-0xfdffffff]
Jan 10 09:40:41 realkj kernel: caller pmc_core_probe+0x7c/0x410 mapping multiple BARs
Jan 10 09:40:41 realkj kernel: wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
Jan 10 09:40:41 realkj kernel: usb: port power management may be unreliable
Jan 10 09:40:41 realkj kernel: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
Jan 10 09:40:42 realkj kernel: vboxdrv: loading out-of-tree module taints kernel.
Jan 10 09:41:07 realkj kernel: VBoxNetAdp: Successfully started.
Jan 10 09:41:07 realkj kernel: VBoxNetFlt: Successfully started.
Jan 10 09:41:07 realkj systemd-journald[221]: File /var/log/journal/ffc99d6d1c9344a4bad09a26f62cf93d/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jan 10 09:41:07 realkj kernel: i2c_hid i2c-ELAN0501:01: supply vdd not found, using dummy regulator
Jan 10 09:41:07 realkj kernel: i2c_hid i2c-ELAN0501:01: supply vddl not found, using dummy regulator
Jan 10 09:41:07 realkj kernel: r8169 0000:03:00.1: can't disable ASPM; OS doesn't have ASPM control
Jan 10 09:41:11 realkj (uetoothd)[738]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Jan 10 09:41:14 realkj systemd[1]: optimus-manager.service: Failed with result 'exit-code'.
Jan 10 09:41:15 realkj bluetoothd[738]: src/plugin.c:plugin_init() System does not support csip plugin
Jan 10 09:41:15 realkj bluetoothd[738]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Jan 10 09:41:15 realkj bluetoothd[738]: src/plugin.c:plugin_init() System does not support micp plugin
Jan 10 09:41:15 realkj bluetoothd[738]: src/plugin.c:plugin_init() System does not support vcp plugin
Jan 10 09:41:15 realkj bluetoothd[738]: src/plugin.c:plugin_init() System does not support mcp plugin
Jan 10 09:41:15 realkj bluetoothd[738]: src/plugin.c:plugin_init() System does not support bass plugin
Jan 10 09:41:15 realkj bluetoothd[738]: src/plugin.c:plugin_init() System does not support bap plugin
Jan 10 09:41:16 realkj systemd[1]: snapd.service: Got notification message from PID 813, but reception only permitted for main PID 743
Jan 10 09:41:16 realkj systemd[1]: snapd.service: Got notification message from PID 814, but reception only permitted for main PID 743
Jan 10 09:41:23 realkj systemd[1]: snapd.service: Got notification message from PID 868, but reception only permitted for main PID 743
Jan 10 09:41:24 realkj systemd[1]: snapd.service: Got notification message from PID 874, but reception only permitted for main PID 743
Jan 10 09:41:35 realkj kernel: nvidia: module license 'NVIDIA' taints kernel.
Jan 10 09:41:35 realkj kernel: Disabling lock debugging due to kernel taint
Jan 10 09:41:35 realkj kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:08 UTC 2023
Jan 10 09:41:35 realkj kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
Jan 10 09:41:47 realkj systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jan 10 09:41:50 realkj systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jan 10 09:41:53 realkj systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jan 10 09:41:56 realkj systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jan 10 09:41:59 realkj systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jan 10 09:42:03 realkj systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jan 10 09:42:06 realkj systemd[1]: lightdm.service: Failed with result 'exit-code'.
