Hi,
I just installed Manjaro gnome one day ago and it got stuck at a black screen with no cursor or any display at all, i tried opening the TTY but that didn’t work too, no command prompt appears, then after several forced shutdowns, it booted normally.
Then when i rebooted it, it went back to the same problem, the system boots up because i can activate airplane mode and caps lock, even when i hit Fn+F1 which is for sleep mode, the pc goes to sleep mode.
I tried replacing “quiet” With 3 In the grub menu but still, nothing worked
I repeat, TTY won’t open up as well.
I installed the proprietary Nvidia and Intel drivers during installation.
Thanks in advanced
