When I first installed Manjaro then there was sound but the full volume was not loud enough. After some updates I am not hearing any sound att all.
inxi -Fazy
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: QUANTA
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
I have uninstalled pulseaudio and installed pipewire but still not solved.
sudo systemctl status pipewire.socket 1 ✘
[sudo] password for neel:
Unit pipewire.socket could not be found.
~ systemctl --user status pipewire.socket 4 ✘
● pipewire.socket - PipeWire Multimedia System Socket
Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; preset: enabled)
Active: active (running) since Sun 2022-09-04 18:51:37 CEST; 16min ago
Until: Sun 2022-09-04 18:51:37 CEST; 16min ago
Triggers: ● pipewire.service
Listen: /run/user/1001/pipewire-0 (Stream)
CGroup: /user.slice/user-1001.slice/user@1001.service/app.slice/pipewire.socket
Sep 04 18:51:37 laptop systemd[694]: Listening on PipeWire Multimedia System Socket.
~ systemctl --user status pipewire.service ✔
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
Active: active (running) since Sun 2022-09-04 18:51:38 CEST; 16min ago
TriggeredBy: ● pipewire.socket
Main PID: 907 (pipewire)
Tasks: 2 (limit: 18915)
Memory: 10.4M
CPU: 2.298s
CGroup: /user.slice/user-1001.slice/user@1001.service/session.slice/pipewire.service
└─907 /usr/bin/pipewire
Sep 04 18:51:38 laptop systemd[694]: Started PipeWire Multimedia Service.
~ systemctl --user status pulseaudio.service ✔
Unit pulseaudio.service could not be found.
~ systemctl --user status pulseaudio.socket 4 ✘
Unit pulseaudio.socket could not be found.
~ sudo systemctl status pulseaudio.socket 4 ✘
~ sudo systemctl status pulseaudio.service 4 ✘
$ pactl info 1 ✘
Server String: /run/user/1001/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 434
Tile Size: 65472
User Name: neel
Host Name: sunanda-laptop
Server Name: PulseAudio (on PipeWire 0.3.56)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
Default Source: alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source
Cookie: ed04:6ee7
After failing wwith pipewire I have uninstalled it and installed manjaro-pulse
sudo pacman -Rdd manjaro-pipewire pipewire-alsa pipewire-pulse pipewire-zeroconf pipewire-media-session
sudo pacman -S majnaro-pulse
But due to plasma shell’s dependence on libpipewire-0.3.so.0
I had to reinstall only the pipewire
package.
It doesn’t make anything better. No sound with pulse also.
