I installed manjaro linux KDE on a Lenovo ThinkBook 15p.
I noticed some glitcieness with the open source drivers when plugging in the second monitor, so I used the “install proprietary driver” in the hardware config screen, then restarted.
Everything worked good enough, until I attempted to plug in a second display through a HDMI port.
When I attempted to do that, the screen stayed blank, with a “no signal” warning.
Unplugging and replugging 2 or 3 times, it finally recognises the monitor and everything works fine.
After that, if the monitor in unplugged and replugged in less than about 10 seconds everything works.
If I wait longer before replugging, the same blank screen happens- as if the monitor was never plugged in.
Also, running the xrandr
command while the hdmi is plugged in, fixes it too.
Here are the journal logs after unplugging, then replugging the monitor:
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: RRNotify_OutputChange
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Output: 66
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 63
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Mode: 68
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Rotation: "Rotate_0"
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Connection: "Connected"
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Subpixel Order: 0
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Output: 570
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 566
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Mode: 571
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Connection: "Disconnected"
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: RRScreenChangeNotify
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Window: 44040197
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Root: 2366
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Size ID: 65535
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Size: 1921 2160
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: SizeMM: 506 570
11.12.20 04:43 plasmashell Old primary output: QScreen(0x7fbfb001c3e0, name="HDMI-1-0") New primary output: QScreen(0x558957962870, name="eDP-1")
11.12.20 04:43 plasmashell trying to show an empty dialog
11.12.20 04:43 plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: XRandROutput 66 update
m_connected: 0
m_crtc XRandRCrtc(0x5594c386c080)
CRTC: 63
MODE: 68
Connection: 0
Primary: false
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Output 66 : connected = true , enabled = true
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: XRandROutput 570 update
m_connected: 0
m_crtc XRandRCrtc(0x5594c386ae30)
CRTC: 566
MODE: 571
Connection: 1
Primary: true
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Output 570 : connected = false , enabled = true
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: false
m_connected: 1
CRTC: 566
MODE: 571
Connection: 1
Primary: true
11.12.20 04:43 plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:121: TypeError: Cannot read property 'x' of null
11.12.20 04:43 plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:135: TypeError: Cannot read property 'y' of null
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Emitting configChanged()
11.12.20 04:43 systemsettings5 file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:262:9: QML ActionToolBar: Binding loop detected for property "atBottom"
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: XRandR::setConfig
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Requested screen size is QSize(1920, 1080)
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Needed CRTCs: 1
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Actions to perform:
Primary Output: true
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Old: 570
New: 66
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Change Screen Size: true
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Old: QSize(1921, 2160)
Intermediate: QSize(1921, 2160)
New: QSize(1920, 1080)
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Disable outputs: true
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: (570)
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Change outputs: true
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: (66)
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Enable outputs: false
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: RRSetCrtcConfig (disable output)
CRTC: 566
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Result: 0
m_connected: 1
CRTC: 0
MODE: 0
Connection: 1
Primary: false
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Disconnected output 570 from CRTC 566
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: RRSetCrtcConfig (change output)
Output: 66 ( "eDP-1" )
CRTC: 63
Pos: QPoint(0,0)
Mode: 68 KScreen::Mode(Id: "68" , Size: QSize(1920, 1080) @ 60.0204 )
Rotation: 1
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: RRSetOutputPrimary
New primary: 66
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: RRSetScreenSize
DPI: 96.2526
SizeMM: QSize(506, 285)
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: XRandR::setConfig done!
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: RRNotify_CrtcChange
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Mode: 0
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Rotation: "invalid value (0)"
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Geometry: 0 0 0 0
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 0
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Geometry: 0 0 1920 1080
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Size ID: 0
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: Size: 1920 1080
11.12.20 04:43 kscreen_backend_launcher kscreen.xcb.helper: SizeMM: 506 285
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
11.12.20 04:43 kscreen_backend_launcher kscreen.xrandr: Output 570 : connected = false , enabled = false
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: true
11.12.20 04:43 systemsettings5 file:///usr/lib/qt/qml/org/kde/kirigami.2/FormLayout.qml:337:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
11.12.20 04:44 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43112, resource id: 12582922, major code: 18 (ChangeProperty), minor code: 0
11.12.20 04:44 systemd Started Konsole - Terminal.
11.12.20 04:44 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43612, resource id: 14700697, major code: 3 (GetWindowAttributes), minor code: 0
11.12.20 04:44 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 43613, resource id: 14700697, major code: 14 (GetGeometry), minor code: 0
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: RRNotify_OutputChange
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Output: 570
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 0
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Mode: 0
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Rotation: "Rotate_0"
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Connection: "Connected"
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Subpixel Order: 0
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: XRandROutput 570 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Output 570 : connected = true , enabled = false
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: RRScreenChangeNotify
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Window: 44040197
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Root: 2366
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Size ID: 0
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Size: 1920 1080
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: SizeMM: 506 285
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Emitting configChanged()
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: XRandR::setConfig
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Requested screen size is QSize(1921, 2160)
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Needed CRTCs: 2
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Actions to perform:
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Old: 66
New: 570
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Change Screen Size: true
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Old: QSize(1920, 1080)
New: QSize(1921, 2160)
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Disable outputs: false
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Change outputs: true
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: (66)
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Enable outputs: true
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: (570)
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: RRSetScreenSize
DPI: 96.2526
SizeMM: QSize(506, 570)
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: RRSetCrtcConfig (change output)
CRTC: 63
Pos: QPoint(1,1080)
Rotation: 1
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Result: 0
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: XRandROutput 66 update
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: false
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: QMap((63, XRandRCrtc(0x5594c386c080))(64, XRandRCrtc(0x5594c386c130))(65, XRandRCrtc(0x5594c3873bd0))(566, XRandRCrtc(0x5594c386ae30))(567, XRandRCrtc(0x5594c386aeb0))(568, XRandRCrtc(0x5594c386ade0))(569, XRandRCrtc(0x5594c3872ac0)))
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Testing CRTC 63
Free: false
Mode: 68
Possible outputs: QVector(66)
Connected outputs: QVector(66)
Geometry: QRect(1,1080 1920x1080)
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Testing CRTC 64
Free: true
Mode: 0
Connected outputs: QVector()
Geometry: QRect(0,0 0x0)
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Testing CRTC 65
Free: true
Mode: 0
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Testing CRTC 566
Free: true
Mode: 0
Possible outputs: QVector(570)
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: RRSetCrtcConfig (enable output)
Output: 570 ( "HDMI-1-0" )
New CRTC: 566
Pos: QPoint(0,0)
Mode: KScreen::Mode(Id: "571" , Size: QSize(1920, 1080) @ 60 ) Preferred: "571"
Rotation: 1
m_connected: 0
m_crtc QObject(0x0)
CRTC: 566
MODE: 571
Connection: 0
Primary: true
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Connected output 570 to CRTC 566
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: RRSetOutputPrimary
New primary: 570
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: XRandR::setConfig done!
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Size ID: 65535
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Size: 1921 2160
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: SizeMM: 506 570
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: RRNotify_CrtcChange
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 63
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Mode: 68
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Geometry: 1 1080 1920 1080
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 566
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Mode: 571
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Geometry: 0 0 1920 1080
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Output: 66
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 64
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: Geometry: 0 0 0 0
11.12.20 04:44 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 65
11.12.20 04:44 plasmashell trying to show an empty dialog
11.12.20 04:44 plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
11.12.20 04:44 plasmashell Old primary output: QScreen(0x558957962870, name="eDP-1") New primary output: QScreen(0x7fbfb001b970, name="HDMI-1-0")
m_connected: 0
CRTC: 566
MODE: 571
Connection: 0
Primary: true
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Output 570 : connected = true , enabled = true
m_connected: 0
CRTC: 566
MODE: 571
Connection: 0
Primary: true
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: false
11.12.20 04:44 kscreen_backend_launcher kscreen.xrandr: Output 66 : connected = true , enabled = true
m_connected: 0
CRTC: 566
MODE: 571
Connection: 0
Primary: true
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: false
m_connected: 0
CRTC: 566
MODE: 571
Connection: 0
Primary: true
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: false
m_connected: 0
CRTC: 566
MODE: 571
Connection: 0
Primary: true
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: false
m_connected: 0
CRTC: 566
MODE: 571
Connection: 0
Primary: true
m_connected: 0
CRTC: 63
MODE: 68
Connection: 0
Primary: false
11.12.20 04:44 systemsettings5 file:///usr/lib/qt/qml/org/kde/kirigami.2/FormLayout.qml:337:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
In those logs I unplugged the HDMI cable, waited 10 seconds, then replugged it.
After unsuccessfully trying to make it find the 2nd monitor by replugging it ~3 times, I ran
[edgars@edgars-lenovo ~]$ xrandr --listmonitors
Monitors: 1
0: +*eDP-1 1920/344x1080/194+0+0 eDP-1
and it updated to dual monitors again.
If someone has already had this problem, or you need additional information, please let me know.
