william@william-hpzbook ~> nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
william@william-hpzbook ~ [9]> paru nvidia|grep 已安装
225 aur/mhwd-nvidia-390xx 390.143-1 [+1 ~0.78] [已安装: 390.144-1]
201 aur/mhwd-nvidia 495.44-1 [+2 ~0.25] [已安装: 470.63.01-1]
33 extra/nvidia-utils 470.63.01-2 [0B 444.48MiB] [已安装]
32 extra/nvidia-prime 1.0-4 [0B 112B] [已安装]
31 extra/nvidia-dkms 470.63.01-1 [0B 46.92MiB] [已安装]
21 extra/linux513-nvidia 470.63.01-14 [0B 39.64MiB] [已安装] (linux513-extramodules)
6 extra/libxnvctrl 470.63.01-1 [0B 456.74KiB] [已安装]
5 extra/libvdpau 1.4-1 [60.61KiB 265.58KiB] [已安装]
3 extra/egl-wayland 1:1.1.7-1 [0B 65.01KiB] [已安装]
2 core/mhwd-nvidia-390xx 390.144-1 [2.64KiB 1.90KiB] [已安装]
1 core/mhwd-nvidia 470.63.01-1 [0B 1.65KiB] [已安装]
nvidia-bug-report.log.gz
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see forums.developer.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 30255326
Date: 2021年 11月 17日 星期三 14:04:44 CST
uname: Linux william-hpzbook 5.13.19-2-MANJARO #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021 x86_64 GNU/Linux
command line flags:
*** /sys/bus/pci/devices/0000:01:00.0/power/control
*** ls: -rw-r–r-- 1 root root 4096 2021-11-17 13:55:09.833333060 +0800 /sys/bus/pci/devices/0000:01:00.0/power/control
on
*** /sys/bus/pci/devices/0000:01:00.0/power/runtime_status
*** ls: -r–r–r-- 1 root root 4096 2021-11-17 14:04:44.433908008 +0800 /sys/bus/pci/devices/0000:01:00.0/power/runtime_status
active
*** /sys/bus/pci/devices/0000:01:00.0/power/runtime_usage does not exist
*** /sys/bus/pci/devices/0000:01:00.1/power/control
*** ls: -rw-r–r-- 1 root root 4096 2021-11-17 13:55:09.836666393 +0800 /sys/bus/pci/devices/0000:01:00.1/power/control
on
*** /sys/bus/pci/devices/0000:01:00.1/power/runtime_status
*** ls: -r–r–r-- 1 root root 4096 2021-11-17 14:04:44.440576598 +0800 /sys/bus/pci/devices/0000:01:00.1/power/runtime_status
active
*** /sys/bus/pci/devices/0000:01:00.1/power/runtime_usage does not exist
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 30 2021-01-21 00:33:43.000000000 +0800 /etc/issue
Manjaro Linux \r (\n) (\l)
*** /var/log/nvidia-installer.log does not exist
/sbin/systemctl status nvidia-suspend.service nvidia-hibernate.service nvidia-resume.service
○ nvidia-suspend.service - NVIDIA system suspend actions
Loaded: loaded (/usr/lib/systemd/system/nvidia-suspend.service; disabled; vendor preset: disabled)
Active: inactive (dead)
○ nvidia-hibernate.service - NVIDIA system hibernate actions
Loaded: loaded (/usr/lib/systemd/system/nvidia-hibernate.service; disabled; vendor preset: disabled)
○ nvidia-resume.service - NVIDIA system resume actions
Loaded: loaded (/usr/lib/systemd/system/nvidia-resume.service; disabled; vendor preset: disabled)
journalctl -b -0 _COMM=Xorg
– Journal begins at Fri 2021-11-12 10:11:38 CST, ends at Wed 2021-11-17 14:04:44 CST. –
– No entries –
journalctl -b -1 _COMM=Xorg
– No entries –
journalctl -b -2 _COMM=Xorg
– No entries –
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
– No entries –
journalctl -b -2 _COMM=Xorg.bin
– No entries –
– No entries –
– No entries –
– No entries –
journalctl -b -0 _COMM=gdm-x-session
– No entries –
journalctl -b -1 _COMM=gdm-x-session
– No entries –
journalctl -b -2 _COMM=gdm-x-session
– No entries –
/sbin/coredumpctl info COREDUMP_COMM=Xorg COREDUMP_COMM=Xorg.bin COREDUMP_COMM=X
*** /usr/share/nvidia/nvidia-application-profiles-470.63.01-rc
*** ls: -rw-r–r-- 1 root root 9082 2021-10-01 02:44:11.000000000 +0800 /usr/share/nvidia/nvidia-application-profiles-470.63.01-rc
Application profiles for the NVIDIA Linux graphics driver, version 470.63.01
Last modified: Tue Aug 3 20:28:33 UTC 2021
These profiles were provided by NVIDIA and should not be modified. If you
wish to change the defaults provided here, you can override them by creating
custom rules in /etc/nvidia/nvidia-application-profiles-rc (which will apply
system-wide) or, for a given user, $HOME/.nv/nvidia-application-profiles-rc
(which will apply to that particular user). See the "APPLICATION PROFILE
SEARCH PATH" section of the NVIDIA Linux Graphics Driver README for more
information.
“profiles” : [
“name” : “NonConformantBlitFramebufferScissor”,
“settings” : [ “GLConformantBlitFramebufferScissor”, false ]
“name” : “CL1C”,
“settings” : [ “0x528ab3”, 1 ]
“name” : “FA0”,
“settings” : [ “10572898”, 0 ]
“name” : “ExactGLESVersion”,
“settings” : [ “ForceRequestedESVersion”, 1 ]
“name” : “IgnoreGLSLExtensionRequirements”,
“settings” : [ “GLIgnoreGLSLExtReqs”, true ]
“name” : “No VRR/OSD”,
“settings” : [
“key” : “GLVRRAllowed”,
“value” : false
“key” : “VKDirectGSYNCAllowed”,
“value” : false
“key” : “VKDirectGSYNCCompatibleAllowed”,
“value” : 0
“key” : “GLShowGraphicsOSD”,
“value” : false
“name” : “UseThreadedOptimizations”,
“settings” : [ “GLThreadedOptimizations”, true ]
“name” : “NoThreadedOptimizations”,
“settings” : [ “GLThreadedOptimizations”, false ]
“name” : “NoAniso”,
“settings” : [ “GLLogMaxAniso”, 0 ]
“name” : “NamedVertexAttributesApplyDivisor”,
“settings” : [ “GL23cd0e”, 1 ]
“name” : “NonStrictDrawRangeElements”,
“settings” : [ “GLStrictDrawRangeElements”, false ]
“name” : “NoEnforceShaderInputOutputMatching”,
“settings” : [ “GLShaderPortabilityWarnings”, false ]
“name” : “HideVendorID”,
“settings” : [ “OVERRIDE_VENDORID”, 4098 ]
“name” : “DisablePersampleFragcoord”,
“settings” : [ “DisablePersampleFragcoord”, true ]
“name” : “ForceSeparateTrimThread”,
“settings” : [ “__GL_CPMM”, 3 ]
“name” : “IdleQueueOnSwapchainOOD”,
“settings” : [ “IdleQueueOnSwapchainOOD”, true ]
“name” : “DisableHostVisibleVidmem”,
“settings” : [ “HostVisibleVidmem”, false ]
“rules” : [
“pattern” : {
“feature” : “dso”,
“matches” : “libcogl.so”
“profile” : “NonConformantBlitFramebufferScissor”
“pattern” : {
“feature” : “dso”,
“matches” : “libMaya.so”
“profile” : “CL1C”
“pattern” : {
“feature” : “dso”,
“profile” : “NamedVertexAttributesApplyDivisor”
{ “pattern” : “SkullGirls.x86_64-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “SkullGirls.i686-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “Indivisible_Linux.i686-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “xsi”, “profile” : “CL1C” },
{ “pattern” : “HoudiniFX”, “profile” : “CL1C” },
{ “pattern” : “katana”, “profile” : “CL1C” },
{ “pattern” : “Autodesk Mudbox 2014 64-bit”, “profile” : “CL1C” },
{ “pattern” : “octane”, “profile” : “CL1C” },
{ “pattern” : “Fusion64_6.4”, “profile” : “CL1C” },
{ “pattern” : “Nuke7.0”, “profile” : “CL1C” },
{ “pattern” : “vray.exe”, “profile” : “CL1C” },
{ “pattern” : “vray.bin”, “profile” : “CL1C” },
{ “pattern” : “kwin_gles”, “profile” : “FA0” },
{ “pattern” : “kwin_gles”, “profile” : “ExactGLESVersion” },
“pattern” : [
{ “feature” : “procname”, “matches” : “heaven_x86”},
{ “op” : “not”, “sub” : { “feature” : “findfile”, “matches” : “browser_x86” } }
“profile” : “IgnoreGLSLExtensionRequirements”
“pattern” : [
{ “feature” : “procname”, “matches” : “heaven_x64”},
{ “op” : “not”, “sub” : { “feature” : “findfile”, “matches” : “browser_x64” } }
{ “pattern” : { “feature” : “procname”, “matches” : “cinnamon” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “compiz” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “compton” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “enlightenment” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “gnome-shell” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “kscreenlocker_greet” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “kwin” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “kwin_x11” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “picom” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “plasmashell” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “ksplashqml” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “systemsettings5” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “muffin” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “dso”, “matches” : “libmutter” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “steam” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “steamcompmgr” }, “profile” : “No VRR/OSD” },
{ “pattern” : { “feature” : “procname”, “matches” : “vrmonitor” }, “profile” : “No VRR/OSD” },
{ “pattern” : “GoatGame”, “profile” : “NonStrictDrawRangeElements” },
{ “pattern” : “ShadowOfMordor”, “profile” : “NoEnforceShaderInputOutputMatching” },
{ “pattern” : { “feature” : “commname”, “matches” : “NMS.exe”} , “profile” : “HideVendorID” },
{ “pattern” : “shotcut”, “profile” : “NoThreadedOptimizations” },
{ “pattern” : “MetroLL”, “profile” : “NoThreadedOptimizations” },
{ “pattern” : “Borderlands2”, “profile” : “UseThreadedOptimizations” },
{ “pattern” : “BorderlandsPreSequel”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “AlienIsolation”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “Civ6”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “CivBE”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “overlord.i386”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “X-Plane-x86_64”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “RocketLeague”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “DeusExMD”, “profile” : “DisablePersampleFragcoord” },
{ “pattern”: “firefox”, “profile” : “ForceSeparateTrimThread” },
{ “pattern”: “Dirt4”, “profile” : “IdleQueueOnSwapchainOOD” },
{ “pattern”: “RiseOfTheTombRaider”, “profile” : “IdleQueueOnSwapchainOOD” },
{ “pattern”: “ShadowOfTheTombRaider”, “profile” : “IdleQueueOnSwapchainOOD” },
{ “pattern”: “LifeIsStrange2”, “profile” : “IdleQueueOnSwapchainOOD” },
{ “pattern”: “Hitman”, “profile” : “IdleQueueOnSwapchainOOD” },
{ “pattern”: “F12017”, “profile” : “IdleQueueOnSwapchainOOD” },
{ “pattern”: “ShadowOfMordor”, “profile” : “IdleQueueOnSwapchainOOD” },
{ “pattern”: “MadMax”, “profile” : “IdleQueueOnSwapchainOOD” },
{ “pattern”: “GRIDAutosport”, “profile” : “IdleQueueOnSwapchainOOD” },
{ “pattern”: “DawnOfWar3”, “profile” : “DisableHostVisibleVidmem” }
ldd /sbin/glxinfo
linux-vdso.so.1 (0x00007ffe205b1000)
libGL.so.1 => /usr/lib/libGL.so.1 (0x00007fb96d12f000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007fb96cfee000)
libc.so.6 => /usr/lib/libc.so.6 (0x00007fb96ce22000)
libGLdispatch.so.0 => /usr/lib/libGLdispatch.so.0 (0x00007fb96cd6a000)
libGLX.so.0 => /usr/lib/libGLX.so.0 (0x00007fb96cd37000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007fb96cd0d000)
libdl.so.2 => /usr/lib/libdl.so.2 (0x00007fb96cd04000)
/lib64/ld-linux-x86-64.so.2 => /usr/lib64/ld-linux-x86-64.so.2 (0x00007fb96d1e9000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007fb96ccff000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007fb96ccf7000)
Found Vulkan loader(s):
/usr/lib/libvulkan.so.1.2.194
/usr/lib32/libvulkan.so.1.2.194
Listing common ICD paths:
/usr/share/vulkan/icd.d/nvidia_icd.json
/sbin/lspci -d “10de:*” -v -xxx
01:00.0 VGA compatible controller: NVIDIA Corporation GA107GLM [RTX A2000 Mobile] (rev ff) (prog-if ff)
!!! Unknown header type 7f
Kernel modules: nouveau, nvidia_drm, nvidia
00: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
10: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
20: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
01:00.1 Audio device: NVIDIA Corporation Device 2291 (rev ff) (prog-if ff)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
/sbin/lspci -d “10b5:*” -v -xxx
/sbin/lspci -t
-[0000:00]-±00.0
±01.0-[01]–±00.0
| -00.1
±02.0
±04.0
±07.0-[02-2b]–
±07.1-[2c-55]–
±08.0
±0a.0
±0d.0
±0d.2
±12.0
±14.0
±14.2
±14.3
±15.0
±16.0
±16.3
±1b.0-[56]----00.0
±1c.0-[57]----00.0
±1f.0
±1f.3
±1f.4
±1f.5
-1f.6
/sbin/lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a36] (rev 05)
00:01.0 PCI bridge [0604]: Intel Corporation 11th Gen Core Processor PCIe Controller #1 [8086:9a01] (rev 05)
00:02.0 VGA compatible controller [0300]: Intel Corporation TigerLake-H GT1 [UHD Graphics] [8086:9a60] (rev 01)
00:04.0 Signal processing controller [1180]: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant [8086:9a03] (rev 05)
00:07.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H Thunderbolt 4 PCI Express Root Port #0 [8086:9a2b] (rev 05)
00:07.1 PCI bridge [0604]: Intel Corporation Tiger Lake-H Thunderbolt 4 PCI Express Root Port #1 [8086:9a2d] (rev 05)
00:08.0 System peripheral [0880]: Intel Corporation GNA Scoring Accelerator module [8086:9a11] (rev 05)
00:0a.0 Signal processing controller [1180]: Intel Corporation Tigerlake Telemetry Aggregator Driver [8086:9a0d] (rev 01)
00:0d.0 USB controller [0c03]: Intel Corporation Tiger Lake-H Thunderbolt 4 USB Controller [8086:9a17] (rev 05)
00:0d.2 USB controller [0c03]: Intel Corporation Tiger Lake-H Thunderbolt 4 NHI #0 [8086:9a1f] (rev 05)
00:12.0 Serial controller [0700]: Intel Corporation Device [8086:43fc] (rev 11)
00:14.0 USB controller [0c03]: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller [8086:43ed] (rev 11)
00:14.2 RAM memory [0500]: Intel Corporation Tiger Lake-H Shared SRAM [8086:43ef] (rev 11)
00:14.3 Network controller [0280]: Intel Corporation Tiger Lake PCH CNVi WiFi [8086:43f0] (rev 11)
00:15.0 Serial bus controller [0c80]: Intel Corporation Tiger Lake-H Serial IO I2C Controller #0 [8086:43e8] (rev 11)
00:16.0 Communication controller [0780]: Intel Corporation Tiger Lake-H Management Engine Interface [8086:43e0] (rev 11)
00:16.3 Serial controller [0700]: Intel Corporation Device [8086:43e3] (rev 11)
00:1b.0 PCI bridge [0604]: Intel Corporation Device [8086:43c0] (rev 11)
00:1c.0 PCI bridge [0604]: Intel Corporation Device [8086:43ba] (rev 11)
00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:4389] (rev 11)
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Tiger Lake-H HD Audio Controller [8086:43c8] (rev 11)
00:1f.4 SMBus [0c05]: Intel Corporation Tiger Lake-H SMBus Controller [8086:43a3] (rev 11)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Tiger Lake-H SPI Controller [8086:43a4] (rev 11)
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (14) I219-LM [8086:15f9] (rev 11)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GA107GLM [RTX A2000 Mobile] [10de:25b8] (rev ff)
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:2291] (rev ff)
56:00.0 Non-Volatile memory controller [0108]: Toshiba Corporation XG6 NVMe SSD Controller [1179:011a]
57:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device [10ec:5261] (rev 01)
*** /sys/devices/system/node/has_cpu
*** ls: -r–r–r-- 1 root root 4096 2021-11-17 14:04:44.677311516 +0800 /sys/devices/system/node/has_cpu
0
*** /sys/devices/system/node/has_memory
*** ls: -r–r–r-- 1 root root 4096 2021-11-17 14:04:44.680645811 +0800 /sys/devices/system/node/has_memory
0
*** /sys/devices/system/node/has_normal_memory
*** ls: -r–r–r-- 1 root root 4096 2021-11-17 14:04:44.680645811 +0800 /sys/devices/system/node/has_normal_memory
0
*** /sys/devices/system/node/online
*** ls: -r–r–r-- 1 root root 4096 2021-11-17 14:04:44.680645811 +0800 /sys/devices/system/node/online
0
*** /sys/devices/system/node/possible
*** ls: -r–r–r-- 1 root root 4096 2021-11-17 14:04:44.683980105 +0800 /sys/devices/system/node/possible
0
*** /sys/bus/pci/devices/0000:01:00.0/local_cpulist
*** ls: -r–r–r-- 1 root root 4096 2021-11-17 13:54:58.859999990 +0800 /sys/bus/pci/devices/0000:01:00.0/local_cpulist
0-15
*** /sys/bus/pci/devices/0000:01:00.0/numa_node
*** ls: -rw-r–r-- 1 root root 4096 2021-11-17 13:54:58.859999990 +0800 /sys/bus/pci/devices/0000:01:00.0/numa_node
-1
/sbin/lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 005: ID 30c9:0046 Luxvisions Innotech Limited HP HD Camera
Bus 003 Device 003: ID 12d1:107e Huawei Technologies Co., Ltd. P10 smartphone
Bus 003 Device 007: ID 8087:0026 Intel Corp. AX201 Bluetooth
Bus 003 Device 006: ID 12d1:3a07 Huawei Technologies Co., Ltd. HUAWEI USB-C HEADSET
Bus 003 Device 002: ID 03f0:094a HP, Inc Optical Mouse [672662-001]
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
/sbin/dmidecode
dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 3.3 present.
55 structures occupying 3398 bytes.
Table at 0x3C8D8000.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
Vendor: HP
Version: T95 Ver. 01.01.05
Release Date: 07/07/2021
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 32 MB
Characteristics:
PCI is supported
PC Card (PCMCIA) is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
Smart battery is supported
BIOS boot specification is supported
Function key-initiated network boot is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 1.5
Firmware Revision: 82.24
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: HP
Product Name: HP ZBook Fury 15.6 inch G8 Mobile Workstation PC
Version:
Serial Number: CND1422M2Q
UUID: 924a1c0e-831e-4c3e-b0f4-ef352748e980
Wake-up Type: Power Switch
SKU Number: 4N4Z7AV
Family: 103C_5336AN HP ZBook
Handle 0x0002, DMI type 2, 17 bytes
Base Board Information
Manufacturer: HP
Product Name: 8870
Version: KBC Version 52.18.00
Serial Number: PPGHLF31UFSKPF
Asset Tag:
Features:
Board is a hosting board
Location In Chassis:
Chassis Handle: 0x0000
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 24 bytes
Chassis Information
Manufacturer: HP
Type: Notebook
Lock: Not Present
Version:
Asset Tag:
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: Unspecified
Contained Elements: 0
SKU Number: Not Specified
Handle 0x0005, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Abbreviated
Installable Languages: 15
enUS
deDE
esES
itIT
frFR
jaJP
ptPT
daDK
svSE
nlBE
noNO
fiFI
zhCN
zhTW
ruRU
Currently Installed Language: zhCN
Handle 0x0006, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 64 GB
Error Information Handle: Not Provided
Number Of Devices: 4
Handle 0x0017, DMI type 19, 31 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x007FFFFFFFF
Range Size: 32 GB
Physical Array Handle: 0x0006
Partition Width: 2
Handle 0x0018, DMI type 221, 26 bytes
HP BIOS iSCSI NIC PCI and MAC Information
NIC 1: PCI device 01:00.3, MAC address 00:0A:00:4F:31:00
NIC 2: PCI device 00:00.2, MAC address 00:00:00:2C:00:03
Handle 0x0019, DMI type 221, 26 bytes
NIC 2: PCI device 00:00.2, MAC address 0F:00:00:03:00:03
Handle 0x001A, DMI type 221, 47 bytes
NIC 1: PCI device 01:00.6, MAC address 00:0A:00:4F:31:00
NIC 2: PCI device 03:00.2, MAC address FF:FF:FF:FF:FF:04
NIC 3: PCI device ff:00.0, MAC address FF:FF:11:00:05:00
NIC 4: Not Installed
NIC 5: PCI device 00:08.6, MAC address 00:00:07:00:04:00
Handle 0x001B, DMI type 221, 82 bytes
NIC 1: PCI device 01:01.3, MAC address 00:0A:00:4F:31:00
NIC 2: PCI device 00:00.2, MAC address 02:00:02:00:00:03
NIC 3: PCI device 0a:00.0, MAC address 00:4F:31:00:04:05
NIC 5: Disabled
NIC 6: PCI device 05:00.0, MAC address 00:08:00:FF:FF:FF
NIC 7: Not Installed
NIC 8: PCI device 0a:00.0, MAC address 00:00:00:00:97:00
NIC 9: PCI device 00:01.3, MAC address 19:00:00:00:00:0C
Handle 0x001C, DMI type 221, 12 bytes
NIC 1: PCI device 01:00.1, MAC address 00:04:00:00:00:00
Handle 0x001D, DMI type 7, 27 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 384 kB
Maximum Size: 384 kB
Supported SRAM Types:
Synchronous
Installed SRAM Type: Synchronous
Speed: Unknown
Error Correction Type: Parity
System Type: Data
Associativity: 12-way Set-associative
Handle 0x001E, DMI type 7, 27 bytes
Cache Information
Installed Size: 256 kB
Maximum Size: 256 kB
Synchronous
Speed: Unknown
System Type: Instruction
Associativity: 8-way Set-associative
Handle 0x001F, DMI type 7, 27 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 10 MB
Maximum Size: 10 MB
Synchronous
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: Unified
Associativity: Other
Handle 0x0020, DMI type 7, 27 bytes
Cache Information
Socket Designation: L3 Cache
Configuration: Enabled, Not Socketed, Level 3
Installed Size: 24 MB
Maximum Size: 24 MB
Synchronous
Speed: Unknown
Error Correction Type: Multi-bit ECC
Handle 0x0021, DMI type 4, 48 bytes
Processor Information
Socket Designation: U3E1
Type: Central Processor
Family: Core i7
Manufacturer: Intel(R) Corporation
ID: D1 06 08 00 FF FB EB BF
Signature: Type 0, Family 6, Model 141, Stepping 1
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: 11th Gen Intel(R) Core™ i7-11850H @ 2.50GHz
Voltage: 0.7 V
External Clock: 100 MHz
Max Speed: 4800 MHz
Current Speed: 2475 MHz
Status: Populated, Enabled
Upgrade: Other
L1 Cache Handle: 0x001E
L2 Cache Handle: 0x001F
L3 Cache Handle: 0x0020
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 8
Core Enabled: 8
Thread Count: 16
Characteristics:
64-bit capable
Multi-Core
Hardware Thread
Execute Protection
Enhanced Virtualization
Power/Performance Control
Handle 0x0022, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: HDMI
Internal Connector Type: None
External Reference Designator: HDMI
External Connector Type: Other
Port Type: Video Port
Handle 0x0023, DMI type 8, 9 bytes
Internal Reference Designator: DisplayPort
External Reference Designator: DisplayPort
Handle 0x0024, DMI type 8, 9 bytes
Internal Reference Designator: Thubderbolt1
External Reference Designator: Thubderbolt1
Port Type:
Handle 0x0025, DMI type 8, 9 bytes
Internal Reference Designator: Thubderbolt2
External Reference Designator: Thubderbolt2
Port Type:
Handle 0x0026, DMI type 8, 9 bytes
Internal Reference Designator: RJ45
External Reference Designator: LAN
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x0027, DMI type 8, 9 bytes
Internal Reference Designator: HDSET
External Reference Designator: Left Headset
External Connector Type: Mini DIN
Port Type: Audio Port
Handle 0x0028, DMI type 8, 9 bytes
Internal Reference Designator: USB
External Reference Designator: Left USB 3.0 Port 1
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x0029, DMI type 8, 9 bytes
External Reference Designator: Left USB 3.0 Port 2
Port Type: USB
Handle 0x002A, DMI type 8, 9 bytes
Internal Reference Designator: SSD1
Internal Connector Type: SAS/SATA Plug Receptacle
External Reference Designator: SSD1
External Connector Type: SAS/SATA Plug Receptacle
Port Type: SATA
Handle 0x002B, DMI type 8, 9 bytes
Internal Reference Designator: SSD2
External Reference Designator: SSD2
Port Type: SATA
Handle 0x002C, DMI type 8, 9 bytes
Internal Reference Designator: SSD3
External Reference Designator: SSD3
Port Type: SATA
Handle 0x002D, DMI type 8, 9 bytes
Internal Reference Designator: SSD4
External Reference Designator: SSD4
Port Type: SATA
Handle 0x002E, DMI type 8, 9 bytes
Internal Reference Designator: HDD1
External Reference Designator: HDD1
Port Type: SATA
Handle 0x002F, DMI type 8, 9 bytes
Internal Reference Designator: PWR
Internal Connector Type: Other
External Reference Designator: Main power
External Connector Type: None
Port Type: Other
Handle 0x0030, DMI type 8, 9 bytes
Internal Reference Designator: CPUFAN
External Reference Designator: CPU fan
Port Type: Other
Handle 0x0031, DMI type 9, 24 bytes
System Slot Information
Designation: PCIe-7
Type: x1 PCI Express 3 x1
Current Usage: Available
Length: Long
Characteristics:
3.3 V is provided
PME signal is supported
SMBus signal is supported
Bus Address: 0000:00:1c.6
Data Bus Width: 80
Peer Devices: 67
Handle 0x0032, DMI type 9, 24 bytes
Designation: PCIe-8
Current Usage: In Use
Length: Long
Characteristics:
3.3 V is provided
Bus Address: 0000:00:14.3
Data Bus Width: 80
Peer Devices: 67
Handle 0x0033, DMI type 9, 24 bytes
Designation: PCIe-9
Type: x4 PCI Express 3 x4
Length: Long
Characteristics:
3.3 V is provided
Bus Address: 0000:00:1d.0
Data Bus Width: 80
Peer Devices: 67
Handle 0x0034, DMI type 9, 24 bytes
Designation: PCIe-13
Length: Long
Characteristics:
3.3 V is provided
Bus Address: 0000:00:1d.4
Data Bus Width: 80
Peer Devices: 67
Handle 0x0035, DMI type 9, 24 bytes
Designation: PCIe-17
Length: Long
Characteristics:
3.3 V is provided
Bus Address: 0000:00:1b.0
Data Bus Width: 80
Peer Devices: 67
Handle 0x0036, DMI type 9, 24 bytes
Designation: PCIe-21
Length: Long
Characteristics:
3.3 V is provided
Bus Address: 0000:00:1b.4
Data Bus Width: 0
Peer Devices: 0
Handle 0x0037, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Onboard IGD
Type: Video
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:02.0
Handle 0x0038, DMI type 130, 20 bytes
OEM-specific Type
Header and Data:
82 14 38 00 24 41 4D 54 01 01 01 01 01 A5 FF 02
C0 01 01 00
Handle 0x0039, DMI type 131, 64 bytes
OEM-specific Type
Header and Data:
83 40 39 00 35 00 00 00 0F 00 00 00 00 00 03 00
F8 00 89 43 00 00 00 00 09 C0 00 00 00 00 0F 00
B4 06 1E 00 00 00 00 00 FE 00 F9 15 00 00 00 00
00 00 00 00 26 00 00 00 76 50 72 6F 00 00 00 00
Handle 0x003A, DMI type 17, 92 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Top-Slot 1(left)
Bank Locator: Controller0ChannelADimm0
Type: DDR4
Type Detail: Synchronous
Speed: 3200 MT/s
Manufacturer: Samsung
Serial Number: 31314492
Asset Tag:
Part Number: M471A2K43DB1-CWE
Rank: 2
Configured Memory Speed: 3200 MT/s
Minimum Voltage: Unknown
Maximum Voltage: Unknown
Configured Voltage: 1.2 V
Memory Technology: DRAM
Memory Operating Mode Capability: Volatile memory
Firmware Version: Not Specified
Module Manufacturer ID: Bank 1, Hex 0xCE
Module Product ID: Unknown
Memory Subsystem Controller Manufacturer ID: Unknown
Memory Subsystem Controller Product ID: Unknown
Non-Volatile Size: None
Volatile Size: 16 GB
Cache Size: None
Logical Size: None
Handle 0x003B, DMI type 17, 92 bytes
Memory Device
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: Other
Set: None
Locator: Bottom-Slot 1(left)
Bank Locator: Controller0ChannelADimm1
Type: Unknown
Type Detail: None
Speed: Unknown
Manufacturer: Not Specified
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Rank: Unknown
Configured Memory Speed: Unknown
Configured Voltage: Unknown
Memory Technology:
Module Manufacturer ID: Unknown
Volatile Size: None
Cache Size: None
Logical Size: None
Handle 0x003C, DMI type 17, 92 bytes
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Top-Slot 2(right)
Bank Locator: Controller1ChannelADimm0
Type: DDR4
Speed: 3200 MT/s
Serial Number: 31314538
Asset Tag:
Rank: 2
Cache Size: None
Logical Size: None
Handle 0x003D, DMI type 17, 92 bytes
Memory Device
Data Width: Unknown
Form Factor: Other
Set: None
Locator: Bottom-Slot 2(right)
Bank Locator: Controller1ChannelADimm1
Type: Unknown
Type Detail: None
Speed: Unknown
Rank: Unknown
Memory Technology:
Volatile Size: None
Cache Size: None
Logical Size: None
Handle 0x0007, DMI type 20, 35 bytes
Memory Device Mapped Address
Ending Address: 0x003FFFFFFFF
Range Size: 16 GB
Physical Device Handle: 0x003A
Memory Array Mapped Address Handle: 0x0017
Partition Row Position: 1
Handle 0x0008, DMI type 20, 35 bytes
Starting Address: 0x00400000000
Range Size: 16 GB
Physical Device Handle: 0x003C
Interleaved Data Depth: 1
Handle 0x0009, DMI type 22, 26 bytes
Portable Battery
Manufacturer: 333-1C-0E-A
Design Capacity: 94330 mWh
Design Voltage: 15440 mV
SBDS Version: 1.1
Maximum Error: Unknown
SBDS Serial Number: 246A
SBDS Manufacture Date: 2021-07-31
SBDS Chemistry: LION
OEM-specific Information: 0x00000000
Handle 0x000A, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Disabled
Keyboard Password Status: Disabled
Administrator Password Status: Disabled
Front Panel Reset Status: Disabled
Handle 0x000B, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
Handle 0x0004, DMI type 11, 5 bytes
OEM Strings
String 1: FBYTE#3X476J6S6b7B7M7Q7U7W7m7s8uaBaEaYapaqauawbhcAdUdpdqfPhkk8mEmSmwn7nPnVngpD.Q2;
String 2: BUILDID#21WWAVAT601#SAB2#DAB2;
String 3: EDK2_1
String 4: Buff=2
String 5: HRDWFEATS=VMCSSHAD:1;VTX:1;VTD:1;SGX:0;PROGKEY:1;NONHPBATDET:1;
String 6: MEFWRec
Handle 0x000C, DMI type 10, 6 bytes
On Board Device Information
Type: Video
Status: Enabled
Description: 64 MB
Handle 0x000D, DMI type 14, 8 bytes
Group Associations
Items: 1
0x0000 (OEM-specific)
Handle 0x000E, DMI type 219, 106 bytes
HP ProLiant Information
Power Features: 0x45010401
Omega Features: 0x06900002
Misc. Features: 0x00000000
iCRU: No
UEFI: No
Handle 0xFEFF, DMI type 127, 4 bytes
End Of Table
/sbin/modinfo nvidia | grep vermagic
vermagic: 5.13.19-2-MANJARO SMP preempt mod_unload
Scanning kernel log files for NVIDIA kernel messages:
journalctl -b -0:
11月 17 13:55:38 william-hpzbook dbus-daemon[527]: [system] Activating via systemd: service name=‘net.reactivated.Fprint’ unit=‘fprintd.service’ requested by ‘:1.97’ (uid=0 pid=3946 comm="sudo nvidia-settings ")
11月 17 13:55:39 william-hpzbook dbus-daemon[527]: [system] Activating via systemd: service name=‘org.freedesktop.home1’ unit=‘dbus-org.freedesktop.home1.service’ requested by ‘:1.99’ (uid=0 pid=3946 comm="sudo nvidia-settings ")
11月 17 13:55:39 william-hpzbook sudo[3946]: william : TTY=pts/0 ; PWD=/home/william ; USER=root ; COMMAND=/usr/bin/nvidia-settings
11月 17 14:04:43 william-hpzbook dbus-daemon[527]: [system] Activating via systemd: service name=‘net.reactivated.Fprint’ unit=‘fprintd.service’ requested by ‘:1.106’ (uid=0 pid=8187 comm="sudo nvidia-bug-report.sh ")
11月 17 14:04:44 william-hpzbook dbus-daemon[527]: [system] Activating via systemd: service name=‘org.freedesktop.home1’ unit=‘dbus-org.freedesktop.home1.service’ requested by ‘:1.108’ (uid=0 pid=8187 comm="sudo nvidia-bug-report.sh ")
11月 17 14:04:44 william-hpzbook sudo[8187]: william : TTY=pts/0 ; PWD=/home/william ; USER=root ; COMMAND=/usr/bin/nvidia-bug-report.sh
journalctl -b -1:
11月 17 13:53:32 william-hpzbook dbus-daemon[521]: [system] Activating via systemd: service name=‘net.reactivated.Fprint’ unit=‘fprintd.service’ requested by ‘:1.144’ (uid=0 pid=7645 comm="sudo nvidia-xconfig ")
11月 17 13:53:33 william-hpzbook dbus-daemon[521]: [system] Activating via systemd: service name=‘org.freedesktop.home1’ unit=‘dbus-org.freedesktop.home1.service’ requested by ‘:1.146’ (uid=0 pid=7645 comm="sudo nvidia-xconfig ")
11月 17 13:53:33 william-hpzbook sudo[7645]: william : TTY=pts/0 ; PWD=/home/william ; USER=root ; COMMAND=/usr/bin/nvidia-xconfig
journalctl -b -2:
11月 17 12:36:14 william-hpzbook dbus-daemon[533]: [system] Activating via systemd: service name=‘net.reactivated.Fprint’ unit=‘fprintd.service’ requested by ‘:1.147’ (uid=0 pid=19890 comm="sudo nvidia-bug-report.sh ")
11月 17 12:36:15 william-hpzbook dbus-daemon[533]: [system] Activating via systemd: service name=‘org.freedesktop.home1’ unit=‘dbus-org.freedesktop.home1.service’ requested by ‘:1.149’ (uid=0 pid=19890 comm="sudo nvidia-bug-report.sh ")
11月 17 12:36:15 william-hpzbook sudo[19890]: william : TTY=pts/0 ; PWD=/home/william ; USER=root ; COMMAND=/usr/bin/nvidia-bug-report.sh
11月 17 12:36:17 william-hpzbook kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
11月 17 12:36:17 william-hpzbook kernel: NVRM: The NVIDIA GPU 0000:01:00.0
NVRM: (PCI ID: 10de:25b8) installed in this system has
NVRM: fallen off the bus and is not responding to commands.
11月 17 12:36:17 william-hpzbook kernel: NVRM: The NVIDIA probe routine failed for 1 device(s).
11月 17 12:36:17 william-hpzbook kernel: NVRM: None of the NVIDIA devices were initialized.
11月 17 12:36:17 william-hpzbook kernel: nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
11月 17 12:36:18 william-hpzbook kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
11月 17 12:36:18 william-hpzbook kernel: NVRM: The NVIDIA GPU 0000:01:00.0
11月 17 12:36:18 william-hpzbook kernel: NVRM: The NVIDIA probe routine failed for 1 device(s).
11月 17 12:36:18 william-hpzbook kernel: NVRM: None of the NVIDIA devices were initialized.
11月 17 12:36:18 william-hpzbook kernel: nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
11月 17 12:36:22 william-hpzbook kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
11月 17 12:36:22 william-hpzbook kernel: NVRM: The NVIDIA GPU 0000:01:00.0
11月 17 12:36:22 william-hpzbook kernel: NVRM: The NVIDIA probe routine failed for 1 device(s).
11月 17 12:36:22 william-hpzbook kernel: NVRM: None of the NVIDIA devices were initialized.
11月 17 12:36:22 william-hpzbook kernel: nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
11月 17 12:42:36 william-hpzbook kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
11月 17 12:42:36 william-hpzbook kernel: NVRM: The NVIDIA GPU 0000:01:00.0
11月 17 12:42:36 william-hpzbook kernel: NVRM: The NVIDIA probe routine failed for 1 device(s).
11月 17 12:42:36 william-hpzbook kernel: NVRM: None of the NVIDIA devices were initialized.
11月 17 12:42:36 william-hpzbook kernel: nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
11月 17 13:09:34 william-hpzbook nvidia-settings.desktop[24112]: ERROR: Unable to find display on any available system
11月 17 13:43:40 william-hpzbook dbus-daemon[533]: [system] Activating via systemd: service name=‘net.reactivated.Fprint’ unit=‘fprintd.service’ requested by ‘:1.195’ (uid=0 pid=39637 comm=“sudo vim /etc/X11/xorg.conf.d/10-nvidia-drm-output”)
11月 17 13:43:42 william-hpzbook dbus-daemon[533]: [system] Activating via systemd: service name=‘org.freedesktop.home1’ unit=‘dbus-org.freedesktop.home1.service’ requested by ‘:1.197’ (uid=0 pid=39637 comm=“sudo vim /etc/X11/xorg.conf.d/10-nvidia-drm-output”)
11月 17 13:43:42 william-hpzbook sudo[39637]: william : TTY=pts/2 ; PWD=/home/william ; USER=root ; COMMAND=/usr/bin/vim /etc/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf
nvidia-settings -q all:
Unable to init server: 无法连接:拒绝连接
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
xrandr --verbose:
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
XWAYLAND0 connected primary 1920x1080+0+0 (0x23) normal (normal left inverted right x axis y axis) 340mm x 190mm
Identifier: 0x21
Timestamp: 16278
Subpixel: unknown
Gamma: inf:inf:inf
Brightness: 0.0039
Clones:
CRTC: 0
CRTCs: 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
non-desktop: 0
supported: 0, 1
1920x1080 (0x23) 173.000MHz -HSync +VSync *current +preferred
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
1440x1080 (0x24) 129.000MHz -HSync +VSync
h: width 1440 start 1528 end 1680 total 1920 skew 0 clock 67.19KHz
v: height 1080 start 1083 end 1087 total 1120 clock 59.99Hz
1400x1050 (0x25) 121.750MHz -HSync +VSync
h: width 1400 start 1488 end 1632 total 1864 skew 0 clock 65.32KHz
v: height 1050 start 1053 end 1057 total 1089 clock 59.98Hz
1280x1024 (0x26) 109.000MHz -HSync +VSync
h: width 1280 start 1368 end 1496 total 1712 skew 0 clock 63.67KHz
v: height 1024 start 1027 end 1034 total 1063 clock 59.89Hz
1280x960 (0x27) 101.250MHz -HSync +VSync
h: width 1280 start 1360 end 1488 total 1696 skew 0 clock 59.70KHz
v: height 960 start 963 end 967 total 996 clock 59.94Hz
1152x864 (0x28) 81.750MHz -HSync +VSync
h: width 1152 start 1216 end 1336 total 1520 skew 0 clock 53.78KHz
v: height 864 start 867 end 871 total 897 clock 59.96Hz
1024x768 (0x29) 63.500MHz -HSync +VSync
h: width 1024 start 1072 end 1176 total 1328 skew 0 clock 47.82KHz
v: height 768 start 771 end 775 total 798 clock 59.92Hz
800x600 (0x2a) 38.250MHz -HSync +VSync
h: width 800 start 832 end 912 total 1024 skew 0 clock 37.35KHz
v: height 600 start 603 end 607 total 624 clock 59.86Hz
640x480 (0x2b) 23.750MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 29.69KHz
v: height 480 start 483 end 487 total 500 clock 59.38Hz
320x240 (0x2c) 6.000MHz -HSync +VSync
h: width 320 start 336 end 360 total 400 skew 0 clock 15.00KHz
v: height 240 start 243 end 247 total 252 clock 59.52Hz
1680x1050 (0x2d) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1440x900 (0x2e) 106.500MHz -HSync +VSync
h: width 1440 start 1528 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1280x800 (0x2f) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
720x480 (0x30) 26.750MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 29.85KHz
v: height 480 start 483 end 493 total 500 clock 59.71Hz
640x400 (0x31) 20.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 25.00KHz
v: height 400 start 403 end 409 total 417 clock 59.95Hz
320x200 (0x32) 5.000MHz -HSync +VSync
h: width 320 start 336 end 360 total 400 skew 0 clock 12.50KHz
v: height 200 start 203 end 209 total 212 clock 58.96Hz
1600x900 (0x33) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1368x768 (0x34) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1280x720 (0x35) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1024x576 (0x36) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
864x486 (0x37) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
720x400 (0x38) 22.250MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 24.83KHz
v: height 400 start 403 end 413 total 417 clock 59.55Hz
640x350 (0x39) 17.500MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 21.88KHz
v: height 350 start 353 end 363 total 366 clock 59.77Hz
Running window manager properties:
_NET_SUPPORTING_WM_CHECK(WINDOW): window id # 0x800007
_MUTTER_VERSION(UTF8_STRING) = “40.5”
_GNOME_WM_KEYBINDINGS(UTF8_STRING) = “Mutter,GNOME Shell”
_NET_WM_NAME(UTF8_STRING) = “GNOME Shell”
*** /proc/cmdline
*** ls: -r–r–r-- 1 root root 0 2021-11-17 13:54:58.666666662 +0800 /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=af98fc4e-c855-4af0-8399-f2814b2783a9 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
*** /proc/interrupts
*** ls: -r–r–r-- 1 root root 0 2021-11-17 14:04:50.075508722 +0800 /proc/interrupts
CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 CPU8 CPU9 CPU10 CPU11 CPU12 CPU13 CPU14 CPU15
0: 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-IO-APIC 2-edge timer
1: 0 0 0 0 0 0 0 0 0 0 0 0 376 0 0 0 IR-IO-APIC 1-edge i8042
8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-IO-APIC 8-edge rtc0
9: 0 1028 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-IO-APIC 9-fasteoi acpi
14: 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-IO-APIC 14-fasteoi INT34C6:00
16: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 6 0 IR-IO-APIC 16-fasteoi i801_smbus
26: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 51 0 IR-IO-APIC 26-fasteoi intel_ish_ipc
27: 0 0 0 640 0 0 0 0 0 0 0 0 0 0 0 0 IR-IO-APIC 27-fasteoi idma64.0, i2c_designware.0
110: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-IO-APIC 110-edge lis3lv02d
120: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 DMAR-MSI 2-edge dmar2
121: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 DMAR-MSI 1-edge dmar1
122: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 DMAR-MSI 0-edge dmar0
123: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 DMAR-MSI 3-edge dmar3
124: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 16384-edge PCIe PME
125: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 114688-edge PCIe PME, pciehp
126: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 116736-edge PCIe PME, pciehp
127: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 442368-edge PCIe PME
128: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 458752-edge PCIe PME, pciehp
129: 0 0 0 0 0 0 0 0 0 36 0 0 0 0 0 0 IR-PCI-MSI 45088768-edge nvme0q0
130: 3255 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 45088769-edge nvme0q1
131: 0 3586 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 45088770-edge nvme0q2
132: 0 0 2219 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 45088771-edge nvme0q3
133: 0 0 0 2411 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 45088772-edge nvme0q4
134: 0 0 0 0 3527 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 45088773-edge nvme0q5
135: 0 0 0 0 0 2643 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 45088774-edge nvme0q6
136: 0 0 0 0 0 0 2889 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 45088775-edge nvme0q7
137: 0 0 0 0 0 0 0 2899 0 0 0 0 0 0 0 0 IR-PCI-MSI 45088776-edge nvme0q8
138: 0 0 0 0 0 0 0 0 2287 0 0 0 0 0 0 0 IR-PCI-MSI 45088777-edge nvme0q9
139: 0 0 0 0 0 0 0 0 0 3561 0 0 0 0 0 0 IR-PCI-MSI 45088778-edge nvme0q10
140: 0 0 0 0 0 0 0 0 0 0 2392 0 0 0 0 0 IR-PCI-MSI 45088779-edge nvme0q11
141: 0 0 0 0 0 0 0 0 0 0 0 4336 0 0 0 0 IR-PCI-MSI 45088780-edge nvme0q12
142: 0 0 0 0 0 0 0 0 0 0 0 0 2123 0 0 0 IR-PCI-MSI 45088781-edge nvme0q13
143: 0 0 0 0 0 0 0 0 0 0 0 0 0 2471 0 0 IR-PCI-MSI 45088782-edge nvme0q14
144: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3066 0 IR-PCI-MSI 45088783-edge nvme0q15
145: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3155 IR-PCI-MSI 45088784-edge nvme0q16
146: 0 0 0 0 0 0 0 0 0 0 6 0 0 0 0 0 IR-PCI-MSI 45613056-edge rtsx_pci
147: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 212992-edge xhci_hcd
148: 0 0 0 0 0 0 0 0 0 0 0 0 0 42445 0 0 IR-PCI-MSI 327680-edge xhci_hcd
149: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 106 IR-PCI-MSI 217088-edge thunderbolt
150: 0 109 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 217089-edge thunderbolt
165: 0 0 66 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 360448-edge mei_me
166: 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 INT34C6:00 416 ELAN074F:00
167: 0 0 0 0 0 6206 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 333824-edge iwlwifi: default queue
168: 988 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 333825-edge iwlwifi: queue 1
169: 0 835 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 333826-edge iwlwifi: queue 2
170: 0 0 933 0 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 333827-edge iwlwifi: queue 3
171: 0 0 0 389 0 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 333828-edge iwlwifi: queue 4
172: 0 0 0 0 357 0 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 333829-edge iwlwifi: queue 5
173: 0 0 0 0 0 640 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 333830-edge iwlwifi: queue 6
174: 0 0 0 0 0 0 516 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 333831-edge iwlwifi: queue 7
175: 0 0 0 0 0 0 0 436 0 0 0 0 0 0 0 0 IR-PCI-MSI 333832-edge iwlwifi: queue 8
176: 0 0 0 0 0 0 0 0 797 0 0 0 0 0 0 0 IR-PCI-MSI 333833-edge iwlwifi: queue 9
177: 0 0 0 0 0 0 0 0 0 457 0 0 0 0 0 0 IR-PCI-MSI 333834-edge iwlwifi: queue 10
178: 0 0 0 0 0 0 0 0 0 0 616 0 0 0 0 0 IR-PCI-MSI 333835-edge iwlwifi: queue 11
179: 0 0 0 0 0 0 0 0 0 0 0 776 0 0 0 0 IR-PCI-MSI 333836-edge iwlwifi: queue 12
180: 0 0 0 0 0 0 0 0 0 0 0 0 4006 0 0 0 IR-PCI-MSI 333837-edge iwlwifi: queue 13
181: 0 0 0 0 0 0 0 0 0 0 0 0 0 610 0 0 IR-PCI-MSI 333838-edge iwlwifi: queue 14
182: 0 0 0 0 0 7 0 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 333839-edge iwlwifi: exception
183: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 133902 IR-PCI-MSI 32768-edge i915
184: 0 0 0 0 0 0 296 0 0 0 0 0 0 0 0 0 IR-PCI-MSI 520192-edge enp0s31f6
NMI: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Non-maskable interrupts
LOC: 130213 121329 116503 109237 108272 113361 108994 121819 115797 113653 109918 120623 108077 114403 100995 175703 Local timer interrupts
SPU: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Spurious interrupts
PMI: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Performance monitoring interrupts
IWI: 1593 1431 1271 1025 876 889 686 808 675 726 957 972 752 873 897 87023 IRQ work interrupts
RTR: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 APIC ICR read retries
RES: 2046 1485 1394 1336 1429 1455 1394 1644 1567 1474 1301 1377 1271 1800 1415 3336 Rescheduling interrupts
CAL: 30153 27766 25788 26683 24551 26769 23977 26742 22983 25784 24772 24497 25457 25534 25637 24098 Function call interrupts
TLB: 6130 6546 5258 6781 4729 6767 6169 7138 6217 5692 5107 6647 5039 5919 5718 5644 TLB shootdowns
TRM: 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 Thermal event interrupts
THR: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Threshold APIC interrupts
DFR: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Deferred Error APIC interrupts
MCE: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Machine check exceptions
MCP: 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Machine check polls
ERR: 0
MIS: 0
PIN: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Posted-interrupt notification event
NPI: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Nested posted-interrupt event
PIW: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Posted-interrupt wakeup event
*** /proc/meminfo
*** ls: -r–r–r-- 1 root root 0 2021-11-17 13:54:59.066666652 +0800 /proc/meminfo
MemTotal: 32537392 kB
MemFree: 28109756 kB
MemAvailable: 29478252 kB
Buffers: 66208 kB
Cached: 2189440 kB
SwapCached: 0 kB
Active: 631156 kB
Inactive: 2951772 kB
Active(anon): 16276 kB
Inactive(anon): 1865512 kB
Active(file): 614880 kB
Inactive(file): 1086260 kB
Unevictable: 436140 kB
Mlocked: 32 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 396 kB
Writeback: 0 kB
AnonPages: 1757140 kB
Mapped: 1008140 kB
Shmem: 561040 kB
KReclaimable: 77728 kB
Slab: 206780 kB
SReclaimable: 77728 kB
SUnreclaim: 129052 kB
KernelStack: 20636 kB
PageTables: 35488 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 16268696 kB
Committed_AS: 11561756 kB
VmallocTotal: 34359738367 kB
VmallocUsed: 74236 kB
VmallocChunk: 0 kB
Percpu: 15872 kB
HardwareCorrupted: 0 kB
AnonHugePages: 28672 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
CmaTotal: 0 kB
CmaFree: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
DirectMap4k: 292872 kB
DirectMap2M: 6703104 kB
DirectMap1G: 26214400 kB
*** /proc/modules
*** ls: -r–r–r-- 1 root root 0 2021-11-17 13:55:03.079999889 +0800 /proc/modules
xt_statistic 16384 3 - Live 0xffffffffc1b9c000
ip_vs_sh 16384 0 - Live 0xffffffffc1b93000
ip_vs_wrr 16384 0 - Live 0xffffffffc1b8b000
ip_vs_rr 16384 0 - Live 0xffffffffc1b83000
ip_vs 184320 6 ip_vs_sh,ip_vs_wrr,ip_vs_rr, Live 0xffffffffc1b4b000
iptable_mangle 16384 1 - Live 0xffffffffc1b26000
ip6table_mangle 16384 1 - Live 0xffffffffc1b21000
ip6table_filter 16384 1 - Live 0xffffffffc0a8d000
xt_comment 16384 63 - Live 0xffffffffc09d7000
xt_mark 16384 12 - Live 0xffffffffc09b3000
isofs 49152 1 - Live 0xffffffffc1b14000
rfcomm 90112 4 - Live 0xffffffffc1afd000
nf_tables 258048 0 - Live 0xffffffffc1a72000
xt_nat 16384 12 - Live 0xffffffffc1a6d000
xt_tcpudp 20480 22 - Live 0xffffffffc1810000
veth 32768 0 - Live 0xffffffffc1803000
xt_conntrack 16384 17 - Live 0xffffffffc1a68000
xt_MASQUERADE 20480 6 - Live 0xffffffffc1a5f000
nf_conntrack_netlink 57344 0 - Live 0xffffffffc1a4b000
nfnetlink 20480 3 nf_tables,nf_conntrack_netlink, Live 0xffffffffc1a41000
xt_addrtype 16384 5 - Live 0xffffffffc1a39000
iptable_filter 16384 2 - Live 0xffffffffc1a34000
br_netfilter 32768 0 - Live 0xffffffffc1864000
bridge 323584 1 br_netfilter, Live 0xffffffffc19e4000
stp 16384 1 bridge, Live 0xffffffffc17fe000
llc 16384 2 bridge,stp, Live 0xffffffffc17f6000
overlay 147456 19 - Live 0xffffffffc19bf000
ccm 20480 6 - Live 0xffffffffc17ec000
cmac 16384 3 - Live 0xffffffffc07b5000
algif_hash 16384 1 - Live 0xffffffffc0692000
algif_skcipher 16384 1 - Live 0xffffffffc04e4000
af_alg 32768 6 algif_hash,algif_skcipher, Live 0xffffffffc0809000
sr_mod 28672 1 - Live 0xffffffffc068a000
cdrom 81920 2 isofs,sr_mod, Live 0xffffffffc078d000
bnep 32768 2 - Live 0xffffffffc185b000
uvcvideo 118784 0 - Live 0xffffffffc183d000
uas 32768 0 - Live 0xffffffffc0ee6000
btusb 69632 0 - Live 0xffffffffc182b000
videobuf2_vmalloc 20480 1 uvcvideo, Live 0xffffffffc0868000
videobuf2_memops 20480 1 videobuf2_vmalloc, Live 0xffffffffc07e6000
videobuf2_v4l2 36864 1 uvcvideo, Live 0xffffffffc169d000
btrtl 28672 1 btusb, Live 0xffffffffc0854000
btbcm 20480 1 btusb, Live 0xffffffffc07c6000
videobuf2_common 69632 4 uvcvideo,videobuf2_vmalloc,videobuf2_memops,videobuf2_v4l2, Live 0xffffffffc1819000
btintel 32768 1 btusb, Live 0xffffffffc0800000
bluetooth 733184 33 rfcomm,bnep,btusb,btrtl,btbcm,btintel, Live 0xffffffffc190b000
snd_usb_audio 335872 2 - Live 0xffffffffc18b8000
videodev 282624 3 uvcvideo,videobuf2_v4l2,videobuf2_common, Live 0xffffffffc1872000
snd_usbmidi_lib 45056 1 snd_usb_audio, Live 0xffffffffc08a9000
snd_rawmidi 45056 1 snd_usbmidi_lib, Live 0xffffffffc0890000
usb_storage 81920 2 uas, Live 0xffffffffc16ae000
snd_seq_device 16384 1 snd_rawmidi, Live 0xffffffffc07bb000
mc 65536 5 uvcvideo,videobuf2_v4l2,videobuf2_common,snd_usb_audio,videodev, Live 0xffffffffc1580000
ecdh_generic 16384 2 bluetooth, Live 0xffffffffc07e1000
ecc 40960 1 ecdh_generic, Live 0xffffffffc07a3000
usbhid 65536 0 - Live 0xffffffffc0843000
snd_hda_codec_hdmi 73728 0 - Live 0xffffffffc125e000
snd_hda_codec_realtek 155648 0 - Live 0xffffffffc1277000
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek, Live 0xffffffffc1245000
mousedev 24576 0 - Live 0xffffffffc0a7f000
hid_sensor_als 20480 0 - Live 0xffffffffc0f7b000
hid_sensor_trigger 20480 2 hid_sensor_als, Live 0xffffffffc0f5f000
industrialio_triggered_buffer 16384 1 hid_sensor_trigger, Live 0xffffffffc0cb2000
kfifo_buf 16384 1 industrialio_triggered_buffer, Live 0xffffffffc0ac0000
hid_sensor_iio_common 20480 2 hid_sensor_als,hid_sensor_trigger, Live 0xffffffffc0f59000
industrialio 98304 4 hid_sensor_als,hid_sensor_trigger,industrialio_triggered_buffer,kfifo_buf, Live 0xffffffffc17c7000
hid_sensor_hub 24576 3 hid_sensor_als,hid_sensor_trigger,hid_sensor_iio_common, Live 0xffffffffc0bd9000
joydev 28672 0 - Live 0xffffffffc1449000
cros_ec_ishtp 20480 0 - Live 0xffffffffc0a79000
snd_soc_dmic 16384 0 - Live 0xffffffffc0970000
cros_ec 20480 1 cros_ec_ishtp, Live 0xffffffffc0a87000
intel_ishtp_loader 24576 0 - Live 0xffffffffc09e7000
iTCO_wdt 16384 0 - Live 0xffffffffc0a70000
hp_wmi 20480 0 - Live 0xffffffffc09ef000
intel_pmt_telemetry 16384 0 - Live 0xffffffffc09e2000
intel_pmc_bxt 16384 1 iTCO_wdt, Live 0xffffffffc09dd000
intel_ishtp_hid 28672 0 - Live 0xffffffffc09ab000
hid_multitouch 32768 0 - Live 0xffffffffc099d000
ee1004 20480 0 - Live 0xffffffffc0997000
iTCO_vendor_support 16384 1 iTCO_wdt, Live 0xffffffffc0969000
mei_hdcp 24576 0 - Live 0xffffffffc0948000
mei_wdt 16384 0 - Live 0xffffffffc092a000
intel_pmt_class 16384 1 intel_pmt_telemetry, Live 0xffffffffc0863000
intel_rapl_msr 20480 0 - Live 0xffffffffc07cc000
platform_profile 16384 1 hp_wmi, Live 0xffffffffc07b0000
wmi_bmof 16384 0 - Live 0xffffffffc0788000
squashfs 69632 0 - Live 0xffffffffc0936000
intel_tcc_cooling 16384 0 - Live 0xffffffffc1698000
x86_pkg_temp_thermal 20480 0 - Live 0xffffffffc0bd3000
intel_powerclamp 20480 0 - Live 0xffffffffc168d000
coretemp 20480 0 - Live 0xffffffffc0829000
kvm_intel 335872 0 - Live 0xffffffffc2a09000
kvm 1036288 1 kvm_intel, Live 0xffffffffc16c9000
irqbypass 16384 1 kvm, Live 0xffffffffc16c4000
crct10dif_pclmul 16384 1 - Live 0xffffffffc0a38000
snd_sof_pci_intel_tgl 16384 0 - Live 0xffffffffc0a30000
crc32_pclmul 16384 0 - Live 0xffffffffc16a9000
ghash_clmulni_intel 16384 0 - Live 0xffffffffc0a2b000
snd_sof_intel_hda_common 106496 1 snd_sof_pci_intel_tgl, Live 0xffffffffc15df000
aesni_intel 380928 8 - Live 0xffffffffc1612000
crypto_simd 16384 1 aesni_intel, Live 0xffffffffc0989000
soundwire_intel 45056 1 snd_sof_intel_hda_common, Live 0xffffffffc0a1a000
cryptd 28672 3 ghash_clmulni_intel,crypto_simd, Live 0xffffffffc1605000
intel_cstate 20480 0 - Live 0xffffffffc08a3000
soundwire_generic_allocation 16384 1 soundwire_intel, Live 0xffffffffc089e000
intel_uncore 184320 0 - Live 0xffffffffc15b1000
soundwire_cadence 36864 1 soundwire_intel, Live 0xffffffffc143f000
snd_sof_intel_hda 20480 1 snd_sof_intel_hda_common, Live 0xffffffffc0ee0000
snd_sof_pci 20480 2 snd_sof_pci_intel_tgl,snd_sof_intel_hda_common, Live 0xffffffffc0eda000
snd_sof_xtensa_dsp 16384 1 snd_sof_intel_hda_common, Live 0xffffffffc0ed5000
snd_sof 147456 2 snd_sof_intel_hda_common,snd_sof_pci, Live 0xffffffffc141a000
snd_soc_hdac_hda 24576 1 snd_sof_intel_hda_common, Live 0xffffffffc0982000
snd_hda_ext_core 36864 3 snd_sof_intel_hda_common,snd_sof_intel_hda,snd_soc_hdac_hda, Live 0xffffffffc095b000
qrtr 20480 4 - Live 0xffffffffc0951000
pcspkr 16384 0 - Live 0xffffffffc081c000
ns 36864 1 qrtr, Live 0xffffffffc15a2000
loop 40960 0 - Live 0xffffffffc1592000
iwlmvm 495616 0 - Live 0xffffffffc1506000
snd_soc_acpi_intel_match 49152 2 snd_sof_pci_intel_tgl,snd_sof_intel_hda_common, Live 0xffffffffc14f5000
snd_soc_acpi 16384 2 snd_sof_intel_hda_common,snd_soc_acpi_intel_match, Live 0xffffffffc14bc000
soundwire_bus 90112 3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence, Live 0xffffffffc14a5000
ledtrig_audio 16384 2 snd_hda_codec_generic,snd_sof, Live 0xffffffffc0976000
e1000e 311296 0 - Live 0xffffffffc1452000
mac80211 1171456 1 iwlmvm, Live 0xffffffffc12fb000
snd_soc_core 335872 5 snd_soc_dmic,snd_sof_intel_hda_common,soundwire_intel,snd_sof,snd_soc_hdac_hda, Live 0xffffffffc12a8000
intel_spi_pci 16384 0 - Live 0xffffffffc0ae8000
intel_spi 24576 1 intel_spi_pci, Live 0xffffffffc0e2b000
spi_nor 98304 1 intel_spi, Live 0xffffffffc0e12000
mtd 81920 3 intel_spi,spi_nor, Live 0xffffffffc0dfd000
libarc4 16384 1 mac80211, Live 0xffffffffc0a5b000
snd_compress 32768 1 snd_soc_core, Live 0xffffffffc0a0f000
i2c_i801 36864 0 - Live 0xffffffffc0a05000
vfat 24576 1 - Live 0xffffffffc09fe000
ac97_bus 16384 1 snd_soc_core, Live 0xffffffffc077d000
i915 2895872 16 - Live 0xffffffffc0f81000
fat 86016 1 vfat, Live 0xffffffffc0c9c000
snd_pcm_dmaengine 16384 1 snd_soc_core, Live 0xffffffffc0904000
i2c_smbus 20480 1 i2c_i801, Live 0xffffffffc0f75000
iwlwifi 430080 1 iwlmvm, Live 0xffffffffc0eef000
i2c_algo_bit 16384 1 i915, Live 0xffffffffc08d8000
drm_kms_helper 294912 1 i915, Live 0xffffffffc0e8c000
snd_hda_intel 57344 0 - Live 0xffffffffc0e75000
intel_lpss_pci 24576 0 - Live 0xffffffffc0c00000
snd_intel_dspcfg 28672 2 snd_sof_intel_hda_common,snd_hda_intel, Live 0xffffffffc0b62000
cec 73728 2 i915,drm_kms_helper, Live 0xffffffffc0e5c000
mei_me 45056 2 - Live 0xffffffffc0a4f000
snd_intel_sdw_acpi 20480 2 snd_sof_intel_hda_common,snd_intel_dspcfg, Live 0xffffffffc0a49000
intel_lpss 16384 1 intel_lpss_pci, Live 0xffffffffc0822000
mei 155648 5 mei_wdt,mei_hdcp,mei_me, Live 0xffffffffc0e35000
idma64 20480 0 - Live 0xffffffffc0a61000
cfg80211 1044480 3 iwlmvm,mac80211,iwlwifi, Live 0xffffffffc0cfd000
snd_hda_codec 176128 5 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_codec_generic,snd_soc_hdac_hda,snd_hda_intel, Live 0xffffffffc0cc3000
drm 589824 10 i915,drm_kms_helper, Live 0xffffffffc0c0b000
snd_hda_core 110592 9 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_codec_generic,snd_sof_intel_hda_common,snd_sof_intel_hda,snd_soc_hdac_hda,snd_hda_ext_core,snd_hda_intel,snd_hda_codec, Live 0xffffffffc0be4000
thunderbolt 315392 0 - Live 0xffffffffc0b85000
rfkill 32768 8 bluetooth,hp_wmi,cfg80211, Live 0xffffffffc0b77000
snd_hwdep 16384 2 snd_usb_audio,snd_hda_codec, Live 0xffffffffc0b6e000
snd_pcm 147456 11 snd_usb_audio,snd_hda_codec_hdmi,snd_sof_intel_hda_common,soundwire_intel,snd_sof,snd_soc_core,snd_compress,snd_pcm_dmaengine,snd_hda_intel,snd_hda_codec,snd_hda_core, Live 0xffffffffc0b3d000
intel_ish_ipc 28672 0 - Live 0xffffffffc0b31000
intel_ishtp 61440 4 cros_ec_ishtp,intel_ishtp_loader,intel_ishtp_hid,intel_ish_ipc, Live 0xffffffffc0b1b000
intel_gtt 24576 1 i915, Live 0xffffffffc0b11000
processor_thermal_device 20480 0 - Live 0xffffffffc0b07000
snd_timer 45056 1 snd_pcm, Live 0xffffffffc0af6000
ucsi_acpi 16384 0 - Live 0xffffffffc0aee000
agpgart 45056 2 drm,intel_gtt, Live 0xffffffffc0adc000
processor_thermal_rfim 16384 1 processor_thermal_device, Live 0xffffffffc0ad7000
typec_ucsi 49152 1 ucsi_acpi, Live 0xffffffffc0aca000
snd 114688 18 snd_usb_audio,snd_usbmidi_lib,snd_rawmidi,snd_seq_device,snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_codec_generic,snd_soc_core,snd_compress,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_timer, Live 0xffffffffc0a9e000
processor_thermal_mbox 16384 1 processor_thermal_device, Live 0xffffffffc0abb000
intel_pmt 16384 0 - Live 0xffffffffc0a99000
processor_thermal_rapl 20480 1 processor_thermal_device, Live 0xffffffffc0a93000
syscopyarea 16384 1 drm_kms_helper, Live 0xffffffffc0a69000
typec 65536 1 typec_ucsi, Live 0xffffffffc090f000
sysfillrect 16384 1 drm_kms_helper, Live 0xffffffffc090a000
intel_rapl_common 28672 2 intel_rapl_msr,processor_thermal_rapl, Live 0xffffffffc08fc000
sysimgblt 16384 1 drm_kms_helper, Live 0xffffffffc0767000
intel_soc_dts_iosf 20480 1 processor_thermal_device, Live 0xffffffffc0761000
i2c_hid_acpi 16384 0 - Live 0xffffffffc075c000
fb_sys_fops 16384 1 drm_kms_helper, Live 0xffffffffc0757000
soundcore 16384 1 snd, Live 0xffffffffc0752000
roles 16384 1 typec_ucsi, Live 0xffffffffc0783000
wmi 36864 2 hp_wmi,wmi_bmof, Live 0xffffffffc09c6000
i2c_hid 32768 1 i2c_hid_acpi, Live 0xffffffffc09ba000
int3403_thermal 20480 0 - Live 0xffffffffc0924000
soc_button_array 20480 0 - Live 0xffffffffc0930000
int340x_thermal_zone 20480 2 processor_thermal_device,int3403_thermal, Live 0xffffffffc08f6000
vboxnetflt 32768 0 - Live 0xffffffffc08ed000 (OE)
hp_accel 28672 0 - Live 0xffffffffc08e5000
vboxnetadp 28672 0 - Live 0xffffffffc08dd000 (OE)
video 57344 1 i915, Live 0xffffffffc08c9000
lis3lv02d 28672 1 hp_accel, Live 0xffffffffc08c1000
acpi_pad 24576 0 - Live 0xffffffffc07f7000
int3400_thermal 20480 0 - Live 0xffffffffc07ee000
intel_hid 24576 0 - Live 0xffffffffc07d6000
mac_hid 16384 0 - Live 0xffffffffc07c1000
hp_wireless 16384 0 - Live 0xffffffffc0773000
acpi_thermal_rel 16384 1 int3400_thermal, Live 0xffffffffc0778000
sparse_keymap 16384 2 hp_wmi,intel_hid, Live 0xffffffffc076e000
vboxdrv 528384 2 vboxnetflt,vboxnetadp, Live 0xffffffffc06d0000 (OE)
acpi_call 16384 0 - Live 0xffffffffc06c8000 (OE)
ip6table_nat 16384 1 - Live 0xffffffffc06c0000
ip6_tables 32768 3 ip6table_mangle,ip6table_filter,ip6table_nat, Live 0xffffffffc06b3000
iptable_nat 16384 2 - Live 0xffffffffc06ab000
nf_nat 53248 4 xt_nat,xt_MASQUERADE,ip6table_nat,iptable_nat, Live 0xffffffffc0698000
nf_conntrack 180224 6 ip_vs,xt_nat,xt_conntrack,xt_MASQUERADE,nf_conntrack_netlink,nf_nat, Live 0xffffffffc065d000
nf_defrag_ipv6 24576 2 ip_vs,nf_conntrack, Live 0xffffffffc0610000
fuse 167936 5 - Live 0xffffffffc05e6000
nf_defrag_ipv4 16384 1 nf_conntrack, Live 0xffffffffc0498000
libcrc32c 16384 4 ip_vs,nf_tables,nf_nat,nf_conntrack, Live 0xffffffffc0428000
crypto_user 20480 0 - Live 0xffffffffc03ff000
ip_tables 32768 3 iptable_mangle,iptable_filter,iptable_nat, Live 0xffffffffc048f000
x_tables 53248 16 xt_statistic,iptable_mangle,ip6table_mangle,ip6table_filter,xt_comment,xt_mark,xt_nat,xt_tcpudp,xt_conntrack,xt_MASQUERADE,xt_addrtype,iptable_filter,ip6table_nat,ip6_tables,iptable_nat,ip_tables, Live 0xffffffffc043a000
ext4 929792 1 - Live 0xffffffffc0502000
crc32c_generic 16384 0 - Live 0xffffffffc04fa000
crc16 16384 2 bluetooth,ext4, Live 0xffffffffc04f5000
mbcache 16384 1 ext4, Live 0xffffffffc04f0000
jbd2 151552 1 ext4, Live 0xffffffffc04be000
rtsx_pci_sdmmc 32768 0 - Live 0xffffffffc04b1000
serio_raw 20480 0 - Live 0xffffffffc04a8000
atkbd 36864 0 - Live 0xffffffffc049e000
mmc_core 188416 1 rtsx_pci_sdmmc, Live 0xffffffffc0460000
libps2 20480 1 atkbd, Live 0xffffffffc0457000
crc32c_intel 24576 3 - Live 0xffffffffc044c000
i8042 32768 1 hp_accel, Live 0xffffffffc0431000
rtsx_pci 106496 1 rtsx_pci_sdmmc, Live 0xffffffffc040d000
xhci_pci 20480 0 - Live 0xffffffffc03f9000
serio 28672 5 hp_accel,serio_raw,atkbd,i8042, Live 0xffffffffc03ed000
*** /proc/version
*** ls: -r–r–r-- 1 root root 0 2021-11-17 13:54:59.619999973 +0800 /proc/version
Linux version 5.13.19-2-MANJARO (builduser@fv-az39-393) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021
*** /proc/pci does not exist
*** /proc/iomem
*** ls: -r–r–r-- 1 root root 0 2021-11-17 14:04:50.098848552 +0800 /proc/iomem
00000000-00000fff : Reserved
00001000-0009efff : System RAM
0009f000-000fffff : Reserved
000a0000-000bffff : PCI Bus 0000:00
000f0000-000fffff : System ROM
00100000-344fffff : System RAM
34500000-34546fff : Reserved
34547000-3affffff : System RAM
3b000000-3bffffff : Reserved
3c000000-3c800fff : System RAM
3c801000-3c8c4fff : Unknown E820 type
3c8c5000-3f9f9fff : Reserved
3f9fa000-3fb32fff : ACPI Non-volatile Storage
3faa8000-3faa8fff : USBC000:00
3fb33000-3fbfefff : ACPI Tables
3fbff000-3fbfffff : System RAM
3fc00000-45ffffff : Reserved
46e00000-46ffffff : Reserved
48000000-507fffff : Reserved
4c800000-507fffff : Graphics Stolen Memory
50800000-bfffffff : PCI Bus 0000:00
50800000-50800fff : 0000:00:1f.5
50800000-50800fff : 0000:00:1f.5 0000:00:1f.5
52000000-5e1fffff : PCI Bus 0000:2c
60000000-6c1fffff : PCI Bus 0000:02
6d000000-6e0fffff : PCI Bus 0000:01
6d000000-6dffffff : 0000:01:00.0
6e000000-6e003fff : 0000:01:00.1
6e080000-6e0fffff : 0000:01:00.0
6e100000-6eafffff : PCI Bus 0000:57
6e100000-6e100fff : 0000:57:00.0
6e100000-6e100fff : rtsx_pci
6eb00000-6ebfffff : PCI Bus 0000:56
6eb00000-6eb03fff : 0000:56:00.0
6eb00000-6eb03fff : nvme
6ec80000-6ec9ffff : 0000:00:1f.6
6ec80000-6ec9ffff : e1000e
6eca1000-6eca1fff : 0000:00:16.3
c0000000-cfffffff : PCI MMCONFIG 0000 [bus 00-ff]
c0000000-cfffffff : Reserved
fd000000-fd68ffff : pnp 00:07
fd690000-fd69ffff : INT34C6:00
fd690000-fd69ffff : INT34C6:00 INT34C6:00
fd6a0000-fd6affff : INT34C6:00
fd6a0000-fd6affff : INT34C6:00 INT34C6:00
fd6b0000-fd6bffff : INT34C6:00
fd6b0000-fd6bffff : INT34C6:00 INT34C6:00
fd6c0000-fd6cffff : pnp 00:07
fd6d0000-fd6dffff : INT34C6:00
fd6d0000-fd6dffff : INT34C6:00 INT34C6:00
fd6e0000-fd6effff : INT34C6:00
fd6e0000-fd6effff : INT34C6:00 INT34C6:00
fd6f0000-fdffffff : pnp 00:07
fe000000-fe01ffff : pnp 00:07
fe042000-fe042007 : pnp 00:0a
fe042008-fe042fff : pnp 00:09
fe043000-fe043fff : pnp 00:09
fe04c000-fe04ffff : pnp 00:07
fe050000-fe0affff : pnp 00:07
fe0d0000-fe0fffff : pnp 00:07
fe200000-fe7fffff : pnp 00:07
fec00000-fec003ff : IOAPIC 0
fed00000-fed003ff : HPET 0
fed00000-fed003ff : PNP0103:00
fed20000-fed7ffff : Reserved
fed20000-fed7ffff : pnp 00:05
fed40000-fed44fff : pnp 00:06
fed84000-fed84fff : dmar1
fed85000-fed85fff : dmar2
fed90000-fed90fff : dmar0
fed91000-fed91fff : dmar3
feda0000-feda0fff : pnp 00:05
feda1000-feda1fff : pnp 00:05
fedc0000-fedc7fff : pnp 00:05
fedf0000-fedfffff : pnp 00:04
fee00000-feefffff : pnp 00:05
fee00000-fee00fff : Local APIC
ff000000-ffffffff : Reserved
ff000000-ffffffff : pnp 00:07
100000000-8af7fffff : System RAM
256400000-257202246 : Kernel code
257400000-257d38fff : Kernel rodata
257e00000-2580071ff : Kernel data
258604000-2589fffff : Kernel bss
8af800000-8afffffff : RAM buffer
4000000000-7fffffffff : PCI Bus 0000:00
4000000000-400fffffff : 0000:00:02.0
4010000000-4016ffffff : 0000:00:02.0
4017000000-4017000fff : 0000:00:15.0
4017000000-40170001ff : lpss_dev
4017000000-40170001ff : i2c_designware.0 lpss_dev
4017000200-40170002ff : lpss_priv
4017000800-4017000fff : idma64.0
4017000800-4017000fff : idma64.0 idma64.0
4020000000-40ffffffff : 0000:00:02.0
6000000000-6101ffffff : PCI Bus 0000:01
6000000000-60ffffffff : 0000:01:00.0
6100000000-6101ffffff : 0000:01:00.0
6110000000-612bffffff : PCI Bus 0000:02
6130000000-614bffffff : PCI Bus 0000:2c
614c000000-614cffffff : 0000:00:02.0
614d000000-614d9fffff : PCI Bus 0000:57
614da00000-614dafffff : 0000:00:1f.3
614da00000-614dafffff : Audio DSP
614db00000-614db3ffff : 0000:00:0d.2
614db00000-614db3ffff : thunderbolt
614db40000-614db5ffff : 0000:00:04.0
614db40000-614db5ffff : proc_thermal
614db60000-614db6ffff : 0000:00:14.0
614db60000-614db6ffff : xhci-hcd
614db70000-614db7ffff : 0000:00:12.0
614db70000-614db7ffff : intel_ish_ipc
614db80000-614db8ffff : 0000:00:0d.0
614db80000-614db8ffff : xhci-hcd
614db90000-614db97fff : 0000:00:0a.0
614db94000-614db94fff : telem0
614db96378-614db96387 : pmt_telemetry.1.auto
614db96378-614db96387 : pmt_telemetry.1.auto pmt_telemetry.1.auto
614db96388-614db96397 : pmt_telemetry.1.auto
614db96388-614db96397 : pmt_telemetry.1.auto pmt_telemetry.1.auto
614db98000-614db9bfff : 0000:00:1f.3
614db98000-614db9bfff : Audio DSP
614db9c000-614db9ffff : 0000:00:14.3
614db9c000-614db9ffff : iwlwifi
614dba0000-614dba3fff : 0000:00:14.2
614dba4000-614dba40ff : 0000:00:1f.4
614dba5000-614dba5fff : 0000:00:16.0
614dba5000-614dba5fff : mei_me
614dba7000-614dba7fff : 0000:00:14.2
614dba8000-614dba8fff : 0000:00:0d.2
614dba9000-614dba9fff : 0000:00:08.0
*** /proc/mtrr
*** ls: -rw-r–r-- 1 root root 0 2021-11-17 14:04:50.105517076 +0800 /proc/mtrr
reg00: base=0x080000000 ( 2048MB), size= 2048MB, count=1: uncachable
reg01: base=0x060000000 ( 1536MB), size= 512MB, count=1: uncachable
reg02: base=0x050000000 ( 1280MB), size= 256MB, count=1: uncachable
reg03: base=0x04c000000 ( 1216MB), size= 64MB, count=1: uncachable
reg04: base=0x2000000000 (131072MB), size=131072MB, count=1: uncachable
reg05: base=0x1000000000 (65536MB), size=65536MB, count=1: uncachable
reg06: base=0x4000000000 (262144MB), size=262144MB, count=1: uncachable
*** /proc/driver/nvidia/./version does not exist
*** /proc/driver/nvidia/./params does not exist
*** /proc/driver/nvidia/./registry does not exist
*** /proc/asound/cards
*** ls: -r–r–r-- 1 root root 0 2021-11-17 14:04:50.122188382 +0800 /proc/asound/cards
1 [HEADSET ]: USB-Audio - HUAWEI USB-C HEADSET
bestechnic HUAWEI USB-C HEADSET at usb-0000:00:14.0-10, full speed
*** /proc/asound/pcm
*** ls: -r–r–r-- 1 root root 0 2021-11-17 14:04:50.128856905 +0800 /proc/asound/pcm
01-00: USB Audio : USB Audio : playback 1 : capture 1
*** /proc/asound/modules
*** ls: -r–r–r-- 1 root root 0 2021-11-17 14:04:50.132191168 +0800 /proc/asound/modules
1 snd_usb_audio
*** /proc/asound/devices
*** ls: -r–r–r-- 1 root root 0 2021-11-17 14:04:50.135525428 +0800 /proc/asound/devices
2: [ 1- 0]: digital audio playback
3: [ 1- 0]: digital audio capture
4: [ 1] : control
33: : timer
*** /proc/asound/version
*** ls: -r–r–r-- 1 root root 0 2021-11-17 14:04:50.142193952 +0800 /proc/asound/version
Advanced Linux Sound Architecture Driver Version k5.13.19-2-MANJARO.
*** /proc/asound/timers
*** ls: -r–r–r-- 1 root root 0 2021-11-17 14:04:50.145528213 +0800 /proc/asound/timers
G0: system timer : 3333.333us (10000000 ticks)
P1-0-0: PCM playback 1-0-0 : SLAVE
P1-0-1: PCM capture 1-0-1 : SLAVE
*** /proc/asound/hwdep
*** ls: -r–r–r-- 1 root root 0 2021-11-17 14:04:50.148862475 +0800 /proc/asound/hwdep
*** ls: lrwxrwxrwx 1 root root 0 2021-11-17 13:55:00.863333276 +0800 /sys/class/drm/card0/device/driver → …/…/…/bus/pci/drivers/i915
*** ls: lrwxrwxrwx 1 root root 0 2021-11-17 13:55:00.863333276 +0800 /sys/class/drm/renderD128/device/driver → …/…/…/bus/pci/drivers/i915
Skipping vulkaninfo output (vulkaninfo not found)
/sbin/nvidia-smi --query
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
/sbin/nvidia-smi --query --unit
base64 “nvidia-nvml-temp8247.log”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/sbin/nvidia-debugdump -D
Error: nvmlInit(): Driver Not Loaded
Skipping acpidump output (acpidump not found)
End of NVIDIA bug report log file.
