I am new to Linux and have been using Manjaro for a few months now but since I’ve installed the 5.10 kernel yesterday, after maybe 20 minuets to an hour of using the computer things start to freeze and nothing seems to respond. I can’t really open any new applications and xfce does not seem to work either since it does not respond when I click on things either. It keeps doing this each time I restart.
I am not 100% sure that it is the kernel but since this has only really started since I updated the kernel, I think it must be. Even in a different tty i can’t seem to login since when I input my password it just seems to freeze.
Here is the output of inxi -Fazy
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=3de4fccc-4029-4c66-a16e-b0de822e7595 rw quiet apparmor=1
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel, plank wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME H310M-R R2.0 v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 1003 date: 10/11/2019
Info: 6-Core model: Intel Core i5-9400F bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
L2 cache: 9 MiB
bogomips: 34814
Speed: 4000 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 4000 2: 4000
3: 4000 4: 4000 5: 4001 6: 3994
Device-1: NVIDIA TU116 [GeForce GTX 1660] driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:2184
Display: x11 server: X.Org 1.20.10 driver: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: GeForce GTX 1660/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:1aeb
Sound Server: ALSA v: k5.10.2-2-MANJARO
Processes: 212 Uptime: 1m wakeups: 0 Memory: 15.58 GiB used: 1.08 GiB (7.0%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages:
pacman: 1260 lib: 374 flatpak: 0 Shell: Zsh v: 5.8
running in: xfce4-terminal inxi: 3.2.01
