I recently installed manjaro on my Laptop Dell Inspiron 5577. It has Nvidia GTX 1050 Graphic card, I had checked non open source drivers during installation process and I had video-hybrid-intel-nvidia-455xx prime initially, and Im using 5.9.8-2 Kernel currently.
I think I have installed the system with UEFI Mode + Legacy PROM and with secure boot mode off. (Not sure though, bit noob in all this)
My system has 24 gb Ram and 512 GB SSD. I Have given around 90 gb of ssd for root and 90 gb HDD for /home. I really don’t understand why the system feels so laggy and irresponsive. When I open any application it opens after a delay and sometimes doesnt open at all and suddenly opens at one time with too many instances.
I had given around 4 GB Swap space since I had sufficient Ram, I tried lot of things but none have worked so far, I really love the KDE Experience and the Arch Linux Experience, thus I do not want to leave Manjaro, can anyone help me troubleshoot my problem, I would really appreciate it.
Also I changed the compositor to open GL 3 still I dont find much difference. I tried to use different driver version (450xx-prime) but the performance is still very bad.
Output of
> mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
> video-hybrid-intel-nvidia-450xx-prime 2020.10.04 false PCI
> video-modesetting 2020.01.13 true PCI
`Warning: No installed USB configs!`
Output of
`cat /etc/X11/mhwd.d/nvidia.conf`
> ## Generated by mhwd - Manjaro Hardware Detection
output of
> inxi -Fza
> System:
> Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
> root=UUID=8ecb3934-dc3f-4f4c-b8da-7691a26c44a8 rw quiet apparmor=1
> security=apparmor resume=UUID=e86b2141-311a-4086-bf67-b0efe4674436
> udev.log_priority=3
> Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
> dm: SDDM Distro: Manjaro Linux
> Machine:
> Type: Laptop System: Dell product: Inspiron 5577 v: 1.0.8
> serial: <filter> Chassis: type: 10 serial: <filter>
> Mobo: Dell model: 0MVD5F v: A00 serial: <filter> UEFI: Dell v: 1.0.8
> date: 12/13/2017
> Battery:
> ID-1: BAT0 charge: 50.0 Wh condition: 50.0/74.0 Wh (68%)
> volts: 12.7/11.1 model: SDI Dell type: Li-ion serial: <filter>
> status: Full
> CPU:
> Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
> arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
> L2 cache: 6144 KiB
> flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
> bogomips: 44817
> Speed: 863 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 835 2: 896
> 3: 836 4: 896 5: 894 6: 802 7: 854 8: 806
> Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
> Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
> SMT vulnerable
> Type: mds mitigation: Clear CPU buffers; SMT vulnerable
> Type: meltdown mitigation: PTI
> Type: spec_store_bypass
> mitigation: Speculative Store Bypass disabled via prctl and seccomp
> Type: spectre_v1
> mitigation: usercopy/swapgs barriers and __user pointer sanitization
> Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
> IBRS_FW, STIBP: conditional, RSB filling
> Type: srbds mitigation: Microcode
> Type: tsx_async_abort status: Not affected
> Graphics:
> Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
> bus ID: 00:02.0 chip ID: 8086:591b
> Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell
> driver: nvidia v: 450.80.02 alternate: nouveau,nvidia_drm
> bus ID: 01:00.0 chip ID: 10de:1c8d
> Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
> driver: uvcvideo bus ID: 1-4:4 chip ID: 1bcf:2b8a
> Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
> driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
> display ID: :0 screens: 1
> Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2")
> s-diag: 582mm (22.9")
> Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
> size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
> OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2)
> v: 4.6 Mesa 20.2.2 direct render: Yes
> Audio:
> Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel
> v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
> Sound Server: ALSA v: k5.9.8-2-MANJARO
> Network:
> Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
> vendor: Dell driver: r8169 v: kernel port: d000 bus ID: 02:00.0
> chip ID: 10ec:8168
> IF: enp2s0 state: down mac: <filter>
> Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: d000
> bus ID: 03:00.0 chip ID: 8086:3165
> IF: wlp3s0 state: up mac: <filter>
> Drives:
> Local Storage: total: 1.36 TiB used: 22.16 GiB (1.6%)
> SMART Message: Unable to run smartctl. Root privileges required.
> ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G3X0C-00SJG0
> size: 465.76 GiB block size: physical: 512 B logical: 512 B
> speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 102000WD scheme: GPT
> ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172
> size: 931.51 GiB block size: physical: 4096 B logical: 512 B
> speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM2
> scheme: GPT
> Partition:
> ID-1: / raw size: 97.35 GiB size: 95.33 GiB (97.92%)
> used: 13.62 GiB (14.3%) fs: ext4 dev: /dev/nvme0n1p7
> ID-2: /home raw size: 93.66 GiB size: 91.69 GiB (97.90%)
> used: 8.54 GiB (9.3%) fs: ext4 dev: /dev/sda4
> Swap:
> Kernel: swappiness: 60 (default) cache pressure: 100 (default)
> ID-1: swap-1 type: partition size: 4.00 GiB used: 0 KiB (0.0%)
> priority: -2 dev: /dev/sda3
> Sensors:
> System Temperatures: cpu: 62.0 C mobo: N/A sodimm: 47.0 C
> Fan Speeds (RPM): cpu: 1940
> Info:
> Processes: 269 Uptime: 25m Memory: 23.26 GiB used: 3.03 GiB (13.0%)
> Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1268
> lib: 335 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
> inxi: 3.1.08
