Hello!! ![]()
I think this is the last quirk to iron in my migration from KDE to Gnome on my little ThinkPad.
I’m experiencing some annoying little freezes randomly, I can’t move the cursor during 4 o 5 seconds, regardless of I use the mouse, trackpad, or pointer. After a few moments, everything continues normal.
In my previous KDE install, this issue didn’t happen.
This is the output to inxi -Fazy:
Kernel: 6.7.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=60a9bdd0-965e-4b5a-80cd-98ea2c6bd70e rw quiet splash apparmor=1
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 20KFS0YM08 v: ThinkPad X280
Mobo: LENOVO model: 20KFS0YM08 v: SDK0J40697 WIN
serial: <superuser required>
part-nu: LENOVO_MT_20KF_BU_Think_FM_ThinkPad X280
uuid: <superuser required> UEFI: LENOVO v: N20ET67W (1.52 )
date: 11/15/2023
ID-1: BAT0 charge: 35.7 Wh (79.3%) condition: 45.0/47.9 Wh (94.0%)
volts: 12.2 min: 11.4 model: LGC 5B10W13920 type: Li-poly serial: <filter>
status: not charging cycles: 196
Info: model: Intel Core i3-8130U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1150 high: 3401 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3401 2: 400 3: 400 4: 400
bogomips: 17605
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: Lite-On Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04ca:7070
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x226d built: 2015 res: 1920x1080
dpi: 177 gamma: 1.2 size: 276x155mm (10.87x6.1") diag: 317mm (12.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
device-ID: 8086:5917 memory: 7.35 GiB unified: yes display-ID: :0.0
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.7.7-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 3b:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
Info: services: httpd, NetworkManager, smbd, systemd-timesyncd,
wpa_supplicant
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 357.72 GiB used: 93.23 GiB (26.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-000L7
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 1L2QEXD7 temp: 29.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Generic model: SD MMC size: 119.25 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 1.00
scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 69.87 GiB (29.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 4 GiB used: 35.8 MiB (0.9%) priority: -2
file: /swapfile
System Temperatures: cpu: 43.0 C pch: 43.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Memory: total: 8 GiB note: est. available: 7.52 GiB used: 4.74 GiB (63.0%)
Processes: 272 Power: uptime: 18h 16m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 3 GiB services: gsd-power,
tool: systemctl
Packages: pm: pacman pkgs: 1333 libs: 373 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash
v: 5.2.26 running-in: gnome-terminal inxi: 3.3.33
I’ve searched in the forum, there are a lot of threads about freeze issues, but none like mine.
What info extra could apport?
Best regards!! ![]()
