Hello , I have a PC with Manjaro XFCE and Windows 10 dual booted each on a separate hard disk of 1TB. After hibernation through Manjaro , the screen turns off for a millisecond then turns on with a black screen and a blinking cursor so I had to hard reset my PC using power button , then I lose saved data after PC boots . Manjaro Suspend , Manjaro Hybrid Sleep , and Windows hibernation work fine .
I configured my swap partition while installing to 22GB since I have 12 GB of RAM (according to Manjaro Swap wiki) , I tried using a swap file also .
swapon
NAME TYPE SIZE USED PRIO
/dev/sdb6 partition 22G 0B -2
I also configured my sleep.conf , grub , and mkinitcpio.conf for hibernation :
mkinitcpio.conf
HOOKS="base udev autodetect modconf block keyboard keymap resume filesystems fsck"
//tried moving resume directly after udev
etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=1
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=aa4262b7-192e-49b8-9169-4adf76d3dba4 udev.log_priority=3"
GRUB_CMDLINE_LINUX="" //tried moving resume to this entry
//tried turning off os_prober
etc/systemd/sleep.conf
[Sleep]
#AllowSuspend=yes
#AllowHibernation=yes
#AllowSuspendThenHibernate=yes //tried setting to no
#AllowHybridSleep=yes
#SuspendMode=
#SuspendState=mem standby freeze
#HibernateMode=platform shutdown //I tried removing platform
#HibernateState=disk
#HybridSleepMode=suspend platform shutdown
#HybridSleepState=disk
#HibernateDelaySec=1800
Also I applied pm_test debugging and it failed on platform , processors , and core test mode .
journalctl showing transition between two boots (Notice freezing on Hibernation Entry then hard reset is done)
-- Journal begins at Mon 2021-09-06 01:07:29 EEST, ends at Tue 2021-09-07 22:40:33 EEST. --
Sep 07 22:36:33 fireflood rtkit-daemon[1002]: Supervising 0 threads of 0 processes of 0 users.
Sep 07 22:36:41 fireflood wpa_supplicant[637]: wlo1: WPA: Group rekeying completed with 58:98:35:d1:41:ad [GTK=TKIP]
Sep 07 22:36:56 fireflood systemd-timesyncd[537]: Initial synchronization to time server 162.159.200.123:123 (0.manjaro.pool.ntp.org).
Sep 07 22:37:11 fireflood manjaro-settings-manager[1274]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41349, resou>
Sep 07 22:37:18 fireflood manjaro-settings-manager[1274]: Shutting down Manjaro Settings Manager...
Sep 07 22:37:47 fireflood NetworkManager[545]: <info> [1631043467.5615] manager: sleep: sleep requested (sleeping: no enabled: yes)
Sep 07 22:37:47 fireflood ModemManager[610]: <info> [sleep-monitor] system is about to suspend
Sep 07 22:37:47 fireflood NetworkManager[545]: <info> [1631043467.5617] device (eno1): state change: unavailable -> unmanaged (reason>
Sep 07 22:37:47 fireflood NetworkManager[545]: <info> [1631043467.5726] manager: NetworkManager state is now ASLEEP
Sep 07 22:37:47 fireflood NetworkManager[545]: <info> [1631043467.5731] device (wlo1): state change: activated -> deactivating (reaso>
Sep 07 22:37:47 fireflood dbus-daemon[544]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-o>
Sep 07 22:37:47 fireflood systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 07 22:37:47 fireflood dbus-daemon[544]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 07 22:37:47 fireflood systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 07 22:37:47 fireflood audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager>
Sep 07 22:37:47 fireflood kernel: audit: type=1130 audit(1631043467.594:137): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfi>
Sep 07 22:37:47 fireflood kernel: wlo1: deauthenticating from 58:98:35:d1:41:ad by local choice (Reason: 3=DEAUTH_LEAVING)
Sep 07 22:37:47 fireflood kernel: rtw_8723de 0000:03:00.0: sta 58:98:35:d1:41:ad with macid 0 left
Sep 07 22:37:48 fireflood wpa_supplicant[637]: wlo1: CTRL-EVENT-DISCONNECTED bssid=58:98:35:d1:41:ad reason=3 locally_generated=1
Sep 07 22:37:48 fireflood wpa_supplicant[637]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Sep 07 22:37:48 fireflood NetworkManager[545]: <info> [1631043468.0566] device (wlo1): state change: deactivating -> disconnected (re>
Sep 07 22:37:48 fireflood avahi-daemon[541]: Withdrawing address record for fe80::b9b4:4dc1:fabd:b525 on wlo1.
Sep 07 22:37:48 fireflood avahi-daemon[541]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::b9b4:4dc1:fabd:b52>
Sep 07 22:37:48 fireflood avahi-daemon[541]: Interface wlo1.IPv6 no longer relevant for mDNS.
Sep 07 22:37:48 fireflood NetworkManager[545]: <info> [1631043468.0879] dhcp4 (wlo1): canceled DHCP transaction
Sep 07 22:37:48 fireflood NetworkManager[545]: <info> [1631043468.0880] dhcp4 (wlo1): state changed bound -> terminated
Sep 07 22:37:48 fireflood avahi-daemon[541]: Interface wlo1.IPv4 no longer relevant for mDNS.
Sep 07 22:37:48 fireflood avahi-daemon[541]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.72.
Sep 07 22:37:48 fireflood avahi-daemon[541]: Withdrawing address record for 192.168.1.72 on wlo1.
Sep 07 22:37:48 fireflood kernel: rtw_8723de 0000:03:00.0: stop vif 5c:ea:1d:35:3c:0b on port 0
Sep 07 22:37:48 fireflood NetworkManager[545]: <info> [1631043468.0909] device (wlo1): set-hw-addr: set MAC address to DE:20:75:D1:F9>
Sep 07 22:37:48 fireflood avahi-daemon[541]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.72.
Sep 07 22:37:48 fireflood avahi-daemon[541]: New relevant interface wlo1.IPv4 for mDNS.
Sep 07 22:37:48 fireflood avahi-daemon[541]: Registering new address record for 192.168.1.72 on wlo1.IPv4.
Sep 07 22:37:48 fireflood kernel: rtw_8723de 0000:03:00.0: start vif de:20:75:d1:f9:17 on port 0
Sep 07 22:37:48 fireflood NetworkManager[545]: <info> [1631043468.2444] device (wlo1): supplicant interface state: completed -> disco>
Sep 07 22:37:48 fireflood NetworkManager[545]: <info> [1631043468.2454] device (wlo1): supplicant interface state: disconnected -> in>
Sep 07 22:37:48 fireflood NetworkManager[545]: <info> [1631043468.2457] device (wlo1): state change: disconnected -> unmanaged (reaso>
Sep 07 22:37:48 fireflood NetworkManager[545]: <info> [1631043468.2462] device (wlo1): set-hw-addr: reset MAC address to 5C:EA:1D:35:>
Sep 07 22:37:48 fireflood kernel: rtw_8723de 0000:03:00.0: stop vif de:20:75:d1:f9:17 on port 0
Sep 07 22:37:48 fireflood kernel: rtw_8723de 0000:03:00.0: start vif 5c:ea:1d:35:3c:0b on port 0
Sep 07 22:37:48 fireflood systemd[1]: Reached target Sleep.
Sep 07 22:37:48 fireflood systemd[1]: Starting Hibernate...
Sep 07 22:37:48 fireflood systemd-sleep[10521]: Suspending system...
Sep 07 22:37:48 fireflood kernel: PM: hibernation: hibernation entry
-- Boot a1979562816d4fafb8028828b047ab12 --
Sep 07 22:38:49 fireflood kernel: microcode: microcode updated early to revision 0xea, date = 2021-01-06
Sep 07 22:38:49 fireflood kernel: Linux version 5.14.0-0-MANJARO (builduser@fv-az83-697) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36>
Sep 07 22:38:49 fireflood kernel: Command line: BOOT_IMAGE=/vmlinuz-5.14-x86_64 root=UUID=07e745d2-822d-4ae3-a7ad-d7376b2c45b3 rw quie>
Sep 07 22:38:49 fireflood kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Sep 07 22:38:49 fireflood kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Sep 07 22:38:49 fireflood kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Sep 07 22:38:49 fireflood kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Sep 07 22:38:49 fireflood kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Sep 07 22:38:49 fireflood kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Sep 07 22:38:49 fireflood kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
Sep 07 22:38:49 fireflood kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
Sep 07 22:38:49 fireflood kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
Sep 07 22:38:49 fireflood kernel: signal: max sigframe size: 2032
Sep 07 22:38:49 fireflood kernel: BIOS-provided physical RAM map:
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x0000000000100000-0x000000006421ffff] usable
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x0000000064220000-0x0000000064220fff] ACPI NVS
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x0000000064221000-0x0000000064221fff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x0000000064222000-0x000000007bd4efff] usable
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x000000007bd4f000-0x000000007c88efff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x000000007c88f000-0x000000007cf7efff] ACPI NVS
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x000000007cf7f000-0x000000007cffefff] ACPI data
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x000000007cfff000-0x000000007cffffff] usable
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x000000007d000000-0x000000007fffffff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x00000000fd000000-0x00000000fe7fffff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x00000000ffa00000-0x00000000ffffffff] reserved
Sep 07 22:38:49 fireflood kernel: BIOS-e820: [mem 0x0000000100000000-0x000000037effffff] usable
Sep 07 22:38:49 fireflood kernel: NX (Execute Disable) protection: active
Sep 07 22:38:49 fireflood kernel: SMBIOS 3.0 present.
Sep 07 22:38:49 fireflood kernel: DMI: HP HP Laptop 15-bs1xx/832B, BIOS F.35 02/26/2018
Sep 07 22:38:49 fireflood kernel: tsc: Detected 1800.000 MHz processor
inxi -Fazy
Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.14-x86_64
root=UUID=07e745d2-822d-4ae3-a7ad-d7376b2c45b3 rw quiet apparmor=1
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: HP product: HP Laptop 15-bs1xx v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 832B v: 23.50 serial: <filter> UEFI-[Legacy]: Insyde v: F.35
date: 02/26/2018
ID-1: BAT1 charge: 32.1 Wh (100.0%) condition: 32.1/32.1 Wh (100.0%)
volts: 16.6 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Full
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 6 MiB
bogomips: 28808
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon
520 Mobile]
driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus-ID: 1-5:4 chip-ID: 05c8:03ac class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati,modesetting,radeon alternate: fbdev,vesa display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard
driver: rtw_8723de v: N/A modules: rtw88_8723de port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-4:3 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.82 TiB used: 14.78 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 033 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: RSM7 scheme: MBR
ID-1: / raw-size: 50 GiB size: 49.09 GiB (98.18%) used: 7.83 GiB (16.0%)
fs: ext4 dev: /dev/sdb7 maj-min: 8:23
ID-2: /boot raw-size: 250 MiB size: 236.1 MiB (94.44%)
used: 153.5 MiB (65.0%) fs: ext4 dev: /dev/sdb5 maj-min: 8:21
ID-3: /home raw-size: 228.25 GiB size: 223.67 GiB (97.99%)
used: 6.79 GiB (3.0%) fs: ext4 dev: /dev/sdb8 maj-min: 8:24
ID-1: swap-1 type: partition size: 22 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb6 maj-min: 8:22
System Temperatures: cpu: 41.5 C mobo: 29.8 C gpu: radeon temp: 35.0 C
Processes: 221 Uptime: 12m wakeups: 1 Memory: 11.61 GiB
used: 1.72 GiB (14.8%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1065 lib: 304 flatpak: 0 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
I tried 5.14 , 5.14 , 4.14 linux kernels , but none worked. Trying the same system on my other HP with Intel Celeron Processor / 4 GB Ram / Intel HD graphic Family worked like a charm .
Notes :
*I have a Windows Backup of 600 GB on the Manjaro disk but on separate partition .
*When the screen turns off , I hear a weird/failing noise in the hard disk.
*I apologize if I forgot something but I tried tons of stuffâThanks in advance.
Edit :
I removed my Manjaro harddisk and booted to it on my Celeron Pc , and hibernation works successfully
Edit2 :
I even tried Manjaro KDE , EndeavourOS with same problem
