When attempting to boot into manjaro today, I am told that manjaro failed to load the kernel modules. After some reading I followed the advice an booted into a live-manjaro, and executed
sudo manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p5]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
I then chrooted into manjaro following thes instructions: [HowTo] Chroot from or into any Linux distribution
But now I’m lost. Can you please help me to find and fix the issue? The following information might be helpful:
LANG=C sudo parted -l
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
loop1
loop2
loop3
loop4
loop5
loop6
loop7
sda
|-sda1
`-sda2
sr0
nvme0n1
|-nvme0n1p1
|-nvme0n1p2 66.4M 31% /boot/efi
|-nvme0n1p3
|-nvme0n1p4
`-nvme0n1p5 200.4G 80% /
Model: Verbatim STORE N GO (scsi)
Disk /dev/sda: 7744MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 3530MB 3534MB 4194kB primary esp
Model: Force MP510 (nvme)
Disk /dev/nvme0n1: 1920GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 556MB 555MB ntfs Basic data partition hidden, diag
2 556MB 661MB 105MB fat32 EFI system partition boot, esp
3 661MB 677MB 16.8MB Microsoft reserved partition msftres
4 677MB 461GB 460GB ntfs Basic data partition msftdata
5 461GB 1920GB 1460GB ext4 root
The nvme0n1p5 is my manjaro installation.
(base) [manjaro /]# mhwd-kernel -li
Currently running: 5.15.60-1-MANJARO (linux515)
* linux515
