Hello,
I’m having issues booting my machine and only able to get to the screen prior to the login screen, where it says “Manjaro” at the bottom and there are three status dots that illuminate sequentially as the system boots. It stays at this screen and will not proceed to the user login screen. If I hit the Esc key while at this screen, I see the following:
"/dev/mapper/luks-cdfd8ff4-c22f-4212-8ce0-ad5acd508570: recovering journal
Error reading block 60885539 (input/output error).
/dev/mapper/luks-cdfd8ff4-c22f-4212-8ce0-ad5acd508570: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY (i.e., without -a or -p options)"
My system info is as follows:
Intel Core i5-6500 3.2GHz CPU
Intel HD GPU
16GB Memory
If anyone has any advice, it would be greatly appreciated.
