Hello, I have an issue that happened after a clean install on a ThinkPad T15p .
It gets stuck while loading after choosing an entry from grub .
Not sure what can cause this but I suspect the Nvidia driver … I managed to load for one time by pressing Ctrl+Alt+F1 then I reinstalled the Nvidia driver again then booted and it loaded just fine for one time and I had to reboot it stuck loading again .
I tried Endeavor OS but I had no issue with it but I prefer Manjaro .
Any suggestions will be appreciated
Hello,
- in case of Gnome DE i always enable the early KMS as is not doing funky things that way
- also in case of Gnome i remove
gdm-plymouth
and install normalgdm
and i removeplymouth
from /etc/mkinitcpio.conf HOOKS line and then i run:
sudo mkinitcpio -P
and
sudo update-grub
See if that helps and let us know.
