Excuse me! Is Manjaro compiled with gcc or clang? Thank you!
It’s gcc.
Ok! Thanks! Is there a way to check this?
In the gitlab repo for the various kernels you can see in the config file
Or when you do
ls -l /usr/bin/cc
lrwxrwxrwx 1 root root 3 Aug 2 02:06 /usr/bin/cc -> gcc
I guess the kernel could be compiled using either one and this value set as the other (maybe? Someone please correct me if I am mistaken), but that would seem strange to do.
Another place is
cat /proc/version
Linux version 6.6.3-1-MANJARO (builduser@fv-az1202-264) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Tue Nov 28 20:37:45 UTC 2023
In that string it says gcc
Good! Thanks a lot!
