Hello,
Im trying to install Manjaro GNOME on my laptop but the installer keeps crashing. Has anyone else had this problem. If so what was the solutions?
For those that need to know
Specs
HP Pavilion
CPU: Intel(R) Core™ i5-10300H CPU @ 2.50GHz 8 Core
GPU: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05) NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] (rev a1)
RAM: 7.5 gi
Thank you in advance
Hi @Greypathos and welcome to the Manjaro community.
Please look at the information you have provided. Is that really enough for anyone to have an immediate solution to your issue? The skeleton information you have provided only opens the door to play a game of questions and guesses.
Please provide more detail to help others help you.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Cheers.
I apologize for my lack of information or knowledge on what i need to post as I am new to not just manjaro but to forums in general and I never expected an immediate solution, i expect it to take time. As for relevant information that would help im not sure what else to provide that would help except that im running a live version of manjaro off a boot drive and when i go to install it to my computer it crashes before i can choose a keyboard layout. I figure its not a software issue due to a combination of no complaints about the latest release that I could find here, and the fact that my live boot drive is working perfectly fine. When it crashes there are no error messages or anything to tell me why it wont install.
Blind shot: Disable Fast Boot/Secure Boot/TPM in Bios… also get sure you choose the right USB Boot entry that fits to your MBR or Efi install.
The installer logs its progres, I’m not certain if the log level is enough to find the issue you experience.
The Calamares session log is placed in ~/.cache/calamares and is called session.log. It is placed in the home-directory of the user running Calamares, so that may be the root user. If it is not detailed, add -D6 to the flags passed to Calamares (meaning “debug logging level 6”, which is plenty).
source
If there is a session log and a relevant error?
So I was able to launch from the terminal and was able to see what was failing. Everything is looking good except a warning for EFI
WARNING: system is EFI but no EFI system partitions found.
15:24:08 [1]: ASSERT: "efiSectorCount > 0" in file /build/calamares5/src/calamares-3.2.62/src/modules/partition/core/PartitionActions.cpp, line 123
/usr/bin/calamares_polkit: line 6: 7838 Aborted
I’m not entirely sure what this mean, but its the only real error I got
“Assert:” means:
This condition MUST be met to continue.
The installer cannot find an EFI partition and cannot continue
Ok, is there a way i can create a partition for it to build on?
What about some inxi ?
Instead of playing hide and seek
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_GNOME_2402 quiet systemd.show_status=1 splash
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: GNOME v: 46.2 tk: GTK v: 3.24.42 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 16-a0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 87AF v: 32.31 serial: <filter> part-nu: 2C387UA#ABA
uuid: 31444335-3130-324d-4739-3024a98d7745 UEFI: AMI v: F.20 date: 11/04/2020
ID-1: BAT0 charge: 43.4 Wh (100.0%) condition: 43.4/43.4 Wh (100.0%)
volts: 12.8 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 249
System RAM: total: 8 GiB available: 7.53 GiB used: 5.09 GiB (67.6%)
igpu: 64 MiB
Device-1: Bottom - Slot 1 (Up) type: DDR4 detail: synchronous size: 4 GiB
speed: spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: SK Hynix
part-no: HMA851S6CJR6N-XN serial: <filter>
Device-2: Bottom - Slot 2 (down) type: DDR4 detail: synchronous size: 4 GiB
Slot: 0 type: PCIe lanes: 16 status: in use info: J6B2 length: long
volts: 3.3 bus-ID: 00:01.0 children: 1: 01:00.0 class-ID: 0300 type: display
2: 01:00.1 class-ID: 0403 type: audio 3: 01:00.2 class-ID: 0c03
type: serialbus 4: 01:00.3 class-ID: 0c80 type: serialbus
Info: model: Intel Core i5-10300H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xFA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 875 high: 904 min/max: 800/4500 base/boost: 2475/8300
scaling: driver: intel_pstate governor: powersave volts: 0.8 V
ext-clock: 100 MHz cores: 1: 900 2: 900 3: 800 4: 800 5: 900 6: 900 7: 904
8: 900 bogomips: 40009
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile]
vendor: Hewlett-Packard driver: nouveau v: kernel non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: none empty: DP-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-3: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0408:5365
class-ID: 0e02
Display: server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: gnome-shell driver: gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display 0x08f7 built: 2019 res: 1920x1080
hz: 144 dpi: 135 gamma: 1.2 chroma: red: x: 0.651 y: 0.341 green: x: 0.322
y: 0.612 blue: x: 0.145 y: 0.051 white: x: 0.314 y: 0.329
size: 360x200mm (14.17x7.87") diag: 407mm (16") ratio: 16:9
modes: 1920x1080
EDID-Warnings: 1: parse_edid: unknown flag 2
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: iris device: 1 drv: nouveau device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: iris x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 7.35 GiB unified: yes
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
class-ID: 0401
Device-2: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: n/a (root, process) with:
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 0bda:b00c
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Device-1: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2944 chunk-size: N/A
Components: Online: N/A Spare:
0: nvme0n1 maj-min: 259:4 size: 27.25 GiB state: S
Local Storage: total: 561.96 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Intel model: HBRPEKNX0202AHO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: HPS3 temp: 53.9 C
SMART: yes health: PASSED on: 1y 68d 12h cycles: 1,382
read-units: 501,551 [256 GB] written-units: 601,464 [307 GB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202AH
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: HPS2 temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 20d 5h cycles: 1,380
read-units: 212,138,929 [108 TB] written-units: 106,666,435 [54.6 TB]
ID-3: /dev/sda maj-min: 8:0 model: USB 3.1 size: 57.77 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
Message: No partition data found.
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: ext4 label: N/A
uuid: c622d75e-3309-40ad-a8f6-ff18229b3739
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: ext4 label: N/A
uuid: 9fdbc23b-8f80-4ce6-9f2f-14180bbcb8a9
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 475.96 GiB fs: ext4 label: N/A
uuid: 23215c83-362f-4bc6-b1c9-e7465562ecca
ID-4: /dev/sda1 maj-min: 8:1 size: 3.69 GiB fs: iso9660
ID-5: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 57E6-B979
Device-1: 1-2:2 info: Razer USA Naga Classic Edition type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0093 class-ID: 0300
serial: <filter>
Device-2: 1-6:3 info: Quanta HP TrueVision HD Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0408:5365 class-ID: 0e02
Device-3: 1-7:4 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Device-1: 2-1:2 info: Phison USB 3.1 type: mass storage driver: usb-storage
interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
power: 504mA chip-ID: 13fe:6700 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 52.0 C pch: 56.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Packages: pm: pacman pkgs: 1229 libs: 278 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
2: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
3: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
4: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
5: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
6: https://mirrors2.manjaro.org/stable/$repo/$arch
7: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
8: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
9: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
10: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
11: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
12: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
13: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
14: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
15: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
16: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
17: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
18: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
19: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
20: https://manjaro.kurdy.org/stable/$repo/$arch
21: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
22: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
23: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
24: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
25: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
26: https://mirrors.manjaro.org/repo/stable/$repo/$arch
27: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
28: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
29: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
30: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
31: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
32: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
33: https://mirror.koddos.net/manjaro/stable/$repo/$arch
34: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
35: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
36: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
37: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
39: http://manjaro.mirror.ac.za/stable/$repo/$arch
40: http://mirror.fcix.net/manjaro/stable/$repo/$arch
41: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
42: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
43: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
44: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
45: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
46: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
47: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
48: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
49: https://mirror.zetup.net/manjaro/stable/$repo/$arch
50: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
51: https://mirror.funami.tech/manjaro/stable/$repo/$arch
52: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
53: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
54: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
55: https://linorg.usp.br/manjaro/stable/$repo/$arch
56: https://muug.ca/mirror/manjaro/stable/$repo/$arch
57: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
58: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
59: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
60: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
61: https://mirror.seahost.de/manjaro/stable/$repo/$arch
62: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
63: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
64: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
65: https://repos.silknet.com/manjaro/stable/$repo/$arch
66: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
67: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
68: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
69: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
70: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
71: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
72: http://manjaro.grena.ge/stable/$repo/$arch
73: https://mirror.init7.net/manjaro/stable/$repo/$arch
74: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
75: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
76: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
77: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
78: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
79: https://mirrors.netix.net/manjaro/stable/$repo/$arch
80: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
81: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
82: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
83: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
84: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
85: https://mirror.easyname.at/manjaro/stable/$repo/$arch
86: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
87: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
88: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
89: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
90: https://manjaro.ynh.ovh/stable/$repo/$arch
91: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
92: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
93: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
94: https://manjaro.kyberorg.fi/stable/$repo/$arch
95: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
96: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
97: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
98: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
99: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
100: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
101: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
102: https://mirror.dc.uz/manjaro/stable/$repo/$arch
103: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
104: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
105: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
106: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
107: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
108: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
109: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
110: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
111: https://mirror.23m.com/manjaro/stable/$repo/$arch
112: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
113: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
114: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
115: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
116: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
117: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
118: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
119: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
120: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
121: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
122: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
123: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
124: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
125: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
126: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
127: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
128: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
129: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 314
1: cpu: 35.4% command: firefox pid: 9258 mem: 550.3 MiB (7.1%)
2: cpu: 32.9% command: firefox pid: 4304 mem: 493.6 MiB (6.3%)
3: cpu: 17.7% command: gnome-shell pid: 1106 mem: 295.0 MiB (3.8%)
4: cpu: 9.7% command: firefox pid: 9027 mem: 48.9 MiB (0.6%)
5: cpu: 4.2% command: firefox pid: 4568 mem: 327.0 MiB (4.2%)
Memory top: 5 of 314
1: mem: 550.3 MiB (7.1%) command: firefox pid: 9258 cpu: 35.4%
2: mem: 493.6 MiB (6.3%) command: firefox pid: 4304 cpu: 32.9%
3: mem: 341.0 MiB (4.4%) command: pamac-manager pid: 15172 cpu: 1.1%
4: mem: 327.0 MiB (4.2%) command: firefox pid: 4568 cpu: 4.2%
5: mem: 295.0 MiB (3.8%) command: gnome-shell pid: 1106 cpu: 17.7%
Processes: 314 Power: uptime: 1h 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.97 GiB services: gsd-power,
tool: systemctl
Compilers: N/A Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.26
running-in: gnome-terminal inxi: 3.3.35
There is a partition, but (with 4MiB) it is way to small for EFI
Please seek advice regarding partitioning. This is not my area of expertise
Or the wiki / forum for “partitioning”
The SDSA In question is my boot USB Drive if that makes a difference
I was able to fit it by going into BIOS and reformatting the first NVME, as it was still set for windows? Anyway its fixed
system
Closed
23 June 2024 05:37
15
