Manjaro Gnome installation stuck on Starting line
Alright so this is my first time trying to install a linux based OS, been trying for like…uhm, 8 hours or so. But it’s still stuck here, tried many fixes but i’m open to suggestions since I really want this OS ;-;
It just says " Starting version … " after I click boot with proprietary drivers since I have a nvidia graphics card…
It’s booted from an USB and i’ve tried various stuff such as rufus, balena etcher and fedora media writer…
No fast boot, only UEFI selected, I don’t really get it…
Current specs :
CPU-Z TXT Report
Binaries
CPU-Z version			2.01.0.x64
Processors
CPU Groups			1
CPU Group 0			6 threads, mask=0x3F
Number of sockets		1
Number of threads		6
APICs
Socket 0
	-- Core 0 (ID 0)
		-- Thread 0	0
	-- Core 1 (ID 2)
		-- Thread 1	2
	-- Core 2 (ID 4)
		-- Thread 2	4
	-- Core 3 (ID 6)
		-- Thread 3	6
	-- Core 4 (ID 8)
		-- Thread 4	8
	-- Core 5 (ID 10)
		-- Thread 5	10
Timers
	ACPI timer		3.580 MHz
	Perf timer		10.000 MHz
	Sys timer		1.000 KHz
Processors Information
Socket 1			ID = 0
	Number of cores		6 (max 6)
	Number of threads	6 (max 6)
	Manufacturer		GenuineIntel
	Name			Intel Core i5 8400
	Codename		Coffee Lake
	Specification		Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
	Package (platform ID)	Socket 1151 LGA (0x1)
	CPUID			6.E.A
	Extended CPUID		6.9E
	Core Stepping		U0
	Technology		14 nm
	TDP Limit		65.0 Watts
	Tjmax			100.0 °C
	Core Speed		3792.6 MHz
	Multiplier x Bus Speed	38.0 x 99.8 MHz
	Base frequency (cores)	99.8 MHz
	Base frequency (ext.)	99.8 MHz
	Stock frequency		2800 MHz
	Max frequency		4000 MHz
	Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
	Microcode Revision	0xDE
	L1 Data cache		6 x 32 KB (8-way, 64-byte line)
	L1 Instruction cache	6 x 32 KB (8-way, 64-byte line)
	L2 cache		6 x 256 KB (4-way, 64-byte line)
	L3 cache		9 MB (12-way, 64-byte line)
	Max CPUID level		00000016h
	Max CPUID ext. level	80000008h
	FID/VID Control		yes
	Turbo Mode		supported, enabled
	Max non-turbo ratio	28x
	Max turbo ratio		40x
	Max efficiency ratio	8x
	Min operating ratio	8x
	Speedshift		Autonomous
	O/C bins		none
	Ratio 1 core		40x
	Ratio 2 cores		39x
	Ratio 3 cores		39x
	Ratio 4 cores		39x
	Ratio 5 cores		38x
	Ratio 6 cores		38x
	IA Voltage Mode		PCU adaptive
	IA Voltage Offset	0 mV
	GT Voltage Mode		PCU adaptive
	GT Voltage Offset	0 mV
	LLC/Ring Voltage Mode	PCU adaptive
	LLC/Ring Voltage Offset	0 mV
	Agent Voltage Mode	PCU adaptive
	Agent Voltage Offset	0 mV
	TDP Level		65.0 W @ 28x
	Temperature 0		55 degC (131 degF) (Package)
	Temperature 1		56 degC (132 degF) (Cores (Max))
	Temperature 2		46 degC (114 degF) (Core #0)
	Temperature 3		52 degC (125 degF) (Core #1)
	Temperature 4		55 degC (131 degF) (Core #2)
	Temperature 5		46 degC (114 degF) (Core #3)
	Temperature 6		46 degC (114 degF) (Core #4)
	Temperature 7		54 degC (129 degF) (Core #5)
	Voltage 0		1.14 Volts (VID)
	Voltage 1		+0.00 Volts (IA Offset)
	Voltage 2		+0.00 Volts (GT Offset)
	Voltage 3		+0.00 Volts (LLC/Ring Offset)
	Voltage 4		+0.00 Volts (System Agent Offset)
	Power 00		26.05 W (Package)
	Power 01		22.83 W (IA Cores)
	Power 02		n.a. (GT)
	Power 03		1.47 W (DRAM)
	Clock Speed 0		3792.59 MHz (Core #0)
	Clock Speed 1		3792.59 MHz (Core #1)
	Clock Speed 2		3792.59 MHz (Core #2)
	Clock Speed 3		3792.59 MHz (Core #3)
	Clock Speed 4		3792.59 MHz (Core #4)
	Clock Speed 5		3792.59 MHz (Core #5)
	Core 0 max ratio	40.00 (effective 38.00)
	Core 1 max ratio	40.00 (effective 38.00)
	Core 2 max ratio	40.00 (effective 38.00)
	Core 3 max ratio	40.00 (effective 39.00)
	Core 4 max ratio	40.00 (effective 38.00)
	Core 5 max ratio	40.00 (effective 38.00)
Thread dumps
CPU Thread 0
	APIC ID			0
	Topology		Processor ID 0, Core ID 0, Thread ID 0
	Cache descriptor	Level 1, D, 32 KB, 2 thread(s)
	Cache descriptor	Level 1, I, 32 KB, 2 thread(s)
	Cache descriptor	Level 2, U, 256 KB, 2 thread(s)
	Cache descriptor	Level 3, U, 9 MB, 16 thread(s)
	CPUID
	0x00000000		0x00000016	0x756E6547	0x6C65746E	0x49656E69
	0x00000001		0x000906EA	0x00100800	0x7FFAFBBF	0xBFEBFBFF
	0x00000002		0x76036301	0x00F0B6FF	0x00000000	0x00C30000
	0x00000003		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000004		0x1C004121	0x01C0003F	0x0000003F	0x00000000
	0x00000004		0x1C004122	0x01C0003F	0x0000003F	0x00000000
	0x00000004		0x1C004143	0x00C0003F	0x000003FF	0x00000000
	0x00000004		0x1C03C163	0x02C0003F	0x00002FFF	0x00000006
	0x00000005		0x00000040	0x00000040	0x00000003	0x11142120
	0x00000006		0x000027F7	0x00000002	0x00000001	0x00000000
	0x00000007		0x00000000	0x029C67AF	0x40000000	0x9C002600
	0x00000008		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000009		0x00000000	0x00000000	0x00000000	0x00000000
	0x0000000A		0x07300804	0x00000000	0x00000000	0x00000603
	0x0000000B		0x00000001	0x00000001	0x00000100	0x00000000
	0x0000000B		0x00000004	0x00000006	0x00000201	0x00000000
	0x0000000C		0x00000000	0x00000000	0x00000000	0x00000000
	0x0000000D		0x0000001F	0x00000440	0x00000440	0x00000000
	0x0000000D		0x0000000F	0x00000440	0x00000100	0x00000000
	0x0000000D		0x00000100	0x00000240	0x00000000	0x00000000
	0x0000000D		0x00000040	0x000003C0	0x00000000	0x00000000
	0x0000000D		0x00000040	0x00000400	0x00000000	0x00000000
	0x0000000E		0x00000000	0x00000000	0x00000000	0x00000000
	0x0000000F		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000010		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000011		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000012		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000013		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000014		0x00000001	0x0000000F	0x00000007	0x00000000
	0x00000015		0x00000002	0x000000EA	0x00000000	0x00000000
	0x00000016		0x00000AF0	0x00000FA0	0x00000064	0x00000000
	0x80000000		0x80000008	0x00000000	0x00000000	0x00000000
	0x80000001		0x00000000	0x00000000	0x00000121	0x2C100800
	0x80000002		0x65746E49	0x2952286C	0x726F4320	0x4D542865
	0x80000003		0x35692029	0x3034382D	0x50432030	0x20402055
	0x80000004		0x30382E32	0x007A4847	0x00000000	0x00000000
	0x80000005		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000006		0x00000000	0x00000000	0x01006040	0x00000000
	0x80000007		0x00000000	0x00000000	0x00000000	0x00000100
	0x80000008		0x00003027	0x00000000	0x00000000	0x00000000
	MSR 0x0000001B		0x00000000	0xFEE00900
	MSR 0x0000003A		0x00000000	0x00020005
	MSR 0x00000035		0x00000000	0x00060006
	MSR 0x000001A0		0x00000000	0x00850089
	MSR 0x00000770		0x00000000	0x00000001
	MSR 0x00000774		0x0000019E	0x0000FF1C
	MSR 0x000000CE		0x00080838	0xF1011C00
	MSR 0x00000017		0x00040000	0x00000000
	MSR 0x000000C1		0x0000FFFF	0xFFEFDDAE
	MSR 0x000000C2		0x00000000	0x000102FB
	MSR 0x000000C3		0x00000000	0x000005E3
	MSR 0x000000C4		0x00000000	0x00029D64
	MSR 0x00000186		0x00000000	0x0051003C
	MSR 0x00000187		0x00000000	0x0041FF88
	MSR 0x000001AD		0x00002626	0x27272728
	MSR 0x00000194		0x00000000	0x00010000
	MSR 0x0000019A		0x00000000	0x00000000
	MSR 0x0000019C		0x00000000	0x88330008
	MSR 0x000001A2		0x00000000	0x00641200
	MSR 0x000001A4		0x00000000	0x00000000
	MSR 0x000001B1		0x00000000	0x882F0008
	MSR 0x000001FC		0x00000000	0x0038005D
	MSR 0x00000606		0x00000000	0x000A0E03
	MSR 0x00000601		0x00000000	0x00000000
	MSR 0x00000610		0x004283B8	0x00DD82F8
	MSR 0x00000611		0x00000000	0x19AD8465
	MSR 0x00000639		0x00000000	0x0EB8572A
	MSR 0x00000641		0x00000000	0x00000000
	MSR 0x00000619		0x00000000	0x0182889E
	MSR 0x00000614		0x00000000	0x00000208
	MSR 0x00000648		0x00000000	0x0000001C
	MSR 0x00000649		0x00000000	0x00000000
	MSR 0x0000064A		0x00000000	0x00000000
	MSR 0x00000198		0x00002354	0x00002600
	MSR 0x00000199		0x00000000	0x00001C00
CPU Thread 1
	APIC ID			2
	Topology		Processor ID 0, Core ID 2, Thread ID 0
	CPUID
	0x00000001		0x000906EA	0x02100800	0x7FFAFBBF	0xBFEBFBFF
	0x0000000B		0x00000001	0x00000001	0x00000100	0x00000002
	0x0000000B		0x00000004	0x00000006	0x00000201	0x00000002
	MSR 0x0000001B		0x00000000	0xFEE00800
	MSR 0x000000C1		0x0000FFFF	0xFFEFB60C
	MSR 0x000000C2		0x00000000	0x0000D1BA
	MSR 0x000000C3		0x00000000	0x00000FA8
	MSR 0x000000C4		0x00000000	0x000246C3
	MSR 0x0000019C		0x00000000	0x88300008
	MSR 0x000001B1		0x00000000	0x88300008
	MSR 0x00000611		0x00000000	0x19AD94F0
	MSR 0x00000639		0x00000000	0x0EB86530
	MSR 0x00000619		0x00000000	0x0182896B
	MSR 0x00000198		0x0000234D	0x00002600
CPU Thread 2
	APIC ID			4
	Topology		Processor ID 0, Core ID 4, Thread ID 0
	CPUID
	0x00000001		0x000906EA	0x04100800	0x7FFAFBBF	0xBFEBFBFF
	0x0000000B		0x00000001	0x00000001	0x00000100	0x00000004
	0x0000000B		0x00000004	0x00000006	0x00000201	0x00000004
	MSR 0x000000C1		0x0000FFFF	0xFFF68C62
	MSR 0x000000C2		0x00000000	0x00024003
	MSR 0x000000C3		0x00000000	0x0001F6CC
	MSR 0x000000C4		0x00000000	0x0004CB93
	MSR 0x0000019C		0x00000000	0x88320008
	MSR 0x000001B1		0x00000000	0x88310008
	MSR 0x00000611		0x00000000	0x19ADA554
	MSR 0x00000639		0x00000000	0x0EB8748C
	MSR 0x00000619		0x00000000	0x01828A3E
	MSR 0x00000198		0x00002424	0x00002600
CPU Thread 3
	APIC ID			6
	Topology		Processor ID 0, Core ID 6, Thread ID 0
	CPUID
	0x00000001		0x000906EA	0x06100800	0x7FFAFBBF	0xBFEBFBFF
	0x0000000B		0x00000001	0x00000001	0x00000100	0x00000006
	0x0000000B		0x00000004	0x00000006	0x00000201	0x00000006
	MSR 0x000000C1		0x0000FFFF	0xFFF0723B
	MSR 0x000000C2		0x00000000	0x00013D52
	MSR 0x000000C3		0x00000000	0x00000ECD
	MSR 0x000000C4		0x00000000	0x000313DC
	MSR 0x0000019C		0x00000000	0x88310008
	MSR 0x00000611		0x00000000	0x19ADD9F7
	MSR 0x00000639		0x00000000	0x0EB8A1E4
	MSR 0x00000619		0x00000000	0x01828D63
	MSR 0x00000198		0x000022FB	0x00002600
CPU Thread 4
	APIC ID			8
	Topology		Processor ID 0, Core ID 8, Thread ID 0
	CPUID
	0x00000001		0x000906EA	0x08100800	0x7FFAFBBF	0xBFEBFBFF
	0x0000000B		0x00000001	0x00000001	0x00000100	0x00000008
	0x0000000B		0x00000004	0x00000006	0x00000201	0x00000008
	MSR 0x000000C1		0x0000FFFF	0xFFEF198C
	MSR 0x000000C2		0x00000000	0x0000970F
	MSR 0x000000C3		0x00000000	0x000017A5
	MSR 0x000000C4		0x00000000	0x00018698
	MSR 0x000001B1		0x00000000	0x88330008
	MSR 0x00000611		0x00000000	0x19ADE97D
	MSR 0x00000639		0x00000000	0x0EB8AF20
	MSR 0x00000619		0x00000000	0x01828E33
	MSR 0x00000198		0x000023CE	0x00002600
CPU Thread 5
	APIC ID			10
	Topology		Processor ID 0, Core ID 10, Thread ID 0
	CPUID
	0x00000001		0x000906EA	0x0A100800	0x7FFAFBBF	0xBFEBFBFF
	0x0000000B		0x00000001	0x00000001	0x00000100	0x0000000A
	0x0000000B		0x00000004	0x00000006	0x00000201	0x0000000A
	MSR 0x000000C1		0x0000FFFF	0xFFFF2504
	MSR 0x000000C2		0x00000000	0x0003A110
	MSR 0x000000C3		0x00000000	0x0005F9A3
	MSR 0x000000C4		0x00000000	0x00100A65
	MSR 0x00000611		0x00000000	0x19ADFEC5
	MSR 0x00000639		0x00000000	0x0EB8C1C5
	MSR 0x00000619		0x00000000	0x01828F2B
	MSR 0x00000198		0x000023F5	0x00002600
BIOS
UEFI				Yes
BIOS Vendor			American Megatrends Inc.
BIOS MSG			63-0100-000001-00101111-040517-Chipset
BIOS Date			04/05/17
Mainboard Vendor		000001
Chipset
Northbridge			Intel Coffee Lake rev. 07
Southbridge			Intel H310 rev. 10
Bus Specification		PCI-Express 3.0 (8.0 GT/s)
Graphic Interface		PCI-Express 3.0
PCI-E Link Width		x16 (max 16x)
PCI-E Link Speed		8.0 GT/s (max 8.0 GT/s)
Memory Type			DDR4
Memory Size			16 GBytes
Channels			Dual
Memory Frequency		1330.7 MHz (3:40)
CAS# latency (CL)		18.0
RAS# to CAS# delay (tRCD)	18
RAS# Precharge (tRP)		18
Cycle Time (tRAS)		44
Row Refresh Cycle Time (tRFC)	467
Command Rate (CR)		2T
Uncore Frequency		3493.2 MHz
Host Bridge			0x3EC2
Memory SPD
DIMM #				1
	SMBus address		0x50
	Memory type		DDR4
	Module format		UDIMM
	Module Manufacturer(ID)	Corsair (7F7F9E0000000000000000000000)
	SDRAM Manufacturer (ID)	SK Hynix (AD00000000000000000000000000)
	Size			8192 MBytes
	Max bandwidth		DDR4-2400 (1200 MHz)
	Max JEDEC		DDR4-2400 (1200 MHz)
	Part number		CMK8GX4M1A2400C16
	Nominal Voltage		1.20 Volts
	EPP			no
	XMP			yes, rev. 2.0
	AMP			no
JEDEC timings table		CL-tRCD-tRP-tRAS-tRC @ frequency
	JEDEC #1		9.0-9-9-22-31 @ 666 MHz
	JEDEC #2		10.0-11-11-25-36 @ 766 MHz
	JEDEC #3		11.0-12-12-27-39 @ 833 MHz
	JEDEC #4		12.0-12-12-30-42 @ 900 MHz
	JEDEC #5		13.0-13-13-32-45 @ 966 MHz
	JEDEC #6		14.0-15-15-35-49 @ 1066 MHz
	JEDEC #7		15.0-16-16-37-52 @ 1133 MHz
	JEDEC #8		16.0-16-16-39-56 @ 1200 MHz
	JEDEC #9		17.0-16-16-39-56 @ 1200 MHz
	JEDEC #10		18.0-16-16-39-56 @ 1200 MHz
	JEDEC #11		19.0-16-16-39-56 @ 1200 MHz
	JEDEC #12		20.0-16-16-39-56 @ 1200 MHz
XMP profile			XMP-2400
	Specification		DDR4-2400
	VDD Voltage		1.200 Volts
	Min Cycle time		0.833 ns (1200 MHz)
	Max CL			16.0
	Min tRP			13.32 ns
	Min tRCD		13.32 ns
	Min tRAS		32.31 ns
	Min tRC			45.81 ns
	Min tRRD		4.16 ns
XMP timings table		CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
	XMP #1			9.0-9-9-22-31-n.a @ 675 MHz (1.200 Volts)
	XMP #2			10.0-10-10-25-35-n.a @ 750 MHz (1.200 Volts)
	XMP #3			11.0-11-11-27-38-n.a @ 825 MHz (1.200 Volts)
	XMP #4			12.0-12-12-30-42-n.a @ 900 MHz (1.200 Volts)
	XMP #5			13.0-13-13-32-45-n.a @ 975 MHz (1.200 Volts)
	XMP #6			14.0-15-15-34-49-n.a @ 1051 MHz (1.200 Volts)
	XMP #7			15.0-16-16-37-52-n.a @ 1126 MHz (1.200 Volts)
	XMP #8			16.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
	XMP #9			17.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
	XMP #10			18.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
	XMP #11			19.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
	XMP #12			20.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
DIMM #				2
	SMBus address		0x52
	Memory type		DDR4
	Module format		UDIMM
	SDRAM Manufacturer (ID)	Micron Technology (2C00000000000000000000000000)
	Size			8192 MBytes
	EPP			no
	XMP			yes, rev. 2.0
	AMP			no
	JEDEC #8		16.0-16-16-39-55 @ 1200 MHz
	JEDEC #9		17.0-16-16-39-55 @ 1200 MHz
	JEDEC #10		18.0-16-16-39-55 @ 1200 MHz
	JEDEC #11		19.0-16-16-39-55 @ 1200 MHz
	JEDEC #12		20.0-16-16-39-55 @ 1200 MHz
	Max CL			16.0
	Min tRP			13.33 ns
	Min tRCD		13.33 ns
	Min tRAS		32.33 ns
	Min tRC			45.70 ns
	Min tRRD		4.16 ns
	XMP #1			9.0-10-10-22-31-n.a @ 675 MHz (1.200 Volts)
	XMP #6			14.0-14-14-34-49-n.a @ 1050 MHz (1.200 Volts)
	XMP #7			15.0-15-15-37-52-n.a @ 1125 MHz (1.200 Volts)
DIMM #				1
SPD registers
		00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
	00	23 10 0C 02 85 21 00 08 00 00 00 03 01 03 00 00
	10	00 00 07 0C FC 3F 04 00 6B 6B 6B 11 03 6F F0 0A
	20	20 08 00 05 00 B0 22 2F 2B 00 00 00 00 00 00 00
	30	00 00 00 00 00 00 00 00 00 00 00 00 16 36 16 36
	40	16 36 16 36 00 00 2B 0C 2B 0C 2B 0C 2B 0C 00 00
	50	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	60	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	70	00 00 00 00 00 ED C9 A6 BF C9 C9 C9 00 D6 42 E5
	80	11 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	90	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	B0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	C0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 B6 58
	100	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	110	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	120	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	130	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	140	02 9E 00 00 00 00 00 00 00 43 4D 4B 38 47 58 34
	150	4D 31 41 32 34 30 30 43 31 36 20 20 20 00 80 AD
	160	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	170	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	180	0C 4A 01 20 00 00 00 00 00 94 00 00 07 FC 3F 04
	190	00 6B 6B 6B 11 03 6F F0 0A 20 08 00 05 00 B0 22
	1A0	2F 00 00 00 00 00 00 00 00 C9 A6 BF C9 C9 C9 D6
	1B0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	1C0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	1D0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	1E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	1F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM #				2
SPD registers
	00	23 10 0C 02 84 19 00 08 00 00 00 03 09 03 00 00
	10	00 00 07 0C FC 3F 04 00 6B 6B 6B 11 03 6E 20 08
	20	00 05 70 03 00 A8 22 2F 2B 00 00 00 00 00 00 00
	70	00 00 00 00 00 ED D4 AB D1 D1 D1 D1 00 D6 8C 32
	80	11 11 01 01 00 00 00 00 00 00 00 00 00 00 00 00
	F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 DE 27
	150	4D 31 41 32 34 30 30 43 31 36 20 20 20 00 80 2C
	190	00 6B 6B 6B 11 03 6E 20 08 00 05 70 03 00 B0 22
	1A0	2F 00 00 00 00 00 00 00 00 D4 AB D1 D1 D1 D1 D6
Monitoring
Mainboard Model		H310M GAMING PLUS (MS-7B28) (0x00000681 - 0xEA9435F4)
LPCIO
LPCIO Vendor			Nuvoton
LPCIO Model			NCT6797
LPCIO Vendor ID			0x5CA3
LPCIO Chip ID			0xD4
LPCIO Revision ID		0x51
Config Mode I/O address		0x4E
Config Mode LDN			0xB
Config Mode registers
	00	FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
	10	FF FF FF FF FF FF FF FF FF FF 30 C6 10 00 FF FF
	20	D4 51 FF 00 04 00 40 00 00 FF 40 00 02 00 00 00
	30	01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	40	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	50	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	60	0A 20 0A 30 00 00 FF FF FF FF FF FF FF FF FF FF
	70	00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space			LPC, base address = 0x0A20
Hardware Monitors
Hardware monitor		Nuvoton NCT5566/5567
	Voltage 7		0.15 Volts [0x13] (CPU SA)
	Voltage 8		1.09 Volts [0x88] (CPU VCORE)
	Voltage 9		0.24 Volts [0xF] (DRAM)
	Voltage 10		12.10 Volts [0x7E] (+12V)
	Voltage 11		5.00 Volts [0x7D] (+5V)
	Voltage 12		0.76 Volts [0x5F] (CPU I/O)
	Voltage 13		0.13 Volts [0x10] (PCH)
	Voltage 14		0.12 Volts [0xF] (VIN14)
	Voltage 15		3.36 Volts [0xD2] (+3.3V)
	Temperature 1		43 degC (108 degF) [0x55] (CPUTIN)
	Temperature 3		54 degC (129 degF) [0x36] (TMPIN3)
	Temperature 9		54 degC (129 degF) [0x36] (CPU Core)
	Fan 1			990 RPM [0x3DE] (CPU)
Hardware registers
bank 0
	00	03 93 03 64 00 FF FF FF FF FF FF FF FF FF FF FF
	10	03 00 03 00 03 00 03 7F 40 82 13 10 11 0F C1 00
	20	89 7D D0 D2 7E 12 5F 7F 03 7F FF DA 00 00 00 00
	30	00 00 00 00 00 00 00 00 00 50 4B FF FF FF FF FF
	40	03 00 07 DF FF 00 3F FF 2D FF FF 10 00 55 00 A3
	50	15 FF FF FF FF FF FF FF C1 FF FF FF FF 02 02 01
	60	55 F0 FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
	70	00 0A 00 37 00 37 00 FF 80 FF 80 FF 80 27 80 FF
	80	FF 7F 7F BF FF 05 05 05 00 00 00 00 00 00 00 00
	90	0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
	A0	0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 01 00
	B0	00 00 00 00 00 00 2B 00 04 00 00 34 28 00 04 00
	C0	FF FF FF FF FF FF FF FF FF 02 01 05 FF FF FF FF
	D0	05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
	E0	55 80 00 00 00 FF FF FF FF 00 00 00 00 00 00 00
	F0	00 00 00 00 00 00 00 FF 1C 08 66 01 5F FF FF FF
bank 4
	00	00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF
	10	FF FF FF FF FF FF FF FF FF 00 00 FF FF FF FF FF
	20	FF FF FF 96 64 96 64 E1 96 00 4B 1B E0 27 EF 01
	30	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	40	FF FF 00 40 FF FF FF FF FF FF 00 00 00 00 04 FF
	50	01 FB FF FF 00 00 00 FF FF 1E 13 31 09 00 FF FF
	60	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	70	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	80	8A 7D D0 D2 7E 12 5F D0 00 82 13 10 11 0F C1 00
	90	7F 2A 27 72 79 FD 00 2B FF 37 37 FF FF FF 1C 27
	A0	27 7F FF FF FF FF 93 64 00 00 00 00 00 00 00 00
	B0	FF 1F 2A 10 FF 1F FF 1F FF 1F FF 1F 00 00 00 00
	C0	00 00 03 E0 00 00 00 00 00 00 00 00 FF 1F 00 00
	D0	00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
	E0	93 64 00 00 00 7F 7F FF FF FF FF FF FF FF FF FF
	F0	37 40 00 00 37 00 00 00 00 00 00 00 00 00 00 FF
Hardware monitor		Nuvoton NCT7718
	Temperature 0		29 degC (84 degF) [0x1D] (TMPIN0)
Register space			SMBus, base address = 0x0EFA0
SMBus request			channel 0x0, address 0x4C
	00	1D 00 04 25 08 46 D8 46 D8 25 08 46 D8 46 D8 FF
	10	00 00 00 00 00 FF 07 FF FF 71 FF FF FF FF FF FF
	20	71 0A FF FF FF FF FF FF FF FF FF FF FF 00 00 00
	30	FF 00 00 00 00 00 46 00 D8 00 71 FF FF FF FF FF
	40	00 00 FF E0 80 00 10 A1 00 50 3C 35 52 02 02 04
	50	0A 99 1C 12 05 0A 0A 0A 84 30 10 FF 60 00 10 46
	60	46 2B 2B 0A 14 1E 28 32 3C 55 5A 28 50 78 96 B4
	70	D2 F0 19 1E 23 28 2D 32 37 3C 28 50 78 96 B4 D2
	80	F0 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
	90	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	A0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	B0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00
	C0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	D0	FF FF FF FF FF FF 00 80 00 00 11 2A 28 10 00 FF
	E0	BB BB FF FF CC FF EF EF 12 12 FF FF 12 44 FF 04
	F0	00 00 00 00 00 00 FF 25 80 02 00 30 4C 50 50 91
Hardware monitor		NVIDIA NVAPI
	Clock Speed 0		949.00 MHz [0x3B5] (Graphics)
	Clock Speed 1		4006.80 MHz [0xFA6] (Memory)
	Clock Speed 2		n.a. (Processor)
PCI Devices
Register space			PCI Express, base address = 0x0E0000000
Description			Host Bridge
Location			bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
	Vendor ID		0x8086 (Intel)
	Model ID		0x3EC2
	Revision ID		0x07
	PI			0x00
	SubClass		0x00
	BaseClass		0x06
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Subvendor ID		0x1462 (MSI)
	Subsystem ID		0x7B28
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps class		Vendor Dependant
	Caps offset		0xE0
PCI registers
	00	86 80 C2 3E 06 00 90 20 07 00 00 06 00 00 00 00
	20	00 00 00 00 00 00 00 00 00 00 00 00 62 14 28 7B
	30	00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
	40	01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00
	50	03 00 00 00 29 80 00 00 04 00 00 00 01 00 80 8F
	60	01 00 00 E0 00 00 00 00 01 80 D1 FE 00 00 00 00
	70	00 00 00 FE 03 00 00 00 00 0C 00 FE 7F 00 00 00
	80	11 11 11 11 11 11 11 00 1A 00 00 00 00 00 00 00
	90	01 00 00 FE 03 00 00 00 01 00 F0 6D 04 00 00 00
	A0	01 00 00 00 04 00 00 00 01 00 00 6E 04 00 00 00
	B0	01 00 00 90 01 00 00 90 01 00 80 8F 01 00 00 90
	E0	09 00 10 01 71 60 01 62 C8 00 04 84 00 C0 02 00
	F0	00 00 00 00 C8 0F 0A 00 00 00 00 00 00 00 00 00
Description			PCI to PCI Bridge
Location			bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
	Model ID		0x1901
	Revision ID		0x07
	PI			0x00
	SubClass		0x04
	BaseClass		0x06
	Cache Line		0x10
	Latency			0x00
	Header			0x81
PCI header
	Primary bus		0x00
	Secondary bus		0x01
	Int. Line		0x0B
	Int. Pin		0x01
PCI capability
	Caps class		Subsystem Vendor
	Caps offset		0x88
	SubVendor ID		0x1462 (MSI)
	SubSystem ID		0x7B28
PCI capability
	Caps class		Power Management
	Caps offset		0x80
	Caps version		1.2
PCI capability
	Caps class		Message Signalled Interrupts
	Caps offset		0x90
PCI capability
	Caps class		PCI Express
	Caps offset		0xA0
	Device type		Root Port of PCI-E Root Complex
	Port			2
	Caps version		2.0
	Physical slot		#0
	Presence detect		yes
	Link width		16x (max 16x)
	Link speed		8.0 GT/s (max 8.0 GT/s)
PCI extended capability
	Caps class		Virtual Channel
	Caps offset		0x100
	Caps class		Root Complex Link Declaration
	Caps offset		0x140
	Link Entries #		1
	Port Number		2
	Caps class		Secondary PCI Express
	Caps offset		0xD94
PCI registers
	00	86 80 01 19 07 04 10 00 07 00 04 06 10 00 81 00
	10	00 00 00 00 00 00 00 00 00 01 01 00 30 30 00 20
	20	00 A0 00 A3 01 90 F1 9F 00 00 00 00 00 00 00 00
	30	00 00 00 00 88 00 00 00 00 00 00 00 0B 01 18 00
	40	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	70	00 00 00 00 00 00 00 00 00 62 17 00 00 00 00 0A
	80	01 90 03 C8 08 00 00 00 0D 80 00 00 62 14 28 7B
	90	05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A0	10 00 42 01 01 80 00 00 20 00 00 00 03 AD 61 02
	B0	40 00 03 D1 80 25 0C 00 00 00 48 00 00 00 00 00
	C0	00 00 00 00 80 0B 08 00 00 64 00 00 0E 00 00 00
	D0	43 00 1E 00 00 00 00 00 00 00 00 00 00 00 00 00
	F0	00 60 01 B8 4E 01 01 20 00 00 00 00 E0 00 10 00
	100	02 00 01 14 00 00 00 00 00 00 00 00 00 00 00 00
	110	01 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
	140	05 00 41 D9 00 01 01 02 00 00 00 00 00 00 00 00
	150	01 00 01 00 00 00 00 00 00 90 D1 FE 00 00 00 00
	180	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	190	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	1A0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	1C0	01 00 41 D9 00 00 00 00 00 00 00 00 10 40 06 00
	1D0	00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00
	1F0	00 00 00 00 00 00 00 00 00 08 01 04 00 00 00 7C
Description			System Device
Location			bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
	Model ID		0x1911
	Revision ID		0x00
	PI			0x00
	SubClass		0x80
	BaseClass		0x08
	Cache Line		0x10
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xA323E000
	Subsystem ID		0x7B28
	Int. Line		0x0B
	Int. Pin		0x01
PCI capability
	Caps offset		0x90
PCI capability
	Caps offset		0xDC
	Caps version		1.1
PCI capability
	Caps class		0x13
	Caps offset		0xF0
PCI registers
	00	86 80 11 19 00 00 10 00 00 00 80 08 10 00 00 00
	10	04 E0 23 A3 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 90 00 00 00 00 00 00 00 0B 01 00 00
	40	FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	90	05 DC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 00 00 00 00 01 F0 02 00
	F0	13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
Description			Data Aquisition and Signal Processing Device
Location			bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
	Model ID		0xA379
	Revision ID		0x10
	PI			0x00
	SubClass		0x80
	BaseClass		0x11
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xA323D000
	Subsystem ID		0x7B28
	Int. Line		0x0B
	Int. Pin		0x01
PCI capability
	Caps offset		0x50
	Caps version		1.2
PCI capability
	Caps offset		0x80
PCI registers
	00	86 80 79 A3 02 00 10 00 10 00 80 11 00 00 80 00
	10	04 D0 23 A3 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 50 00 00 00 00 00 00 00 0B 01 00 00
	40	04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	50	01 80 23 00 08 00 00 00 00 00 00 00 00 00 00 00
	80	05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	90	10 00 01 00 C2 0F 00 00 40 00 00 00 11 F0 03 00
	A0	40 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00
	F0	00 00 00 00 00 00 00 00 B5 0F 11 01 00 00 00 00
Description			USB Controller (xHCI)
Location			bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
	Model ID		0xA36D
	Revision ID		0x10
	PI			0x30
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xA3220000
	Subsystem ID		0x7B28
	Int. Line		0x00
	Int. Pin		0x01
PCI capability
	Caps offset		0x70
	Caps version		1.1
PCI capability
	Caps offset		0x80
PCI capability
	Caps offset		0x90
PCI registers
	00	86 80 6D A3 06 04 90 02 10 30 03 0C 00 00 80 00
	10	04 00 22 A3 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 70 00 00 00 00 00 00 00 00 01 00 00
	40	FD 01 34 80 8F C6 FF 83 00 00 00 00 00 00 00 00
	50	7F 6D DC 0F 00 00 00 00 75 07 BD 28 00 00 00 00
	60	31 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	70	01 80 C2 C1 08 00 00 00 00 00 00 00 00 00 00 00
	80	05 90 87 00 0C F0 E3 FE 00 00 00 00 91 49 00 00
	90	09 00 14 F0 10 00 40 01 00 00 00 00 C1 0A 08 00
	A0	00 08 0E 00 00 18 00 00 8F 40 02 00 00 01 00 00
	B0	03 00 00 00 0C 00 00 00 30 00 00 00 C0 00 00 00
	C0	00 21 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D0	0C 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00
	F0	00 00 00 00 00 00 00 00 B5 0F 11 01 12 00 00 00
Description			RAM Memory Controller
Location			bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
	Model ID		0xA36F
	Revision ID		0x10
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x10
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xA3236000
	Address 2 (memory)	0xA323C000
	Subvendor ID		0x8086 (Intel)
	Subsystem ID		0x7270
	Int. Line		0xFF
	Int. Pin		0x00
PCI capability
	Caps offset		0x80
	Caps version		1.2
PCI registers
	00	86 80 6F A3 00 00 10 00 10 00 00 05 10 00 00 00
	10	04 60 23 A3 00 00 00 00 04 C0 23 A3 00 00 00 00
	20	00 00 00 00 00 00 00 00 00 00 00 00 86 80 70 72
	30	00 00 00 00 80 00 00 00 00 00 00 00 FF 00 00 00
	80	01 00 03 00 08 00 00 00 00 00 00 00 00 00 00 00
Description			Communication Device
Location			bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
	Model ID		0xA360
	Revision ID		0x10
	PI			0x00
	SubClass		0x80
	BaseClass		0x07
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xFE1FF000
	Subsystem ID		0x7B28
	Int. Line		0x00
	Int. Pin		0x01
PCI capability
	Caps offset		0x50
	Caps version		1.2
PCI capability
	Caps offset		0x8C
PCI capability
	Caps offset		0xA4
PCI registers
	00	86 80 60 A3 06 04 10 00 10 00 80 07 00 00 80 00
	10	04 F0 1F FE 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
	40	55 02 00 90 00 00 00 80 00 01 85 32 00 00 00 00
	50	01 8C 03 40 08 00 00 00 00 00 00 00 00 00 00 00
	60	20 00 00 00 00 48 00 00 00 00 00 00 06 00 00 00
	70	00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00
	80	00 00 00 00 00 00 00 00 00 00 00 00 05 A4 81 00
	90	0C F0 E3 FE 00 00 00 00 71 49 00 00 00 00 00 00
	A0	04 00 00 00 09 00 14 F0 10 00 40 01 00 00 00 00
	B0	01 80 00 00 38 0D 0E 00 00 00 00 00 00 00 00 40
Description			Serial ATA Controller - AHCI
Location			bus 0 (0x00), device 23 (0x17), function 0 (0x00)
Common header
	Model ID		0xA352
	Revision ID		0x10
	PI			0x01
	SubClass		0x06
	BaseClass		0x01
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xA3234000
	Address 1 (memory)	0xA323A000
	Address 2 (port)	0x00004050
	Address 3 (port)	0x00004040
	Address 4 (port)	0x00004020
	Address 5 (memory)	0xA3239000
	Subsystem ID		0x7B28
	Int. Line		0x00
	Int. Pin		0x01
PCI capability
	Caps offset		0x80
PCI capability
	Caps offset		0x70
	Caps version		1.2
PCI capability
	Caps class		Serial ATA Configuration
	Caps offset		0xA8
PCI registers
	00	86 80 52 A3 07 04 B0 02 10 01 06 01 00 00 00 00
	10	00 40 23 A3 00 A0 23 A3 51 40 00 00 41 40 00 00
	20	21 40 00 00 00 90 23 A3 00 00 00 00 62 14 28 7B
	30	00 00 00 00 80 00 00 00 00 00 00 00 00 01 00 00
	40	00 00 21 01 00 0C 00 00 1F 00 20 01 00 0C 00 00
	70	01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00
	80	05 70 01 00 0C F0 E3 FE 50 49 00 00 00 00 00 00
	90	00 00 F8 00 07 00 07 00 00 00 00 00 30 00 00 80
	A0	3C 00 00 00 00 00 00 00 12 00 10 00 48 00 00 00
	D0	11 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
Description			PCI to ISA Bridge
Location			bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
	Model ID		0xA303
	Revision ID		0x10
	PI			0x00
	SubClass		0x01
	BaseClass		0x06
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subsystem ID		0x7B28
	Int. Line		0x00
	Int. Pin		0x00
PCI registers
	00	86 80 03 A3 07 00 00 02 10 00 01 06 00 00 80 00
	60	00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00
	80	70 00 0E 3F 01 02 FC 00 01 0A 3C 00 E1 03 0C 00
	90	E1 02 1C 00 00 00 00 00 00 00 00 00 00 00 00 00
	D0	33 22 11 00 67 45 00 00 CF FF 00 00 80 00 00 00
	E0	09 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description			High Definition Audio (HDA)
Location			bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
	Model ID		0xA348
	Revision ID		0x10
	PI			0x00
	SubClass		0x03
	BaseClass		0x04
	Cache Line		0x10
	Latency			0x20
	Header			0x00
PCI header
	Address 0 (memory)	0xA3230000
	Address 4 (memory)	0xA3100000
	Subsystem ID		0xEB28
	Int. Line		0x10
	Int. Pin		0x01
PCI capability
	Caps offset		0x50
	Caps version		1.2
PCI capability
	Caps offset		0x80
PCI capability
	Caps offset		0x60
PCI registers
	00	86 80 48 A3 00 04 10 00 10 00 03 04 10 20 00 00
	10	04 00 23 A3 00 00 00 00 00 00 00 00 00 00 00 00
	20	04 00 10 A3 00 00 00 00 00 00 00 00 62 14 28 EB
	30	00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
	40	00 00 00 00 00 00 00 00 FF 09 7B 00 00 00 00 00
	50	01 80 43 C0 0B 00 00 00 00 00 00 00 00 00 00 00
	60	05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
	70	10 00 91 00 00 00 00 10 00 28 10 00 00 00 00 00
	80	09 60 14 F0 10 00 40 01 00 00 00 00 A1 04 01 00
	90	00 08 08 00 00 00 00 00 00 00 00 00 00 00 00 00
	C0	08 06 02 21 00 60 80 04 00 0C A5 82 10 00 03 00
	D0	00 0C B5 02 10 00 03 00 00 00 00 00 00 00 00 00
Description			SMBus Controller
Location			bus 0 (0x00), device 31 (0x1F), function 4 (0x04)
Common header
	Model ID		0xA323
	Revision ID		0x10
	PI			0x00
	SubClass		0x05
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xA3238000
	Address 4 (port)	0x0000EFA0
	Subsystem ID		0x7B28
	Int. Line		0x10
	Int. Pin		0x01
PCI registers
	00	86 80 23 A3 03 00 80 02 10 00 05 0C 00 00 00 00
	10	04 80 23 A3 00 00 00 00 00 00 00 00 00 00 00 00
	20	A1 EF 00 00 00 00 00 00 00 00 00 00 62 14 28 7B
	30	00 00 00 00 00 00 00 00 00 00 00 00 10 01 00 00
	40	01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	50	01 04 00 00 01 01 00 00 00 00 00 00 00 00 00 00
	60	04 05 05 00 00 00 0A 0A 00 00 00 00 00 00 00 00
	80	24 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	90	00 00 21 01 00 0C 00 00 17 00 20 01 00 0C 00 00
Description			Serial Bus Controller
Location			bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Common header
	Model ID		0xA324
	Revision ID		0x10
	PI			0x00
	SubClass		0x80
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xFE010000
	Subsystem ID		0x7B28
	Int. Line		0x00
	Int. Pin		0x00
PCI registers
	00	86 80 24 A3 02 04 00 00 10 00 80 0C 00 00 00 00
	10	00 00 01 FE 00 00 00 00 00 00 00 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 CF FF 00 00 88 08 00 00
Description			Ethernet Controller
Location			bus 0 (0x00), device 31 (0x1F), function 6 (0x06)
Common header
	Model ID		0x15BC
	Revision ID		0x10
	PI			0x00
	SubClass		0x00
	BaseClass		0x02
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xA3200000
	Subsystem ID		0x7B28
	Int. Line		0x00
	Int. Pin		0x01
PCI capability
	Caps offset		0xC8
	Caps version		1.2
PCI capability
	Caps offset		0xD0
PCI registers
	00	86 80 BC 15 06 04 10 00 10 00 00 02 00 00 00 00
	10	00 00 20 A3 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 C8 00 00 00 00 00 00 00 00 01 00 00
	80	28 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00
	90	00 00 00 00 1F 00 00 00 00 00 00 00 00 00 00 00
	A0	00 00 00 00 01 00 00 00 03 10 03 10 00 00 00 00
	C0	00 00 00 00 00 00 00 00 01 D0 23 C8 08 21 00 00
	D0	05 00 81 00 0C 10 E0 FE 00 00 00 00 B1 49 00 00
	E0	13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
Description			VGA Controller
Location			bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
	Vendor ID		0x10DE (NVIDIA)
	Model ID		0x1B81
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x03
	Cache Line		0x10
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xA2000000
	Address 1 (memory)	0x90000000
	Address 3 (memory)	0xA0000000
	Address 5 (port)	0x00003000
	Subsystem ID		0x3301
	Int. Line		0x10
	Int. Pin		0x01
PCI capability
	Caps offset		0x60
	Caps version		1.2
PCI capability
	Caps offset		0x68
PCI capability
	Caps offset		0x78
	Device type		Legacy PCI-E Endpoint Device
	Port			0
	Caps version		2.0
	Caps offset		0x100
	Caps class		0x18
	Caps offset		0x250
	Caps class		Power Budgeting
	Caps offset		0x128
	Caps class		Advanced Error Reporting
	Caps offset		0x420
	Caps class		Vendor Specific
	Caps offset		0x600
	Vendor			1
	Size			36
	Caps offset		0x900
PCI registers
	00	DE 10 81 1B 07 00 10 00 A1 00 00 03 10 00 80 00
	10	00 00 00 A2 0C 00 00 90 00 00 00 00 0C 00 00 A0
	20	00 00 00 00 01 30 00 00 00 00 00 00 62 14 01 33
	30	00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
	40	62 14 01 33 00 00 00 00 00 00 00 00 00 00 00 00
	50	01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
	60	01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
	70	00 00 00 00 00 00 00 00 10 00 12 00 E1 8D 2C 01
	80	30 21 09 00 03 4D 45 00 40 01 03 11 00 00 00 00
	90	00 00 00 00 00 00 00 00 00 00 00 00 13 08 04 00
	A0	00 04 00 00 0E 00 00 00 03 00 1F 00 00 00 00 00
	B0	00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
	100	02 00 01 25 00 00 00 00 00 00 00 00 00 00 00 00
	110	00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
	120	00 00 00 00 00 00 00 00 04 00 01 42 00 00 00 00
	130	21 81 07 00 00 00 00 00 00 00 00 00 00 00 00 00
	140	00 00 00 00 30 00 00 01 00 00 00 00 1B 00 00 8B
	150	95 01 00 E0 40 71 50 06 00 00 00 00 21 81 07 00
	160	21 81 05 00 02 80 03 00 02 80 01 00 06 80 1F 00
	170	06 80 1D 00 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
	Model ID		0x10F0
	Revision ID		0xA1
	PI			0x00
	SubClass		0x03
	BaseClass		0x04
	Cache Line		0x10
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xA3080000
	Subsystem ID		0x3301
	Int. Line		0x11
	Int. Pin		0x02
PCI capability
	Caps offset		0x60
	Caps version		1.2
PCI capability
	Caps offset		0x68
PCI capability
	Caps offset		0x78
	Device type		PCI-E Endpoint Device
	Port			0
	Caps version		2.0
	Caps offset		0x100
PCI registers
	00	DE 10 F0 10 06 00 10 00 A1 00 03 04 10 00 80 00
	10	00 00 08 A3 00 00 00 00 00 00 00 00 00 00 00 00
	20	00 00 00 00 00 00 00 00 00 00 00 00 62 14 01 33
	30	00 00 00 00 60 00 00 00 00 00 00 00 11 02 00 00
	50	00 00 00 00 00 00 00 00 CE D6 23 00 00 00 00 00
	70	00 00 00 00 00 00 00 00 10 00 02 00 E1 8D 2C 01
	80	30 29 09 00 03 4D 45 00 03 01 03 11 00 00 00 00
	A0	00 00 00 00 0E 00 00 00 00 00 01 00 00 00 00 00
	100	01 00 02 00 00 00 00 00 00 00 00 00 30 20 46 00
	110	00 20 00 00 00 A0 00 00 00 00 00 00 00 00 00 00
	140	00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 03
	150	00 00 00 E0 20 71 10 00 00 00 00 00 0F 00 00 00
DMI
SMBIOS Version			2.8
DMI BIOS
	vendor			American Megatrends Inc.
	version			1.30
	date			07/18/2018
	ROM size		16384 KB
DMI System Information
	manufacturer		Micro-Star International Co. Ltd.
	product			MS-7B28
	version			1.0
	serial			Default string
	UUID			{00000000-0000-0000-0000-309C23D10517}
	SKU			Default string
	family			Default string
DMI Baseboard
	vendor			Micro-Star International Co. Ltd.
	model			H310M GAMING PLUS (MS-7B28)
	revision		1.0
	serial			I516624577
DMI System Enclosure
	chassis type		Desktop
	chassis serial		Default string
DMI Port Connector
	designation		J1A1 (internal)
	designation		PS2Mouse (external)
	port type		Mouse Port
	connector		PS/2
DMI Port Connector
	designation		Keyboard (external)
	port type		Keyboard Port
	connector		PS/2
DMI Port Connector
	designation		J2A1 (internal)
	designation		TV Out (external)
	connector		Mini Centronics Type-14
DMI Port Connector
	designation		J2A2A (internal)
	designation		COM A (external)
	port type		Serial Port 16550A
	connector		DB-9 male
DMI Port Connector
	designation		J2A2B (internal)
	designation		Video (external)
	port type		Video Port
	connector		DB-15 female
DMI Port Connector
	designation		J3A1 (internal)
	designation		USB1 (external)
	port type		USB
	connector		Access Bus (USB)
DMI Port Connector
	designation		J9A1 - TPM HDR (internal)
DMI Port Connector
	designation		J9C1 - PCIE DOCKING CONN (internal)
DMI Port Connector
	designation		J2B3 - CPU FAN (internal)
DMI Port Connector
	designation		J6C2 - EXT HDMI (internal)
DMI Port Connector
	designation		J3C1 - GMCH FAN (internal)
DMI Port Connector
	designation		J1D1 - ITP (internal)
DMI Port Connector
	designation		J9E2 - MDC INTPSR (internal)
DMI Port Connector
	designation		J9E4 - MDC INTPSR (internal)
DMI Port Connector
	designation		J9E3 - LPC HOT DOCKING (internal)
DMI Port Connector
	designation		J9E1 - SCAN MATRIX (internal)
DMI Port Connector
	designation		J9G1 - LPC SIDE BAND (internal)
DMI Port Connector
	designation		J8F1 - UNIFIED (internal)
DMI Port Connector
	designation		J6F1 - LVDS (internal)
DMI Port Connector
	designation		J2F1 - LAI FAN (internal)
DMI Port Connector
	designation		J2G1 - GFX VID (internal)
DMI Port Connector
	designation		J1G6 - AC JACK (internal)
DMI Extension Slot
	designation		J6B2
	type			PCI Express
	populated		yes
DMI Extension Slot
	designation		J6B1
	type			PCI Express
	populated		yes
DMI Extension Slot
	designation		J6D1
	type			PCI Express
	populated		yes
DMI Extension Slot
	designation		J7B1
	type			PCI Express
	populated		yes
DMI Extension Slot
	designation		J8B4
	type			PCI Express
	populated		yes
DMI Extension Slot
	designation		J8D1
	type			PCI Express
	populated		yes
DMI Extension Slot
	designation		J8B3
	type			PCI
	width			32 bits
	populated		yes
DMI OEM Strings
	string[0]		Default string
DMI Physical Memory Array
	location		Motherboard
	usage			System Memory
	correction		None
	max capacity		64 GB
	max# of devices		4
DMI Memory Device
	designation		ChannelA-DIMM0
	format			DIMM
	type			DDR4
	total width		64 bits
	data width		64 bits
	size			8 GB
DMI Memory Device
	designation		ChannelA-DIMM1
	format			unknown
	type			unknown
DMI Memory Device
	designation		ChannelB-DIMM0
	format			DIMM
	type			DDR4
	total width		64 bits
	data width		64 bits
	size			8 GB
DMI Memory Device
	designation		ChannelB-DIMM1
	format			unknown
	type			unknown
DMI Processor
	manufacturer		Intel(R) Corporation
	model			Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
	clock speed		2772.0 MHz
	FSB speed		100.0 MHz
	multiplier		27.5x
	max clock speed		8300.0 MHz
Storage
Drive	0
	Device Path		\\?\scsi#disk&ven_kingston&prod_#4&345b9e13&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
	Name			KINGSTON SA400S37240G
	Revision		S3700100
	Serial			50026B7380D80F5E
	Capacity		223.6 GB
	Type			Fixed, SSD
	Bus Type		SATA (11)
	Features		SMART, TRIM
	Controller		Serial ATA Controller - AHCI at bus 0, device 23, function 0
	Volume			c:\, 222.9 GBytes (10.5 percent available)
Drive	1
	Device Path		\\?\scsi#disk&ven_st1000dm&prod_010-2ep102#4&345b9e13&0&000100#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
	Name			ST1000DM010-2EP102
	Revision		CC43
	Serial			            Z9AXLJXS
	Capacity		931.5 GB
	Type			Fixed
	Bus Type		SATA (11)
	Rotation speed		7200 RPM
	Features		SMART
	Volume			d:\, 930.9 GBytes (37.9 percent available)
USB Devices
USB Device			USB Composite Device, class=0x00, subclass=0x00, vendor=0x1532, product=0x006E
USB Device			USB Composite Device, class=0x00, subclass=0x00, vendor=0x1A2C, product=0x4C5E
USB Device			USB Mass Storage Device, class=0x00, subclass=0x00, vendor=0x058F, product=0x6387
Graphics
Number of adapters		1
Graphic APIs
API				D3D
API				NVIDIA I/O
API				NVIDIA NVAPI
Display Adapters
Display adapter 0
	ID			0x1090304
	Name			NVIDIA GeForce GTX 1070
	Board Manufacturer	Micro-Star International Co., Ltd. (MSI)
	Revision		A1
	Codename		GP104-200
	Core family		0x134 (GP104-A)
	TDP			150.0 W
	Cores			1920
	ROP Units		64
	TM Units		120
	Technology		16 nm
	Memory type		GDDR5 (Micron)
	Memory size		8 GB
	Memory bus width	256 bits
	PCI device		bus 1 (0x1), device 0 (0x0), function 0 (0x0)
		Vendor ID	0x10DE (0x1462)
		Model ID	0x1B81 (0x3301)
		Revision ID	0xA1
	Root device		bus 0 (0x0), device 1 (0x1), function 0 (0x0)
	Performance Level	Base
		Core clock	1531.0 MHz
		Memory clock	4004.0 MHz
	Performance Level	Boost
		Core clock	1721.0 MHz
	Performance Level	Current
		Core clock	949.0 MHz
		Memory clock	4006.8 MHz
	Driver version		30.0.15.1259
	WDDM Model		3.0
Win32_VideoController		AdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoController		DriverVersion = 30.0.15.1259
Win32_VideoController		DriverDate = 04/20/2022
Monitor 0
	Model			MP59G (LG Electronics (GoldStar))
	ID			GSM5B34
	Serial
	Manufacturing Date	Week 9, Year 2021
	Size			21.7 inches
	Max Resolution		1920 x 1080 @ 74 Hz
	Horizontal Freq. Range	30-85 kHz
	Vertical Freq. Range	40-75 Hz
	Max Pixel Clock		180 MHz
	Gamma Factor		2.2
Monitor 1
	Model			VG245 ()
	ID			AUS24A1
	Serial			H9LMQS008182
	Manufacturing Date	Week 36, Year 2017
	Size			24.0 inches
	Max Resolution		1920 x 1080 @ 60 Hz
	Horizontal Freq. Range	30-90 kHz
	Max Pixel Clock		250 MHz
	Gamma Factor		2.2
Software
Windows Version			Microsoft Windows 11 (10.0) Home 64-bit   (Build 22000)
DirectX Version			12.0
Register Spaces
Register space			PCI
Register space			PCI #2
Register space			LPC, base address = 0x04E
its not clear if you mean booting into live usb is stuck, or the actuall installation?
is it dual boot?
The usb boots the.uhh, interface that says boot from proprietary drivers and stuff, but when I select boot from proprietary drivers and get to this point it just gets stuck…
I hope it’s alright to send the image like this htt ps://pas teboard.c o/lP7cBGp L3Lgu.png
I’m sorry but I can’t really put this in words since I’m not familiar with CS terms…
Also really love your Shiva profile picture :smiley:
you can post link inside of this icon </>… so booting into the live usb is stuck… did you try booting by selecting free drivers instead of proprietary… and is it a dual boot? … thanks for the pic haha
Oh, just tried the proprietary choice, should I go for the free drivers also?
And…sorry, I do not know what do you mean by dual boot, I want to replace windows with linux if that helps in anyway…
EDIT: for some reason I can’t post links, might be because my account is new
dual boot means running manjaro alongside other OS in your case windows… so you have windows installed, so probably it is related to bios setting, and also how you booted your usb - bios or uefi… so first download ventoy and use ventoy to flash your iso onto usb, and check this ‘preparation’ check list:
Firmware checklist for BIOS systems
  • :white_small_square: Use latest available firmware
  • :white_small_square: Disable EFI
  • :white_small_square: Disable RAID option
  • :white_small_square: Enable AHCI
Firmware checklist for EFI Systems
  • :white_small_square: Disable CSM (Legacy) boot
  • :white_small_square: Disable Secure Boot
  • :white_small_square: Disable Optane Memory and Rapid Storage Technology (RST)
  • :white_small_square: Disable Fast Boot (if unable to boot from USB)
Thank you!
I’ll give it a try and be back :smiley:
I think it’s because of the Nvidia driver but could also be a hardware issue - I also had issues with Lubuntu, Kubuntu and even Pop_OS! in live mode, before starting the installation and during it. It was freezing, sometimes seeing some things on the screen like artifacts (which is GPU error). I had to use an older driver, and I used Manjaro GUI for this.
I modified also the grub folder with GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pci=nomsi pci=noaer" - for resolving an MSI issue (some PCI hardware not working properly)
Now, I am no expert but maybe someone from this forum can provide you with a similar command that can be done from TTY before starting the installation.
select gnome on xorg and see if that works
you are not installing anything yet, you are only booting into the live session… and do you have installed windows on that pc?
so disable fast boot - check for it in windows, it also may be in bios
disable secure boot - its in bios
use Ventoy to flash iso on usb
So if it is really a problem of the gpu driver, then try this:
If that works, then one can assume, that its a problem of the gpu driver.
