I am new to linux, have been using only for a month now. I just installed Manjaro 21.3.7 version with KDE. I need to add the Golang compiler to the PATH, which I normally do (in previous distro, Linux Mint) by adding export PATH=$PATH:/usr/local/go/bin
to the ~/.profile
file. I can’t seem to find this file in Manjaro. Will it work if I add this file manually? I temporarily fixed this by adding the same line to ~/.zshrc
file. In the process, another question came to my mind. If Manjaro uses zsh
as default, why does echo $SHELL
return /bin/bash
??? I initially entered this command to check which shell Manjaro uses (returned /bin/bash
) and added the PATH line to ~/.bashrc
which did not work. Adding it to ~/.zshrc
worked, which means Manjaro is actually using zsh
Yes, you can create it manually.
~/.profile
does not exist by default, and creating it will not necessarily result in the file being sourced.
would work, but better would be ~/.zprofile
, if it exists. The logic is that the *rc
file is read at every invocation of an interactive shell, while the *profile
file is only read at login time.
It might also be a good idea to add it to ~/.bash_profile
as well, for reasons explained below.
The system shell is still bash
, and that is the shell you’ll get in a tty
session, but the graphical terminal window profiles have been set up to use zsh
instead. Not everyone is happy about that, but the majority of our users requested it.
Okay that explains everything. ~/.zprofile
does not exist either but ~/.bash_profile
does. I prefer adding PATHs to ~/.*profile
for the same reason, everything is configured at login time. I just removed the PATH from ~/.zshrc
and added it to ~/.bash_profile
and logged in again. It works. Thank you.
