Hey,
I am having this annoying bug where my laptop would randomly freeze only when it is charging. I have tried anything from adding things to grub and disabling TLP. However when I unplug my laptop everything is fine. The logs don’t really show a specific error and I can’t find any weird behavior which causes the freezes. I have also tried multiple kernels, this doesn’t make a change.
My output of inxi --admin --verbosity=7 --filter --no-host --width:
Kernel: 6.0.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.0-x86_64
root=UUID=659c1a4a-087a-4291-8897-0982d30ea49b rw rootflags=subvol=@ quiet
splash apparmor=1 amd_iommu=off security=apparmor
resume=UUID=7682d855-780d-43d8-a951-05819855057d udev.log_priority=3
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Convertible System: HP product: HP ENVY x360 Convertible 15-bq1xx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 83C6 v: 63.18 serial: <superuser required> UEFI: AMI
v: F.23 date: 08/12/2021
ID-1: BAT0 charge: 16.0 Wh (64.0%) condition: 25.0/25.0 Wh (100.0%)
volts: 12.8 min: 11.6 model: 333-42-2C LK03055XL type: Li-ion
serial: <filter> status: charging
Device-1: hid-0018:04F3:FFFF.0006-battery model: ELAN0732:00 04F3:FFFF
serial: N/A charge: N/A status: N/A
RAM: total: 31.06 GiB used: 5.43 GiB (17.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen level: v3 built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101007
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1622 high: 2000 min/max: 1600/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1381 2: 1600
3: 1600 4: 2000 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 31952
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: DP-1,eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:15dd class-ID: 0300
Device-2: Realtek HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 0bda:58e6 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
display-ID: 0
Monitor-1: DP-1 model: ASUS MB16AC serial: <filter> built: 2020
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 model: BOE Display 0x0819 built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.48
6.0.0-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k6.0.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
chip-ID: 10ec:b822 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 3-2.4:4 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Local Storage: total: 1.36 TiB used: 274.83 GiB (19.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3T0 scheme: GPT
ID-1: / raw-size: 310 GiB size: 310 GiB (100.00%) used: 274.83 GiB (88.7%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 659c1a4a-087a-4291-8897-0982d30ea49b
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 612 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 5C0B-28D5
ID-3: /home raw-size: 310 GiB size: 310 GiB (100.00%) used: 274.83 GiB
(88.7%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
ID-4: /var/cache raw-size: 310 GiB size: 310 GiB (100.00%) used: 274.83
GiB (88.7%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
ID-5: /var/log raw-size: 310 GiB size: 310 GiB (100.00%) used: 274.83 GiB
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 7682d855-780d-43d8-a951-05819855057d
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 342B-1CD9
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 152.65 GiB fs: ntfs label: N/A
uuid: 50BC2FE2BC2FC178
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 505 MiB fs: ntfs label: N/A
uuid: CC5EC41A5EC3FAEA
ID-5: /dev/sda1 maj-min: 8:1 size: 703.52 GiB fs: ntfs label: DATA
uuid: 024EB1E14EB1CE23
ID-6: /dev/sda2 maj-min: 8:2 size: 513 MiB fs: vfat label: N/A
uuid: 9466-1833
ID-7: /dev/sda3 maj-min: 8:3 size: 13.46 GiB fs: ntfs label: RECOVERY
uuid: DC74B4A874B48734
ID-8: /dev/sda4 maj-min: 8:4 size: 214.03 GiB fs: ext4 label: N/A
uuid: 04b44ea8-edab-42a2-a8d5-ab0740f545a0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:3 info: Realtek HP Wide Vision FHD Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 2-1:2 info: Realtek 4-Port USB 3.0 Hub ports: 2 rev: 3.1
speed: 5 Gb/s chip-ID: 0bda:0412 class-ID: 0900
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-2.3:3 info: STMicro Sensor Hub type: HID
driver: hid-sensor-hub,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0483:91d1 class-ID: 0300 serial: <filter>
Device-2: 3-2.4:4 info: Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-6: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.1 C mobo: N/A gpu: amdgpu temp: 49.0 C
Processes: 348 Uptime: 7m wakeups: 3 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1507
pm: pacman pkgs: 1485 libs: 329 tools: aura,gnome-software,pamac pm: flatpak
pkgs: 22 Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.21
The output of journalctl -b -1
Sep 21 13:06:20 julian-hp kernel: Linux version 6.0.0-1-MANJARO (builduser@fv-az77-747) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT_DYNAMIC Sun Sep 4 20:49:47 UTC 2022
Sep 21 13:06:20 julian-hp kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-6.0-x86_64 root=UUID=659c1a4a-087a-4291-8897-0982d30ea49b rw rootflags=subvol=@ quiet splash apparmor=1 amd_iommu=o>
Sep 21 13:06:20 julian-hp kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Sep 21 13:06:20 julian-hp kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Sep 21 13:06:20 julian-hp kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Sep 21 13:06:20 julian-hp kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Sep 21 13:06:20 julian-hp kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
Sep 21 13:06:20 julian-hp kernel: signal: max sigframe size: 1776
Sep 21 13:06:20 julian-hp kernel: BIOS-provided physical RAM map:
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x0000000004000000-0x000000000400ffff] ACPI NVS
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x0000000004010000-0x0000000009e9ffff] usable
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x0000000009ea0000-0x0000000009ffffff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x000000000a000000-0x00000000c9f45fff] usable
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000c9f46000-0x00000000c9f4dfff] ACPI data
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000c9f4e000-0x00000000ccfc1fff] usable
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000ccfc2000-0x00000000cd0adfff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000cd0ae000-0x00000000cd0ddfff] ACPI data
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000cd0de000-0x00000000cd5b5fff] ACPI NVS
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000cd5b6000-0x00000000cdc93fff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000cdc94000-0x00000000cdd62fff] type 20
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000cdd63000-0x00000000ceffffff] usable
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000cf000000-0x00000000dfffffff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000fd800000-0x00000000fd8fffff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000fe800000-0x00000000fe800fff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Sep 21 13:06:20 julian-hp kernel: BIOS-e820: [mem 0x0000000100000000-0x000000081f33ffff] usable
Sep 21 13:06:20 julian-hp kernel: NX (Execute Disable) protection: active
Sep 21 13:06:20 julian-hp kernel: efi: EFI v2.60 by American Megatrends
Sep 21 13:06:20 julian-hp kernel: efi: ACPI 2.0=0xcd0b1000 ACPI=0xcd0b1000 SMBIOS=0xcdbff000 SMBIOS 3.0=0xcdbfe000 ESRT=0xcbf8d098
...skipping...
Sep 21 13:10:28 julian-hp dbus-daemon[1753]: [session uid=1000 pid=1753] Successfully activated service 'org.freedesktop.Flatpak'
Sep 21 13:10:28 julian-hp systemd[1728]: Started flatpak session helper.
Sep 21 13:10:28 julian-hp systemd[1728]: Started app-flatpak-com.spotify.Client-6246.scope.
Sep 21 13:10:29 julian-hp com.spotify.Client.desktop[6268]: /app/extra/bin/spotify: /app/lib/libcurl-gnutls.so.4: no version information available (required by /app/extra/bin/spotify)
Sep 21 13:10:29 julian-hp com.spotify.Client.desktop[6268]: [spotifywm] attached to spotify
Sep 21 13:10:29 julian-hp com.spotify.Client.desktop[6274]: /app/extra/share/spotify/spotify: /app/lib/libcurl-gnutls.so.4: no version information available (required by /app/extra/share/spo>
Sep 21 13:10:29 julian-hp com.spotify.Client.desktop[6275]: /app/extra/share/spotify/spotify: /app/lib/libcurl-gnutls.so.4: no version information available (required by /app/extra/share/spo>
Sep 21 13:10:29 julian-hp com.spotify.Client.desktop[6274]: [spotifywm] attached to spotify
Sep 21 13:10:29 julian-hp com.spotify.Client.desktop[6275]: [spotifywm] attached to spotify
Sep 21 13:10:31 julian-hp spotify[6268]: Failed to load module "canberra-gtk-module"
Sep 21 13:10:31 julian-hp com.spotify.Client.desktop[6303]: /proc/self/exe: /app/lib/libcurl-gnutls.so.4: no version information available (required by /proc/self/exe)
Sep 21 13:10:31 julian-hp com.spotify.Client.desktop[6303]: [spotifywm] attached to spotify
Sep 21 13:10:31 julian-hp com.spotify.Client.desktop[6290]: libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
Sep 21 13:10:31 julian-hp com.spotify.Client.desktop[6290]: [spotifywm] spotify window found
Sep 21 13:10:32 julian-hp spotify[6268]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Sep 21 13:10:34 julian-hp com.spotify.Client.desktop[6290]: [spotifywm] spotify window found
Sep 21 13:11:17 julian-hp jetbrains-webstorm.desktop[3019]: 2022-09-21 13:11:17,940 [ 265763] WARN - #copilot - [ERROR] [streamChoices] [2022-09-21T11:11:17.937Z] Invalid streamingData
Sep 21 13:11:17 julian-hp jetbrains-webstorm.desktop[3019]: 2022-09-21 13:11:17,940 [ 265763] WARN - #copilot - [ERROR] [streamChoices] [2022-09-21T11:11:17.937Z] Invalid streamingData,joi>
Sep 21 13:11:40 julian-hp rtkit-daemon[1251]: Supervising 3 threads of 3 processes of 1 users.
Sep 21 13:11:41 julian-hp touchegg[577]: libinput error: event15 - SynPS/2 Synaptics TouchPad: kernel bug: Touch jump detected and discarded.
Sep 21 13:11:41 julian-hp touchegg[577]: See https://wayland.freedesktop.org/libinput/doc/1.21.0/touchpad-jumping-cursors.html for details
Sep 21 13:11:41 julian-hp gnome-shell[1819]: libinput error: event15 - SynPS/2 Synaptics TouchPad: kernel bug: Touch jump detected and discarded.
Sep 21 13:11:41 julian-hp gnome-shell[1819]: See https://wayland.freedesktop.org/libinput/doc/1.21.0/touchpad-jumping-cursors.html for details
Sep 21 13:11:47 julian-hp rtkit-daemon[1251]: Supervising 3 threads of 3 processes of 1 users.
Sep 21 13:11:48 julian-hp gnome-shell[3531]: [2022-09-21T11:11:48Z ERROR mp4parse] Found 2 nul bytes in "\0\0"
Sep 21 13:11:52 julian-hp rtkit-daemon[1251]: Supervising 3 threads of 3 processes of 1 users.
Sep 21 13:11:52 julian-hp kernel: logitech-hidpp-device 0003:046D:4082.0005: HID++ 4.5 device connected.
Sep 21 13:11:56 julian-hp wpa_supplicant[871]: wlp3s0: PMKSA-CACHE-ADDED 88:1d:fc:55:96:6f 0
Sep 21 13:11:56 julian-hp wpa_supplicant[871]: wlp3s0: PMKSA-CACHE-ADDED a8:9d:21:6d:7b:e0 0
Sep 21 13:12:40 julian-hp spotify[6268]: App Name is not available when using Portal Notifications
Sep 21 13:14:46 julian-hp spotify[6268]: App Name is not available when using Portal Notifications
Sep 21 13:14:51 julian-hp spotify[6268]: App Name is not available when using Portal Notifications
