Manjaro freezing when doing certain things
Hi, i am using manjaro for a week now and is great! the games run better tan windows and system is really light. But there is a problem, my manjaro sometimes when i try to install something or open something it freeze the tab and after that everything that i try to open freezes too until the hole system freeze and i need to restart to use desktop again. I think maybe there is something wrong with my computer to run linux distros, Ubuntu simply just doesn’t work, to installation to desktop there is tons of bugs and freeze all the time (Ubuntu bases distros like PopOS do the same things).
I am really scared that even manjaro will not work right in my pc, i’m tired of creating new system every time, if windows that is so heavy was running with no problems why linux are running so bad? And i dont want to go back to windows, i hate that thing with passion.
Going to the point now (sorry for the little vent) my manjaro usually freeze when i open the “add/remove apps” and freeze with any app really time to time. there is something i can do to make with run normal or i will need to go back to windows?
I am thiking of trying to reeinstall manjaro in my HD and see if it work, maybe the iso was broken (i tested but it can be still broken the one i used to install).
(obs: i just used linux mint years ago and just used for 10 months, i am almost full new to linux)
Anyway, here my system info that i could collect.
inxi -Fxz:
  Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  Desktop: Xfce 4.16.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: TUF B360M-PLUS GAMING/BR v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 2401 date: 03/22/2019
  Info: 6-Core model: Intel Core i5-9600KF bits: 64 type: MCP
  arch: Kaby Lake note: check rev: D cache: L2: 9 MiB
  bogomips: 44398
  Speed: 4386 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 4386 2: 4398
  3: 4397 4: 4375 5: 4387 6: 4398
  Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] driver: nvidia
  v: 460.73.01 bus-ID: 01:00.0
  Display: x11 server: X,Org 1.20.11 driver: loaded: nvidia
  resolution: 1920x1080~75Hz
  OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 00:1f.3
  Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel
  v: kernel bus-ID: 01:00.1
  Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: no
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
  port: efa0 bus-ID: 00:1f.6
  Device-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
  v: kernel port: 3000 bus-ID: 04:00.0
  IF: wlp4s0 state: up mac: <filter>
  Local Storage: total: 931.51 GiB used: 178.4 GiB (19.2%)
  ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-75WN4A1
  ID-1: / size: 915.53 GiB used: 178.4 GiB (19.5%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
  dev: /dev/sda1
  System Temperatures: cpu: 62.0 C mobo: N/A gpu: nvidia temp: 49 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
  Processes: 230 Uptime: 3h 48m Memory: 15.55 GiB used: 6.57 GiB (42.2%)
  Init: systemd Compilers: gcc: 10.2.0 Packages: 1256 Shell: Bash v: 5.1.4
  inxi: 3.3.04
Part of system log:
mai 14 22:16:38 NetvorSystem kernel: pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 17 kernel messages
mai 14 22:16:38 NetvorSystem kernel: pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 11 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 20 kernel messages
mai 14 22:16:38 NetvorSystem kernel: pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 22 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 14 kernel messages
mai 14 22:16:38 NetvorSystem kernel: pcieport 0000:00:1c.5:   device [8086:a33d] error status/mask=00000001/00002000
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 18 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 19 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 13 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 24 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 12 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 23 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 15 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 27 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 8 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 16 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 7 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 9 kernel messages
mai 14 22:16:38 NetvorSystem systemd-journald[9675]: Missed 21 kernel messages
PCI devices (lspci -v):
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 0d)
	DeviceName: Onboard - Other
	Subsystem: ASUSTeK Computer Inc. PRIME H310M-D
	Flags: bus master, fast devsel, latency 0
	Capabilities: <access denied>
	Kernel driver in use: skl_uncore
	Kernel modules: ie31200_edac
00:01.0 PCI bridge: Intel Corporation 6th-9th Gen Core Processor PCIe Controller (x16) (rev 0d) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 120
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 00004000-00004fff [size=4K]
	Memory behind bridge: a3000000-a40fffff [size=17M]
	Prefetchable memory behind bridge: 0000000090000000-00000000a20fffff [size=289M]
	Kernel driver in use: pcieport
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10) (prog-if 30 [XHCI])
	Subsystem: ASUSTeK Computer Inc. Device 8694
	Flags: bus master, medium devsel, latency 0, IRQ 126
	Memory at a4320000 (64-bit, non-prefetchable) [size=64K]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
	Flags: fast devsel
	Memory at a4336000 (64-bit, non-prefetchable) [disabled] [size=8K]
	Memory at a433c000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
	Flags: bus master, fast devsel, latency 0, IRQ 129
	Memory at a433b000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10) (prog-if 01 [AHCI 1.0])
	DeviceName: Onboard - SATA
	Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 125
	Memory at a4334000 (32-bit, non-prefetchable) [size=8K]
	Memory at a433a000 (32-bit, non-prefetchable) [size=256]
	I/O ports at 5050 [size=8]
	I/O ports at 5040 [size=4]
	I/O ports at 5020 [size=32]
	Memory at a4339000 (32-bit, non-prefetchable) [size=2K]
	Kernel driver in use: ahci
00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #21 (rev f0) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 121
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 00006000-00006fff [size=4K]
	Memory behind bridge: a2100000-a22fffff [size=2M]
	Prefetchable memory behind bridge: 00000000a2300000-00000000a24fffff [size=2M]
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #5 (rev f0) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 122
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: [disabled]
	Memory behind bridge: [disabled]
	Prefetchable memory behind bridge: [disabled]
00:1c.5 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #6 (rev f0) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 123
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 00003000-00003fff [size=4K]
	Memory behind bridge: a4200000-a42fffff [size=1M]
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 124
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
	I/O behind bridge: 00007000-00007fff [size=4K]
	Memory behind bridge: a2500000-a26fffff [size=2M]
	Prefetchable memory behind bridge: 00000000a2700000-00000000a28fffff [size=2M]
00:1f.0 ISA bridge: Intel Corporation Device a308 (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
	DeviceName: Onboard - Sound
	Subsystem: ASUSTeK Computer Inc. Device 86c7
	Flags: bus master, fast devsel, latency 32, IRQ 131
	Memory at a4330000 (64-bit, non-prefetchable) [size=16K]
	Memory at a4100000 (64-bit, non-prefetchable) [size=1M]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
	Flags: medium devsel, IRQ 16
	Memory at a4338000 (64-bit, non-prefetchable) [size=256]
	I/O ports at efa0 [size=32]
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
	Flags: fast devsel
	Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
	DeviceName: Onboard - Ethernet
	Subsystem: ASUSTeK Computer Inc. Device 8672
	Flags: bus master, fast devsel, latency 0, IRQ 128
	Memory at a4300000 (32-bit, non-prefetchable) [size=128K]
	Kernel driver in use: e1000e
	Kernel modules: e1000e
01:00.0 VGA compatible controller: NVIDIA Corporation TU106 [GeForce RTX 2060 Rev. A] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: NVIDIA Corporation Device 12fd
	Flags: bus master, fast devsel, latency 0, IRQ 133
	Memory at a3000000 (32-bit, non-prefetchable) [size=16M]
	Memory at 90000000 (64-bit, prefetchable) [size=256M]
	Memory at a0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at 4000 [size=128]
	Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
	Flags: bus master, fast devsel, latency 0, IRQ 17
	Memory at a4080000 (32-bit, non-prefetchable) [size=16K]
01:00.2 USB controller: NVIDIA Corporation TU106 USB 3.1 Host Controller (rev a1) (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 127
	Memory at a2000000 (64-bit, prefetchable) [size=256K]
	Memory at a2040000 (64-bit, prefetchable) [size=64K]
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU106 USB Type-C UCSI Controller (rev a1)
	Flags: bus master, fast devsel, latency 0, IRQ 130
	Memory at a4084000 (32-bit, non-prefetchable) [size=4K]
	Kernel driver in use: nvidia-gpu
	Kernel modules: i2c_nvidia_gpu
04:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8188EE Wireless Network Adapter (rev 01)
	Subsystem: Realtek Semiconductor Co., Ltd. Device 8197
	Flags: bus master, fast devsel, latency 0, IRQ 132
	I/O ports at 3000 [size=256]
	Memory at a4200000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: rtl8188ee
	Kernel modules: rtl8188ee
Hey @Netvor, whatever device is there it doesn’t look like it’s working well. Is it a gaming controller?
I would rule that out first.
If you google about the errors on your journal, you’ll get several results suggesting that you may need to pass a kernel parameter in your bootloader config. Check this out:
https://bbs.archlinux.org/viewtopic.php?id=255722
https://askubuntu.com/questions/771899/pcie-bus-error-severity-corrected
To add the kernel parameter, see this HowTo guide and follow the procedure in the section Adding the acpi kernel to grub (Assuming your bootloader is GRUB).
Hope the above helps! :slightly_smiling_face:
Thank you for the reply!
I have reinstall my manjaro and the freezing problem is not showing up, but the pci erros still going, i tried seeing the links that you have send to me but i am still a little confused, i have to install windows on my pc to configure the kernel parameter? Again thank you for the reply and sorry for the late response.
Hi @Netvor
No, you don’t need to reinstall Windows to pass a Linux kernel parameter. This is something that needs to be done via command line on your bootloader configuration.
Assuming you’re using GRUB2 bootloader (most likely, since this is the one that Manjaro installs by default), you need to add the kernel parameter to the line below in the file /etc/default/grub:
GRUB_CMDLINE_LINUX_DEFAULT=
So, for instance, if you’re trying the kernel parameter pcie_aspm=off as suggested in the link from the Arch forum, you need to append that to the contents of that line and making sure it is within the quotation marks:
GRUB_CMDLINE_LINUX_DEFAULT="[original_contents] pcie_aspm=off"
Then, you need to update the configuration with the command
sudo update-grub
If the above kernel parameter does not help, then you might want to try other parameters as per the other link provided before.
Hope this clarifies your question :+1:
