I’m using Orange Pi 800 (RK3399) with latest Manjaro 23.02 after full system upgrade.
HDMI works perfectly well, as well as audio both in HDMI and in the headphones output (onboard speaker is not working).
The board has a VGA port that is used as an eDP display.
I can’t figure out why it’s not working.
When I’m doing xrandr it does show the EDP display as an option, but whenever I actually connect the display there - no display works afterwards (even the HDMI won’t return).
UPDATE:
I checked again now by connecting via ssh to Manjaro to see what happens when I connect the display and i found out that once I connect the display, the systemd show “waiting…” in the ps aux window… and any attemt to do “dmesg” or “cat /var/log/syslog” are simply stuck forever… as if some main kernel module hangs indefinitely.
Anyone know how to help?
Thanks
