Manjaro freezing randomly on several diferent kernals
As far as I’m aware, this never happens when the computer is not in use. Normally one of three things will happen. 1. It will freeze but sound will continue playing and it will normally unfreeze after a minute or two. The mouse can move like normal, but nothing is intractable. 2.Everything will suddenly slowdown and the mouse will inch slowly across the screen to where you moved it but things are still intractable. Rarely ever comes out of this state. 3. Everything will freeze, the clock doesn’t move while its frozen. The only way to exit is by holding the power button down and hard rebooting. I have several kernels installed and tried them to see if one of them was the problem, but the problem persists.
My system:
  Kernel: 5.18.0-1-rt11-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-rt-x86_64
    root=UUID=53936964-05be-4892-a5a3-06cd8d611438 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASRock model: Z370 Taichi serial: <superuser required>
    UEFI-[Legacy]: American Megatrends v: P1.10 date: 09/08/2017
  RAM: total: 7.69 GiB used: 2.82 GiB (36.7%)
  RAM Report:
  Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
    stepping: 0xA (10) microcode: 0x6E
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88796
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
    f16c flexpriority fma fpu fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp
    hwp_notify ida intel_pt invpcid invpcid_single lahf_lm lm mca mce mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed
    rdtscp rep_good rtm sdbg sep smap smep smx ss sse sse2 sse4_1 sse4_2 ssse3
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: l1tf
  Type: mds
    status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
  Type: srbds status: Vulnerable: No microcode
  Type: tsx_async_abort
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: Gigabyte
    driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2489 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3600x1080 s-dpi: 95 s-size: 963x292mm (37.91x11.50")
    s-diag: 1006mm (39.62")
  Monitor-1: DP-1 pos: bottom-l res: 1680x1050 hz: 60 dpi: 98
    size: 434x270mm (17.09x10.63") diag: 511mm (20.12") modes: N/A
  Monitor-2: HDMI-1 pos: primary,top-right res: 1920x1080 hz: 60 dpi: 96
    size: 509x286mm (20.04x11.26") diag: 584mm (22.99") modes: N/A
  OpenGL: renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    v: 4.6.0 NVIDIA 515.57 direct render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: NVIDIA GA104 High Definition Audio vendor: Gigabyte
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
    class-ID: 0403
  Sound Server-1: ALSA v: k5.18.0-1-rt11-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.54 running: yes
  Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
    chip-ID: 8086:24fb class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Message: Output throttled. IPs: 3; Limit: 10; Override: --limit [1-x;-1 all]
  Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-9:3 chip-ID: 8087:0aa7 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
  Local Storage: total: 1.36 TiB used: 751.6 GiB (53.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
    lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7 temp: 31.9 C scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD5003AZEX-00K3CA0 size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: MBR
  ID-1: / raw-size: 911 GiB size: 895.63 GiB (98.31%) used: 365.14 GiB (40.8%)
    fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 53936964-05be-4892-a5a3-06cd8d611438
  ID-2: /run/media/landon/FC7636A376365E98 raw-size: 464.72 GiB
    size: 464.72 GiB (100.00%) used: 371.26 GiB (79.9%) fs: ntfs dev: /dev/sda2
    maj-min: 8:2 label: N/A uuid: FC7636A376365E98
  ID-3: /run/media/landon/NO_LABEL raw-size: 517.5 MiB
    size: 516.5 MiB (99.80%) used: 5.9 MiB (1.1%) fs: vfat dev: /dev/sda3
    maj-min: 8:3 label: NO_LABEL uuid: CA02-FA7A
  ID-4: /run/media/landon/Storage raw-size: 20.51 GiB
    size: 20.51 GiB (100.00%) used: 15.2 GiB (74.1%) fs: ntfs
    dev: /dev/nvme0n1p2 maj-min: 259:2 label: Storage uuid: CA985AAE985A9931
  ID-1: /dev/sda1 maj-min: 8:1 size: 549 MiB fs: ntfs label: System Reserved
    uuid: B06E12996E125884
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Hub-2: 1-6:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-6.3:4 info: Maxxter Telink Wireless Receiver
    type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 12 Mb/s power: 50mA chip-ID: 248a:8367 class-ID: 0301
  Device-2: 1-6.4:5 info: Razer USA Mamba 2018 (Wireless)
    type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 500mA chip-ID: 1532:0072 class-ID: 0300
  Device-3: 1-9:3 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
  Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
  Hub-4: 2-6:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 26.0 C mobo: N/A gpu: nvidia temp: 48 C
  Processes: 388 Uptime: 9m wakeups: 1 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 alt: 11 clang: 14.0.6 Packages: 1601
  pacman: 1548 lib: 374 flatpak: 40 snap: 13 Shell: Zsh v: 5.9 default: Bash
  v: 5.1.16 running-in: yakuake inxi: 3.3.19```
Sounds like you’re running out of RAM, try adding some swap.
Instead of using the power button, do this:
I’ll keep htop open next time I’m using my computer because it will just be running perfectly then stop
Add a swap file.
It is very easy to setup!
Otherwise, you could try the non-rt kernels.
I’m considering just upgrading my because my harddrive is slow and my other storage is an ssd( also the real time kernel was the one a was trying at the time)
