Hi,
I’ve been using Manjaro for around 3 months now, just coming out of Windows for the first time ever, but my computer keeps freezing when running on battery. I’ve tried several kernels, but the problem persists.
I also can’t seem to get the soft restart (alt + prt sc + reisub) to work, so I have to constantly press the power button to shutdown and restart.
Some of the suggestions I found through searches are just too technical for my current knowledge, can you please help?
Thank you so much, I managed to get the alt + prt scr + reisuo command to work with the first link you sent me!
As for the main problem regarding constant system freezes while using battery only, can anyone help?
is odd. Also, why is the charge at 59% if there’s no other OS and manjaro crashes immediately when on battery; shouldn’t the battery then be at around 97-100%? Does it charge ok?
I tried this option, but still no luck. It does seem to freeze a bit less often, once every hour or so.
Also, as I stated before, the soft restart option doesn’t work when the system freezes.
Any other options that might help with this issue?
That was the kernel I first installed, the freezes happened there as well, that’s why I ended up updating to 5.13.19-2 and then to 5.14.21-2. I even downgraded to 5.4.169-1, but the problem still occurred
