Hi folks! I’m having some problems with Manjaro. I have no idea what caused/triggered this problem. I did not change anything. I didn’t update anything. There was no system update either.
Screen was turned off due to inactivity as I set it up to turn off screen in “Energy Savings” setting. That’s been my settings for months without any issue. I don’t think my current issue is related to this.
A few hours later, when I was back on the computer, there was a “Notifier” icon in the “System Tray”, next to the bluetooth icon. When I hovered over the notifier icon, it disappeared.
When I hovered over other icons (bluetooth, screen brightness, volume, battery, networks) in the system tray, they disappeared too.
I restarted the computer. It didn’t help! I restarted, choosing a different kernel. It didn’t help either.
Maybe it was the same or another notifier icon in the system tray, when I clicked on it, small option window popped up, to select some options, I think it was about rendering if I remember correctly.
There were some options, Vulkan, OpenGL (and some other ones I don’t really remember). I chose “Vulkan”, which made things worse.
Now the application launcher doesn’t respond as if it were frozen. The semi-transparent panel turns black. Once I launch any app, I can’t exit out. It doesn’t respond. It may be due to kwin_x11 crash.
I tried to find and launch the setting for the notifier, which I recently changed to “Vulkan”, but I could not find any options or settings to make the change. Any help is greatly appreciated.
