Hi All!
I recently installed Manjaro i3 (community edition) and set everything on my dual monitor setup in nvidia-settings but the screen does not feel like 165Hz at all.
My setup is:
Ryzen 5 3600
GTX 1660
Dual monitor - 2x Dell S2721DGF (165Hz G-Sync compatible)
Now what I’ve configured so far under X Server Display Configuration in nvidia-settings is this:
Resolution 2560x1440 , refresh rate 165Hz (same set on both displays)
Force Composition Pipeline enabled on both displays
Under OpenGL settings:
Sync to VBlank enabled
Allow Flipping enabled
Allow G-Sync/G-Sync compatible enabled
UFO Test (w w w . testufo . c o m) says: VSYNC is not available on the Linux platform.
Am I missing something?
The same setup on Manjaro KDE edition seemed much better and could notice that its running on 165Hz/FPS while dragging windows.
I would just like to use i3wm instead of KDE or XFCE or else.
