Manjaro doesn't start with a second monitor | Intel UHD Graphics
The problem:
  1. My laptop with Manjaro doesn’t start with a second monitor. I see the logos of manjaro loading but it loads indefinitely.
  2. The monitor works when I connect it afterwards.
Peculiarity:
If I restart Manjaro with a second monitor it works. Which is strange to me.
My graphics:
Intel UHD Graphics
Monitor:
Acer V247Y
Manjaro version (uname -a):
Linux anton-pc 6.1.85-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Apr 10 20:05:44 UTC 2024 x86_64 GNU/Linux
I tried:
I tried making the second monitor primary and vice versa it had no effect whatsoever.
I have no clue what could be the culprit of this behavior, though I suspect it might be laptop related. Because I had my old laptop with Manjaro and it would start with the same second monitor with no problems.
Another system info:
  Kernel: 6.1.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=806cb279-9635-40a3-86d1-06f8059e657b rw quiet splash apparmor=1
    security=apparmor resume=UUID=0f162b99-9246-47c1-a837-651c52425d5d
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: F-Plus Mobile LLC product: FLAPTOP i v: N/A
    serial: <superuser required>
  Mobo: F-Plus Mobile LLC model: f+ FLAPTOP I-SERIES
    serial: <superuser required> part-nu: FLTP-5i5-16512
    uuid: <superuser required> UEFI: American Megatrends LLC. v: 013
    date: 11/11/2022
  ID-1: BAT0 charge: 48.6 Wh (100.0%) condition: 48.6/48.6 Wh (100.0%)
    volts: 8.6 min: N/A model: UTL Q354 type: Li-ion serial: <filter>
    status: charging
  System RAM: total: 16 GiB available: 15.37 GiB used: 3.01 GiB (19.6%)
  Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Shenzhen Longsys
    Electronics Co Ltd part-no: FD4AS3200CQGMZ serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: no module installed
  Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
    microcode: 0x430
  Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
    cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
    L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 434 high: 813 min/max: 400/4400:3300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 813 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59916
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
    waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: reg_file_data_sampling status: Vulnerable: No microcode
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-UP3 GT2 [UHD Graphics] driver: i915 v: kernel
    arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
    active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:4628
    class-ID: 0300
  Device-2: Realtek USB2.0 camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 0bda:5830
  Display: x11 server: X.Org v: 21.1.12 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
    s-diag: 1055mm (41.55") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: Acer V247Y serial: <filter> built: 2023
    res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
    diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 model-id: HKC 0x3d05 built: 2022 res: 1920x1080 dpi: 142
    gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Realtek
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.1.85-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:c822 class-ID: 0280
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:8 chip-ID: 0bda:c822
  Local Storage: total: 2.29 TiB used: 2.02 TiB (88.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Foresee model: XP1000F512G
    lanes: 4 tech: SSD serial: <filter> fw-rev: V1.25 temp: 29.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 9203 scheme: GPT
  ID-1: / raw-size: 117.19 GiB size: 114.79 GiB (97.95%) used: 13.2 GiB (11.5%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 806cb279-9635-40a3-86d1-06f8059e657b
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: B0C3-6437
  ID-3: /home raw-size: 351.25 GiB size: 344.67 GiB (98.13%)
    used: 222.61 GiB (64.6%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 1d64c02a-92b0-4de8-8166-b578bb575b22
  ID-4: /run/media/anton/ADATA HD330 raw-size: 1.82 TiB
    size: 1.82 TiB (100.00%) used: 1.79 TiB (98.4%) fs: ntfs dev: /dev/sda2
    maj-min: 8:2 label: ADATA HD330 uuid: B6BEDBC6BEDB7CF5
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 0f162b99-9246-47c1-a837-651c52425d5d
  ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-1:2 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-1.1:4 info: INSTANT USB GAMING MOUSE type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:1040 class-ID: 0300
  Device-2: 1-1.2:10 info: A-DATA HD330 type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 125f:a83a class-ID: 0806
    serial: <filter>
  Device-3: 1-2:3 info: Realtek USB2.0 camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 0bda:5830 class-ID: 0e02 serial: <filter>
  Device-4: 1-3:5 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Hub-3: 1-7:7 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-7.2:9 info: China Resource Semico USB Gaming Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 1a2c:484a class-ID: 0301
  Device-2: 1-10:8 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:c822 class-ID: e001 serial: <filter>
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-5: 2-2:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  System Temperatures: cpu: 37.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 274 Power: uptime: 48m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 6.14 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 255 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1318 libs: 431 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
    running-in: xfce4-terminal inxi: 3.3.34
Welcome to the forum! :wave:
Please see the following and edit your post accordingly. Adding system info would be very helpful for others to help you:
please use this command, it will filter out every privacy infos and post the output.
Instead of using the [spoiler] tag which just blurs it, instead use the following. Notice there is a carriage return in between the preformatted text area:
[details=“Title”]
preformatted text
[/details]
Which appears like this:
Title
preformatted text
We have a similar problem, today after we upgrade all apps show up to do. and I started. I was working on another ThinkCentre- Lenovo Windows 8. all those PCs share multiple monitors together or separately. When the Manjaro comes up after restart, only one monitor. but when was started to show the Manjaro logo on both monitors the graphics were only in one and the other was still light blue. but dark and try setup do not show 2 monitors. only one. I am pretty sure this is Gnome management on the graphics card. I do not know. please if someone can fix it let me know here.
Device-1: AMD Trinity [Radeon HD 7560D] vendor: Lenovo driver: radeon
v: kernel alternate: amdgpu arch: TeraScale-3 code: Northern Islands
process: TSMC 32nm built: 2010-13 ports: active: VGA-1 empty: DP-1
bus-ID: 00:01.0 chip-ID: 1002:9904 class-ID: 0300
Device-2: AMD Cape Verde PRO / Venus LE Tropo PRO-L [Radeon HD 8830M R7
250 M465X] vendor: Dell driver: radeon v: kernel alternate: amdgpu
arch: GCN-1 code: Southern Islands process: TSMC 28nm built: 2011-20 pcie:
gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1Machine:
Type: Desktop System: LENOVO product: 5100C1U v: ThinkCentre M78Memory:
System RAM: total: 32 GiB available: 30.82 GiB used: 2.33 GiB (7.6%CPU:
Info: model: AMD A8-5500B APU with Radeon HD Graphics bits: 64 type:
@777MultStst Please create your own Support topic. Your hardware is completely different.
