After logging in, the background for the buttons in “Manjaro Hello” are white. This looks off in the dark theme. It corrects itself back to dark, after launching an app or selecting Manjaro Hello itself.
Not sure what is causing this. Is it possible to reset the Hello App?
Also, could you please provide an inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
It’s a known issue with applying the Adwaita-maia theme on startup. Hello launches before the theme gets applied. @Chrysostomus tried adding a delay for launching Hello, but it didn’t work for some reason.
It did work somewhat, but delays are always unreliable. It depends on the underlying hardware, if it is fast enough to complete the change before the delay ends.
