Hello,
I’ve been into Manjaro for years and recently I decided to install the latest release from scratch.
I mostly dual boot Manjaro gnome and Win 7 on this laptop(MBR/BIOS).
So far I had no problems with Manjaro before and I been using optimus manager and always set it for Nvidia the whole time and had no problems at all, everything smooth.
Now, I installed the latest Manjaro release, the gnome one and from the very first seconds it was laggy and unresponsive(like 2 sec) and loads of stutter, like opening nautilus, closing a tab in google chrome, pressing Super…any action lead to this kind of stutter.
I had doubts about the iso file i downloaded, so I downloaded an other one and checked the hash, all is good and did an other fresh install and this time I configured my graphic settings : optimus manager, and nothing, using intel or nvidia leads to the same thing.
I did my long research here and nothing helped me, I’m really curious as to what causing this problem.
Kernel: 5.4.108-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=6dae7135-e5ef-4d32-b388-87c9130baa78 rw quiet splash apparmor=1
security=apparmor resume=UUID=6527b70f-e625-4337-98cf-da808ea8a4d6
udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 3.38.2
Type: Laptop System: ASUSTeK product: X550JX v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X550JX v: 1.0 serial: <filter>
BIOS: American Megatrends v: X550JX.210 date: 04/22/2019
RAM: total: 7.67 GiB used: 3.04 GiB (39.7%)
Info: Quad Core model: Intel Core i7-4750HQ bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 46 (70) stepping: 1 microcode: 1C cache:
L2: 6 MiB bogomips: 31938
Speed: 898 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 898 2: 898 3: 898
4: 898 5: 898 6: 899 7: 899 8: 899
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Crystal Well Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0d26 class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: ASUSTeK driver: nvidia
v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:139a
class-ID: 0302
Device-3: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:5 chip-ID: 04f2:b48c class-ID: 0e02
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: modesetting,nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce GTX 950M/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67
direct render: Yes
Device-1: Intel Crystal Well HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0d0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound Server-1: ALSA v: k5.4.108-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: yes
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: e000 bus-ID: 03:00.0
chip-ID: 168c:0036 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 04:00.1
IF: enp4s0f1 state: down mac: <filter>
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-5:6
chip-ID: 13d3:3408 class-ID: e001
Message: No LVM data was found.
Local Storage: total: 931.51 GiB used: 550.1 GiB (59.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
rotation: 5400 rpm serial: <filter> rev: 2J scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: AS00
dev-links: cdrom
ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 10.48 GiB (26.8%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 6dae7135-e5ef-4d32-b388-87c9130baa78
ID-2: /home raw-size: 49.65 GiB size: 48.57 GiB (97.82%)
used: 2.21 GiB (4.5%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 42c9e612-2ef2-41cb-a188-78dbf471d337
ID-3: /mnt/E8FE15EBFE15B2B4 raw-size: 540.54 GiB size: 540.54 GiB (100.00%)
used: 537.41 GiB (99.4%) fs: ntfs dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: E8FE15EBFE15B2B4
ID-1: swap-1 type: partition size: 8 GiB used: 524 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 6527b70f-e625-4337-98cf-da808ea8a4d6
ID-1: /dev/sda1 maj-min: 8:1 size: 500 MiB fs: ntfs label: System Reserved
uuid: C82A3D4D2A3D39B0
ID-2: /dev/sda2 maj-min: 8:2 size: 292.82 GiB fs: ntfs label: N/A
uuid: 685442D55442A5A2
ID-3: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 1-1:2 info: CASUE USB Keyboard type: Keyboard,HID
power: 100mA chip-ID: 2a7a:9a18 class-ID: 0300
Device-2: 1-2:3 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
Device-3: 1-5:6 info: IMC Networks type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 13d3:3408
class-ID: e001
Device-4: 1-7:5 info: Chicony USB2.0 VGA UVC WebCam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (RPM): cpu: 2400
Processes: 290 Uptime: 2h 12m wakeups: 1 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1201 lib: 292
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.03
How to find the problem ?
Sorry about the long post, had to write those details in order to have high chance to fix my problem.
