Hi! I’m new to Manjaro, coming from openSUSE Leap.
Manjaro does not detect my Bluetooth adapter. GNOME Settings says:
No Bluetooth Found
Plug in a dongle to use Bluetooth
This may be useful:
$ inxi --admin --verbosity=7 --filter --width
Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.9-x86_64
root=UUID=94126f4b-4320-476b-9b99-6aede8348448 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 46.4 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Type: Laptop System: Acer product: Aspire E5-573 v: V3.72
serial: <superuser required>
Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version
serial: <superuser required> part-nu: Aspire E5-573_098A_1_37
uuid: <superuser required> UEFI: Insyde v: 1.37 date: 02/16/2016
ID-1: BAT1 charge: 0% condition: 8.5/37.0 Wh (23.1%) volts: 13.1 min: 14.8
model: SANYO AL15A32 type: Li-ion serial: <filter> status: charging
System RAM: total: 16 GiB available: 15.54 GiB used: 11.83 GiB (76.2%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: TeamGroup part-no: TMT41GS6BFR8A-PBHJ serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 649 high: 799 min/max: 500/2700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 799 2: 798 3: 500 4: 500
bogomips: 17567
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid lahf_lm
lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel HD Graphics 5500 vendor: Acer Incorporated ALI driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Sunplus Innovation HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-7:3 chip-ID: 1bcf:2c81
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15ca built: 2014 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
device-ID: 8086:1616 memory: 7.59 GiB unified: yes display-ID: :0.0
Device-1: Intel Broadwell-U Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.9.12-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
Device-1: luks-b2ca3ce0-686c-4d15-807d-abccdbf1ff84 maj-min: 254:0
type: LUKS dm: dm-0 size: 230.03 GiB
Components:
p-1: sda7 maj-min: 8:7 size: 230.03 GiB
Local Storage: total: 912.89 GiB used: 245.7 GiB (26.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1103 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST500LM012 HN-M500MBB
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 23.12 GiB (23.1%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5 label: Manjaro
uuid: 94126f4b-4320-476b-9b99-6aede8348448
used: 30.8 MiB (32.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 2882-8FAA
ID-3: /home raw-size: 230.03 GiB size: 229.92 GiB (99.95%)
used: 222.49 GiB (96.8%) fs: xfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b2ca3ce0-686c-4d15-807d-abccdbf1ff84 label: N/A
uuid: fbd31b9a-d0cd-466e-9ae3-5cbdf5f813a7
ID-4: /var/cache raw-size: 100 GiB size: 100 GiB (100.00%)
used: 23.12 GiB (23.1%) fs: btrfs dev: /dev/sda5 maj-min: 8:5 label: Manjaro
ID-5: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: partition size: 17 GiB used: 66 MiB (0.4%) priority: -2
dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 53a44eae-e1af-4934-9cb4-e3b5e96d331a
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 99.48 GiB fs: ntfs label: N/A
uuid: CCE886D3E886BAEA
ID-3: /dev/sda4 maj-min: 8:4 size: 515 MiB fs: ntfs label: N/A
uuid: 5898737C98735788
ID-4: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: ntfs label: N/A
uuid: 486FEC5338457727
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 2-7:3 info: Sunplus Innovation HD WebCam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 1bcf:2c81 class-ID: 0e02
Device-2: 2-8:4 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 353 Power: uptime: 1h 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1374 libs: 399
tools: gnome-software,pamac pm: rpm pkgs: 0 pm: flatpak pkgs: 0 Compilers:
gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.35
See? It says:
But my Bluetooth adapter is also my Wi-Fi adapter, which is detected:
Wi-Fi is working. Although I’m not able to connect to my home 5GHz network from Manjaro. But that’s another problem, that I can solve later…
What should I do to get Bluetooth working on my system?
Thank you in advance!
