i’m using the plasma environment and the rfkill list only says that Bluetooth isn’t blocked. i updated everything in the system update and tried the set up command and it didn’t seem to work
was the wifi working before update?
hardware info
inxi -Fazy
Why are you telling about bluetooth, when what you have trouble with is wifi?
no, i have been using tethering to update
i forgot the command for hardware info and assumed it was rfkill list
so post output from:
inxi -xN
mhwd-kernel -li
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Dell
driver: bcma-pci-bridge v: N/A bus-ID: 01:00.0
Currently running: 5.10.129-1-MANJARO (linux510) INT ✘
* linux510
* linux54
output also from:
mhwd -l
1 aur/rtl8821ce-dkms-git 1.0.5.r36.gca4abd8-1 (26) (0,46)
rtl8821ce driver with firmware
what is that, thats not the output from mhwd -l
pasted the wrong thing sorry
0000:01:00.0 (0280:14e4:4365) Network controller Broadcom:
NAME VERSION FREEDRIVER TYPE
network-broadcom-wl 2018.10.07 false PCI
0000:00:02.0 (0300:8086:0a16) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
install the driver:
sudo mhwd -i pci network-broadcom-wl
or go to system settings/hardware configuration and click auto install proprietary drivers
then reboot and test
