Good day all,
I hope this hasn’t been asked too many times, I’m using an Asus Chromebook C223 which uses the Intel N3350 - bluetooth audio works fine, I haven’t yet been able to test the audio jack but the built-in speakers definitely are not working and the only output I have in settings is “Dummy Output”
I have used mrchromebox to replace the firmware and am running the latest stable manjaro gnome distro, ChromeOS has been completely erased.
inxi -Frazy shows the following:
(removed as was being marked as a link is places - will try to post in comments)
aplay -l shows the following:
aplay: device_list:274: no soundcards found…
Thank you in advance to anyone who can enlighten me in any manner.
Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Type: Laptop System: Google product: Coral v: rev5 serial: Chassis:
type: 9 serial: N/A
Mobo: Google model: Coral v: rev5 serial: BIOS: coreboot v: N/A
date: 11/27/2018
Info: Dual Core model: Intel Celeron N3350 bits: 64 type: MCP arch: Goldmont
family: 6 model-id: 5C (92) stepping: 9 microcode: 44 cache: L2: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 4378
Speed: 1951 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 1951 2: 2188
Type: spec_store_bypass status: Not affected
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Imaging Unit
driver: N/A bus-ID: 00:03.0 chip-ID: 8086:5a88 class-ID: 0480
Device-2: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
driver: snd_soc_skl v: kernel alternate: snd_hda_intel,snd_sof_pci
bus-ID: 00:0e.0 chip-ID: 8086:5a98 class-ID: 0401
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
aplay -l 99 ✘
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
alsactl init
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel PCH at 0xc2b18000 irq 127)
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -6
Found hardware: “HDA-Intel” “Intel Broxton HDMI” “HDA:8086280a,80860101,00100000” “0x8086” “0x7270”
Hardware is initialized using a generic method
