I was doing a bit of work related to nodejs and suddenly the whole system hanged after rebooting the system. the system takes quite alot time open application or get completly frozen. Nothing new dependency was installed recently and i dont have any clue…
I looked at my storage both partition have sufficient amount of free storage,
disabled indexer just in case
no io task are running in background
no load on cpu
1Gb memory use out of 8
everything looks ok dont know what to do, really need help solving this
Host: knight Kernel: 5.18.0-1-rt11-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.1.0 Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5
info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A
Mobo: HP model: 87B1 v: 31.23 serial: <superuser required> UEFI: AMI
v: F.25 date: 08/18/2021
ID-1: BAT0 charge: 41.0 Wh (87.4%) condition: 46.9/46.9 Wh (100.0%)
volts: 11.9 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: discharging cycles: 422
Info: 6-core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 2 rev: 1 cache: L1: 384 KiB L2: 3 MiB
L3: 8 MiB
Speed (MHz): avg: 1397 high: 1401 min/max: 1400/3000 boost: enabled
cores: 1: 1396 2: 1397 3: 1401 4: 1397 5: 1396 6: 1396 7: 1397 8: 1401
9: 1396 10: 1395 11: 1397 12: 1397 bogomips: 71864
Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: nouveau v: kernel
arch: Turing pcie: speed: Unknown lanes: 63 ports: active: none
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN 5.1 pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 0408:5365 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x150d res: 1920x1080
hz: 60 dpi: 142 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.0-1-rt11-MANJARO)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: speed: Unknown lanes: 63 bus-ID: 01:00.1 chip-ID: 10de:10fa
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: N/A pcie: speed: 8 GT/s lanes: 16 bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.18.0-1-rt11-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno1 state: down mac: b0:22:7a:d8:eb:a3
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie:
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlo1 state: down mac: 32:73:f6:f6:12:85
IF-ID-1: docker0 state: down mac: 02:42:d1:45:39:a6
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.36 TiB used: 706.62 GiB (50.6%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G2B0C-00PXH0
size: 465.76 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: 212464802316
rev: 211210WD temp: 43.9 C scheme: GPT
ID-2: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: 31J3PL1DT rev: 7C scheme: GPT
ID-1: / size: 97.66 GiB used: 27.44 GiB (28.1%) fs: btrfs
dev: /dev/nvme0n1p1
ID-2: /boot/efi size: 517.6 MiB used: 616 KiB (0.1%) fs: vfat
dev: /dev/sda3
ID-3: /home size: 301.76 GiB used: 230.8 GiB (76.5%) fs: btrfs
dev: /dev/sda2
ID-4: /var/log size: 97.66 GiB used: 27.44 GiB (28.1%) fs: btrfs
dev: /dev/nvme0n1p1
System Temperatures: cpu: N/A mobo: N/A
GPU: device: amdgpu temp: 46.0 C device: nouveau temp: N/A
Processes: 441 Uptime: 2m wakeups: 1 Memory: 7.2 GiB used: 1.15 GiB (16.0%)
Init: systemd v: 251 default: graphical Compilers: gcc: 12.1.0
clang: 14.0.6 Packages: pacman: 1397 Shell: fish v: 3.4.1
running-in: yakuake inxi: 3.3.19
Startup finished in 4.022s (firmware) + 5.981s (loader) + 2.630s (kernel) + 11.099s (userspace) = 23.733s
graphical.target reached after 11.095s in userspace.
