So I may deleted a part of my home directory accidentally
managed to restore most of what broke
but now the “Manjaro Hello” screen always appear on startup and the “Launch at start” options does not do anything
any options?
any options?
rm ~/.config/autostart/manjaro-hello.desktop
It’ll take a reset for me to test this
but when I checked the .config folder was owned by root user, so no surprise that when I pressed the button nothing happened…
thank you!
NEVER use sudo
in your Home directory. See why?
Obviously not. Apparently you did a lot more than deleting things. Since you haven’t bothered to tell us what, we won’t bother to help you troubleshoot the result of bad practices. It would be a fruitless endeavor
Let this be a lesson, learn from it and start over.
